go2rtc on reComputer
Introduction
go2rtc is an open-source WebRTC framework designed to facilitate real-time media streaming over the internet. It is developed by the XTLS team and aims to combine WebRTC with other media protocols like RTSP, RTMP, and HLS for efficient real-time video and audio transmission.
WebRTC (Web Real-Time Communication) is a widely used protocol for establishing peer-to-peer connections and enabling real-time media exchange such as video calls, live broadcasts, and other real-time applications. go2rtc makes it easier to implement WebRTC in environments where different media protocols need to be converted into WebRTC streams for low-latency and scalable transmission.
Prerequisites
Hardware Requirements
| reComputer R1125 | reComputer AI R2130 | reComputer AI Industrial R2145 |
| reComputer Industrial R20xx | reComputer Industrial R21xx |
Download and run go2rtc
Update system
Please use the following command to run.
sudo apt update
sudo apt upgrade -y
Download go2rtc
wget https://nightly.link/AlexxIT/go2rtc/workflows/build/master/go2rtc_linux_arm64.zip
tar -xvzf go1.24.0.linux-arm64.tar.gz
chmod +x go2rtc_linux_arm64
Create go2rtc.yaml
nano go2rtc.yaml
Please fill in the following configuration with your actual IP address.
streams:
stream1:
url: rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=1
protocol: rtsp
codec: h264
server:
api: :1984
rtsp: :8554
webrtc: :8555
Run go2rtc
./go2rtc_linux_arm64
Open port 1984 on the host, and click the Streambutton.
Result
Once we have configured everything, we can view the live feed from the current camera.
