Grove-Color Sensor V3.0 - I2C interface
It is a sensor to measure the color chromaticity of ambient light or the color of objects. With the synchronization input pin, an external pulsed light source can provide precise synchronous conversion control.
- Color Detection: Measures red, green, blue, and white light components.
- I2C Interface: Easy integration with microcontrollers via I2C for data access.
- Supply Voltage: Operates at 3.3V or 5V.
- Synchronization: Can work with an external pulsed light source for accurate readings.
- Compact Design: Small form factor for easy integration into various projects.
- Low Power Consumption: Ideal for battery-operated devices.
| Parameter | Value/Range |
| Color Channels | Red, green, blue, and clear (white) |
| Supply Voltag | 3.3V to 5V |
| Interface | I2C |
| Resolution | 16-bit color data output |
| Operating Temperature Range | -40°C to +85°C |
| Current Consumption | 200μA |
| Selectable maximum detection range | 515.4, 1031, 2062, 4124, 8248, or 16 496 lux with highest sensitivity 0.007865 lux/step |
Getting Started
indication diagram
Hardware
Step 1. Prepare the below stuffs:
- Play with Arduino
| Seeeduino V4.2 | Base Shield | Grove - Color Sensor V3.0 |
| Get One Now | Get One Now | Get One Now |
- Connect Grove with Arduino
- Play with XIAO ESP32 Series
| Seeed Studio Grove Base for XIAO | XIAO ESP32-S3 | Grove - Color Sensor V3.0 |
- Connect Grove with XIAO ESP32S3
Two different combinations, but using the same code.
Software
- Step 1. DownLoad Library
Install the VEML6040 library.
- Step 2. Copy the code into Arduino IDE and upload.
#include "Wire.h"
#include "veml6040.h"
VEML6040 RGBWSensor;
Serial.begin(9600);
Wire.begin();
if(!RGBWSensor.begin()) {
Serial.println("ERROR: couldn't detect the sensor");
while(1){}
RGBWSensor.setConfiguration(VEML6040_IT_320MS + VEML6040_AF_AUTO + VEML6040_SD_ENABLE);
delay(1500);
Serial.println("Vishay VEML6040 RGBW color sensor auto mode example");
Serial.println("CCT: Correlated color temperature in \260K");
Serial.println("AL: Ambient light in lux");
delay(1500);
Serial.print("RED: ");
Serial.print(RGBWSensor.getRed());
Serial.print(" GREEN: ");
Serial.print(RGBWSensor.getGreen());
Serial.print(" BLUE: ");
Serial.print(RGBWSensor.getBlue());
Serial.print(" WHITE: ");
Serial.print(RGBWSensor.getWhite());
Serial.print(" CCT: ");
Serial.print(RGBWSensor.getCCT());
Serial.print(" AL: ");
Serial.println(RGBWSensor.getAmbientLight());
delay(400);
- Step 3. Open the serial port to view the printed content.
When I placed the color sensor on the white area of our viewer, we opened the serial port and found that the value of WHITE was the highest
- [SCH] Grove_Color_Sensor Reference Information
- [Datasheet] VISHAY_VEML6040A3OG_Datasheet.PDF
