Getting Started with Jetson-Claw on Orin Nano / NX 8GB
This wiki walks through a practical Jetson-Claw starter build for Jetson Orin Nano 8GB and Jetson Orin NX 8GB. The whole stack runs locally on Jetson: we install nanobot, expand swap space for safer model loading, compile llama.cpp with CUDA, download a Qwen3.5 4B GGUF model, switch nanobot to a local llama.cpp backend, and finally connect the bot to Feishu so you can control it from chat.
Compared with a larger OpenClaw deployment, nanobot is a better fit for this entry-level Jetson-Claw setup because it is much lighter, starts faster, is easier to read and modify, and already supports Feishu plus OpenAI-compatible local backends. On an 8 GB Jetson, that lower runtime overhead leaves more room for the local model itself. If you later need a larger plugin ecosystem or a heavier multi-component workflow, you can still move up to OpenClaw.
What You Will Build
  • A lightweight local AI assistant based on nanobot
  • A llama.cpp OpenAI-compatible HTTP server running on Jetson
  • A local Qwen3.5 4B GGUF model
  • A Feishu-connected Jetson bot that can be controlled from private chats or group mentions
Prerequisites
  • 1 x Jetson Orin Nano 8GB or Jetson Orin NX 8GB
  • JetPack 6.x already installed
  • Internet connection for package and model download
  • At least 20 GB of free storage recommended
This guide uses reComputer Super J3011 as the reference Jetson platform:
info
nanobot currently requires Python 3.11 or newer, so this guide uses a Miniconda environment instead of the default system Python on Jetson.
Step 1. Install nanobot
First install system dependencies and Miniconda:
sudo apt update
sudo apt install -y git curl wget build-essential cmake libcurl4-openssl-dev python3-pip
chmod +x Miniconda3-latest-Linux-aarch64.sh
./Miniconda3-latest-Linux-aarch64.sh
source ~/.bashrc
Create a clean Python 3.11 environment and install nanobot:
conda create -y -n jetson-claw python=3.11
conda activate jetson-claw
pip install -U pip
pip install nanobot-ai
Initialize the runtime directory:
nanobot onboard
After initialization, the main configuration file is located at:
~/.nanobot/config.json
note
nanobot is inspired by OpenClaw, but for Orin Nano / NX 8GB it is usually the better starting point: less memory overhead, faster startup, and fewer moving parts to debug.
Step 2. Increase Swap Space
Running a 4B local model on an 8 GB Jetson is much more stable with extra swap. This helps during model loading, compilation, and long-context inference.
sudo fallocate -l 8G /var/swapfile
sudo chmod 600 /var/swapfile
sudo mkswap /var/swapfile
sudo swapon /var/swapfile
echo '/var/swapfile none swap sw 0 0' | sudo tee -a /etc/fstab
swapon --show
If you plan to experiment with larger context sizes or other models, you can increase swap further.
Step 3. Compile llama.cpp with CUDA
Set CUDA paths:
export PATH=/usr/local/cuda/bin${PATH:+:${PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda/lib64${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
Clone and build llama.cpp:
git clone https://github.com/ggml-org/llama.cpp.git ~/llama.cpp
cd ~/llama.cpp
cmake -B build -DGGML_CUDA=ON -DCMAKE_BUILD_TYPE=Release
cmake --build build --parallel
After compilation, the main executables will be placed under:
~/llama.cpp/build/bin
You can quickly confirm the server binary is ready with:
~/llama.cpp/build/bin/llama-server --help
Step 4. Download Qwen3.5 4B GGUF Weights
This guide uses a Q4_K_M GGUF quantization because it is a practical balance between memory usage and response quality for 8 GB Jetson devices.
Install the Hugging Face CLI:
pip install -U "huggingface_hub[cli]"
mkdir -p ~/llama.cpp/models/Qwen3.5-4B-GGUF
Then open the model page below and download the Q4_K_M GGUF file into ~/llama.cpp/models/Qwen3.5-4B-GGUF/:
Choose the Qwen3.5-4B.Q4_K_M.gguf file on the Hugging Face page:
If the repository uses the same filename as the example in this guide, you can also download it with:
huggingface-cli download \
unsloth/Qwen3.5-4B-GGUF \
Qwen3.5-4B.Q4_K_M.gguf \
--local-dir ~/llama.cpp/models/Qwen3.5-4B-GGUF
If your file is named differently, just update the path in the launch command below. In the example here, we assume the model file is:
~/llama.cpp/models/Qwen3.5-4B-GGUF/Qwen3.5-4B.Q4_K_M.gguf
Step 5. Launch llama.cpp as the Local Backend
Start the local OpenAI-compatible API server:
cd ~/llama.cpp
./build/bin/llama-server \
-m ~/llama.cpp/models/Qwen3.5-4B-GGUF/Qwen3.5-4B.Q4_K_M.gguf \
--alias qwen3.5-4b-local \
-t 6 \
-c 40960 \
--n-gpu-layers 40 \
--reasoning off \
--reasoning-format none \
--host 127.0.0.1 \
--port 8080
Recommended parameter notes:
  • --alias qwen3.5-4b-local: gives the local model a clean API model name for nanobot
  • -t 6: uses a moderate number of CPU threads on entry-level Jetson devices
  • -c 40960: provides a large context window, but you can reduce it if memory is tight
  • --n-gpu-layers 40: offloads as many layers as practical to the Jetson GPU
  • --reasoning off: keeps output simpler and lowers unnecessary overhead for a starter setup
If the server fails to start because of memory pressure, try reducing -c to 16384 first, then lower --n-gpu-layers.
