Install the Isaac Lab
This wiki provides a step-by-step guide to install Isaac Lab. Isaac Lab requires Isaac Sim. This tutorial first installs Isaac Sim via pip, then installs Isaac Lab from source code.
  • This tutorial is only applicable to Ubuntu 20.04 and 22.04 systems and does not currently support Windows. Please ensure your computer has NVIDIA graphics drivers and CUDA 12+ installed based on your GPU.
  • Check the official Isaac Sim link to verify if your hardware meets the requirements.
  • Miniconda is recommended and must be pre-installed.
Creating a Virtual Environment with Miniconda
We recommend creating a virtual environment first. Ensure the Python version in the virtual environment is Python 3.10.
conda create -n env_isaaclab python=3.10
conda activate env_isaaclab
Installing PyTorch and torchvision
Next, install PyTorch and Torchvision according to your CUDA version.
pip install torch==2.5.1 torchvision==0.20.1 --index-url https://download.pytorch.org/whl/cu118
Installing Isaac Sim
pip install --upgrade pip
pip install 'isaacsim[all,extscache]==4.5.0' --extra-index-url https://pypi.nvidia.com
Verifying Isaac Sim Installation
isaacsim
note
When running Isaac Sim for the first time, all required extensions will be pulled from the registry. This process may take over 10 minutes and is necessary for the initial run of each experience file. Once the extensions are downloaded, subsequent runs with the same experience file will use cached extensions.
Installing Isaac Lab
Clone the Isaac Lab repository
git clone https://github.com/isaac-sim/IsaacLab.git
Install dependencies for Isaac Lab
sudo apt install cmake build-essential
Install Isaac Lab's reinforcement learning libraries
./isaaclab.sh --install  # or "./isaaclab.sh -i"
You can also install a specific RL library individually:
./isaaclab.sh --install rl_games  # or "rsl_rl, sb3, skrl, robomimic"
Verify Isaac Lab installation
Navigate to the cloned Isaac Lab directory.
Option 1: Launch via shell script
./isaaclab.sh -p scripts/tutorials/00_sim/create_empty.py
Option 2: Launch via Python
python scripts/tutorials/00_sim/create_empty.py
note
The above commands should launch the simulator and display a window with a black viewport, as shown below. You can exit the script by pressing Ctrl+C in the terminal. On Windows, use Ctrl+Break or Ctrl+fn+B in the Command Prompt to terminate the process.
Training a Simple Robot
You can train a group of spiders using the provided example script:
./isaaclab.sh -p scripts/reinforcement_learning/rsl_rl/train.py --task=Isaac-Ant-v0 --headless
Or train a single dog:
./isaaclab.sh -p scripts/reinforcement_learning/rsl_rl/train.py --task=Isaac-Velocity-Rough-Anymal-C-v0 --headless
Installing Isaac Gym (Optional)
The previous installation steps are sufficient, but if you only want to experience the reinforcement learning part with Isaac Gym, you can install Isaac Gym separately.
Download and extract Isaac Gym code
Extract it to your home directory, then create a Conda environment and install dependencies:
conda create --name isaac python=3.8
conda activate isaac
conda install pytorch torchvision torchaudio pytorch-cuda=12.4 -c pytorch -c nvidia
conda install numpy=1.23
Install Isaac Gym
cd <path_to_isaacgym>/IsaacGym_Preview_4_Package/isaacgym/python
pip install -e .
Verify Isaac Gym installation
cd <path_to_isaacgym>/IsaacGym_Preview_4_Package/isaacgym/python/examples
python 1080_balls_of_solitude.py
warning
Possible error & solution
When running the Python script, you may encounter the following error:
ImportError: libpython3.8.so.1.0: cannot open shared object file: No such file or directory
Fix it with this command (replace the path with your own):
export LD_LIBRARY_PATH=${LD_LIBRARY_PATH}:/home/{Your Username}/anaconda3/envs/pi/lib
