Getting Started with reTerminal E1003
Introduction
reTerminal E1003 is a 10.3 inch open-source monochrome ePaper display featuring 16 levels of grayscale and a high-resolution of 1404×1872 pixels, with up to 6-month battery life. Touch interaction is currently supported on SenseCraft HMI firmware v1.1.2. Powered by ESP32-S3, it natively supports our SenseCraft HMI no-code UI platform for effortless dashboard creation, while supporting Arduino and PlatformIO for further development. Support for Home Assistant (via ESPHome & Open Display) is planned for a future release. Whether for smart home dashboard visualization and control, office information displays, or educational projects, this ready-to-use device delivers stunning visuals and flexible customization to meet all your needs.
Touch interaction for reTerminal E1003 is supported starting from SenseCraft HMI firmware v1.1.2. Touch-related library support is planned for future open-source release, providing greater flexibility to customize panels. More updates will be shared soon.
ESPHome support for reTerminal E1003 is under development and will be available in a future release.
- Up to 16-level grayscale clarity: Boasting 16 levels of exquisite grayscale, every detail of text and graphics is rendered with exceptional sharpness and clarity.
- Ultra-Low Power Consumption: The ePaper consumes power only during updates, resulting in longer battery life and greater energy efficiency.
- SenseCraft HMI Support: The reTerminal E Series Display supports SenseCraft HMI by default firmware.
- Wide Range of Applications: Supports high-speed refresh for low-latency updates with a TTL parallel interface (multi-line, high-throughput) — making it an ideal choice for smart home control panels.
- High-Resolution Touch ePaper Display: The 10.3-inch 1404×1872 monochrome ePaper display is paired with a built-in responsive touchscreen, with touch interaction currently supported on SenseCraft HMI firmware v1.1.2.
- Adapting to Decoration Needs: Wire-free for greater freedom; supports wall-mount and desktop placement, with flexible portrait and landscape orientation switching.
| Item | Description |
| Product Name | reTerminal E1003 |
| Processor | ESP32-S3 with 8MB PSRAM |
| Storage | 32MB Flash, support Micro SD card |
| Display | 10.3" Monochrome/ 16-level Grayscale |
| Resolution | 1404x1872 Pixels |
| Micro SD Card | Maximum support 32GB SD card, FAT32 format |
| Wireless Connectivity | 2.4GHz 802.11 b/g/n Wi-Fi, Bluetooth 5.0 |
| Sensors | Temperature, humidity sensors |
| Microphone | Reserved for voice interaction application |
| Audio | Buzzer for sound alert |
| Battery | 3000mAh |
| Power Input | USB-C 5V/1A |
| Software Support | Default firmware support SenseCraft HMI(https://sensecraft.seeed.cc/hmi/) Support Arduino/PlatformIO development platform |
| Working Temperature | 0-40°C |
| Dimensions | 224mm187mm18.6mm |
Hardware Overview
- Screen Refresh Button
- Page Up and Down Button
- Wi-Fi Antenna Area
- MicroSD Card/TF Card port
- Power Switch
- Red Power LED
- Green Status LED
- USB-C Data and Charge Port
- Expansion Port
- Stand Mounting Screw Hole
- Stand
Applications
- Home Automation Dashboards: Display real-time smart home data like temperature, humidity, and air quality via Home Assistant (ESPHome driver support for E1003 is planned for a future release).
- Low-power Monochrome electronic photo frame: With SenseCraft HMI or the App, you can easily upload a series of photos from your album remotely online. Combined with a large, high-resolution monochrome e-ink screen, it achieves ultra-low power image display, no longer have to worry about battery life.
- Smart Office Displays: Show meeting room availability, office schedules, or directional guidance in low-power, always-on ePaper displays.
- Retail & Public Information Displays: Low-power ePaper signs for menus, schedules, or occupancy indicators with long battery life.
Getting Started with SenseCraft HMI
The reTerminal E1003 comes pre-loaded with firmware that supports SenseCraft HMI, a no-code platform that allows you to design and deploy personalized dashboards effortlessly.
Step 1. Power On and Network Configuration
- Turn on the Power Button to turn on the reTerminal E1003.
- Use your smartphone to connect to the device's hotspot (AP mode) to configure the Wi-Fi credentials.
- The screen will display a "Network Configuration" QR code or use browser open 192.168.4.1 page.
- Once connected to the internet, the device will display a Device Code or Binding QR Code.
Step 2. Bind the Device
- Visit the SenseCraft HMI Platform on your computer browser.
- Log in to your account (or create one if you haven't).
- Navigate to the Device Management section and click Add Device.
- Enter the Device Code displayed on your reTerminal E1003 screen to complete the binding process.
Step 3. Create Content on the Platform
- Go to the Home Page select a template you want or Workspace to create your work from scratch.
- Click this link to learn how to use HMI Platform if you have question.
Step 4. Deploy Content to Device
- Once your design is ready, click the Preview button to check how it looks.
- Click the Save or deploy button.
- Select your bound reTerminal E1003 from the list.
- The platform will send the data to your device via Wi-Fi. The ePaper screen will refresh to display your new dashboard.
Troubleshooting
Q1: Device Won't Power On
- Ensure the power switch is in the ON position
- Connect the USB-C cable to charge the device
- Check if the red LED is always on (indicating charging)
- If using battery power, ensure the battery is properly connected and charged
Q2: Can't Connect to Wi-Fi
- Verify you're entering the correct Wi-Fi password
- Ensure your Wi-Fi network is operational
- Check if your Wi-Fi router supports 2.4GHz networks (5GHz is not supported)
- Try positioning the device closer to your Wi-Fi router
Q3: Display Not Updating
- Press the refresh button to manually trigger an update
- Verify the device is connected to Wi-Fi (no disconnection icon in the corner)
- Check your SenseCraft account to ensure the dashboard is properly deployed
- If the problem persists, try restarting the device
- If the device still does not respond after restarting, re-flash the corresponding firmware on the SenseCraft HMI platform and check whether the device can refresh normally
Q4: Network Connection Lost
- The device will automatically attempt to reconnect to known networks
- When reconnected, the Wi-Fi disconnection icon will disappear
- If unable to reconnect, follow the Network Reset procedure above
Q5: Cannot Find Serial Port (COM) on macOS
If your Mac doesn't recognize the reTerminal via USB, follow this compact guide to install the CH340/CH340K driver:
Step 1. Download and Install the Driver
Download the driver from the official WCH page and run CH34xVCPDriver.pkg.
If macOS blocks the installation, go to System Settings → Privacy & Security, scroll to find the blocked WCH software, and click Allow.
Step 2. Enable Driver Extension (Critical) Open the CH34xVCPDriver app from Launchpad, click Install, then go to System Settings → General → Login Items & Extensions → Driver Extensions. Toggle CH34xVCPDriver Extensions to ON (blue).
Step 3. Connect and Verify Ensure the device power switch is ON and use a data USB-C cable (not charge-only). Open Terminal and run:
ls /dev/tty.wch*
# Expected output: /dev/tty.wchusbserialxxx
If you see the device path in the output, the driver is correctly installed and your reTerminal is ready for use!