In another terminal, verify the API:
curl http://127.0.0.1:8080/v1/models
Step 6. Configure nanobot to Use llama.cpp
Open the configuration file:
nano ~/.nanobot/config.json
Then merge the following sections into your config:
"agents": {
"defaults": {
"workspace": "~/.nanobot/workspace",
"model": "qwen3.5-4b-local",
"provider": "custom",
"maxTokens": 8192,
"contextWindowTokens": 40960,
"temperature": 0.1,
"maxToolIterations": 40,
"reasoningEffort": null
"channels": {
"sendProgress": true,
"sendToolHints": false,
"feishu": {
"enabled": true,
"appId": "cli_xxx",
"appSecret": "xxx",
"encryptKey": "",
"verificationToken": "",
"allowFrom": ["*"],
"reactEmoji": "THUMBSUP",
"groupPolicy": "mention",
"replyToMessage": false
"providers": {
"custom": {
"apiKey": "no-key",
"apiBase": "http://127.0.0.1:8080/v1",
"extraHeaders": null
"gateway": {
"host": "0.0.0.0",
"port": 18790
Why this works:
  • provider: "custom" tells nanobot to use any OpenAI-compatible backend
  • apiBase: "http://127.0.0.1:8080/v1" points to the local llama-server
  • model: "qwen3.5-4b-local" matches the --alias value used when starting llama.cpp
warning
For quick testing, allowFrom: ["*"] is convenient. For production use, replace it with your own Feishu open_id after validation.
Step 7. Connect Feishu to nanobot
Create a Feishu application in the Feishu Open Platform:
  • Open https://open.feishu.cn/app
  • Create or open your bot application
  • Copy the App ID and App Secret
  • Paste them into channels.feishu.appId and channels.feishu.appSecret
For Long Connection mode, encryptKey and verificationToken can stay empty.
If you cannot find your credentials later, go to:
  • Feishu Open Platform
  • Your application
  • Credentials & Basic Info
Import Feishu Permissions
To make file, image, and rich message handling work correctly, import the permission set below in:
  • Your application
  • Permission Management
  • Bulk Import
"scopes": {
"tenant": [
"aily:file:read",
"aily:file:write",
"application:application.app_message_stats.overview:readonly",
"application:application:self_manage",
"application:bot.menu:write",
"cardkit:card:write",
"contact:user.employee_id:readonly",
"corehr:file:download",
"docs:document.content:read",
"event:ip_list",
"im:chat",
"im:chat.access_event.bot_p2p_chat:read",
"im:chat.members:bot_access",
"im:message",
"im:message.group_at_msg:readonly",
"im:message.group_msg",
"im:message.p2p_msg:readonly",
"im:message:readonly",
"im:message:send_as_bot",
"im:resource",
"sheets:spreadsheet",
"wiki:wiki:readonly"
"user": [
"aily:file:read",
"aily:file:write",
After importing permissions:
  • Create a new app version
  • Publish the app version
Otherwise the newly added permissions may not take effect.
Step 8. Start nanobot and Test Feishu Control
Keep llama-server running in one terminal, then start nanobot in another:
nanobot gateway
Useful checks:
nanobot status
nanobot channels status
Now send a message to the bot from Feishu:
  • In a private chat, send a direct message
  • In a group chat, mention the bot if you keep groupPolicy: "mention"
If you used allowFrom: ["*"], the bot should reply immediately. If you later want to lock access down, send one message first, check the nanobot logs for your open_id, and replace ["*"] with that value.
Optional: Add a Sample Jetson-Claw Skill
If you want to turn this starter setup into a more useful Jetson-Claw demo, you can add a sample skill set:
git clone https://github.com/jjjadand/JetsonClaw-SKILLS.git ~/JetsonClaw-SKILLS
mkdir -p ~/.nanobot/workspace/skills
cp -r ~/JetsonClaw-SKILLS/person-detection ~/.nanobot/workspace/skills/
Then restart nanobot gateway, connect a USB camera to Jetson, and ask the bot in Feishu to check whether a person is visible in front of the camera.
Example Feishu Monitoring Flow
After the skill is installed, you can send a request from the Feishu app to ask Jetson-Claw to check the camera feed:
If no person is detected, the monitoring result can look like this:
If a person is detected, Jetson-Claw can return an alert through Feishu:
The monitoring skill can also send back the captured result image:
Troubleshooting
  • nanobot fails to install: make sure you are inside a Python 3.11 environment
  • llama-server exits during model load: increase swap or reduce -c
  • Feishu bot does not reply: verify App ID, App Secret, imported permissions, and published app version
  • Group messages do not trigger the bot: check groupPolicy and make sure you mention the bot
  • Replies are slow: lower context size, reduce concurrent usage, or use a smaller quantization
References
