Install the Isaac ROS
Isaac ROS Initial Environment Setup
ReComputer Requirements
Hardware Environment
  • Jetson Orin/Jetson Xavier
Software Environment
1. Install Initial Dependencies
Follow NVIDIA's official image and Seeed WIki's flashing guide:
sudo apt-get install python3-pip # Install python3
sudo apt-get install nvidia-jetpack # Install developer tools
sudo pip3 install jetson-stats # Install Jtop to check Jetpack version
sudo apt-get install git-lfs # Install git-lfs
2. Install Docker-CE
Update software sources:
sudo apt-get update
Install basic dependencies:
sudo apt-get install \
apt-transport-https \
ca-certificates \
curl \
software-properties-common # Install essential packages to allow apt over HTTPS
Add Docker's official GPG key:
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
Add Docker's stable repository:
sudo add-apt-repository \
"deb [arch=arm64] https://download.docker.com/linux/ubuntu \
$(lsb_release -cs) \
stable"
Update package list again (new repository added):
sudo apt-get update
Install Docker CE (Community Edition):
sudo apt-get install docker-ce
Ensure Docker starts:
sudo systemctl enable docker
sudo systemctl start docker
Add permissions (add user to Docker group):
sudo usermod -aG docker $USER
Reboot system or logout:
sudo reboot
3. Isaac ROS Common Package Configuration
Create workspace and add to environment:
mkdir -p ~/workspaces/isaac_ros-dev/src
echo "export ISAAC_ROS_WS=${HOME}/workspaces/isaac_ros-dev/" >> ~/.bashrc
source ~/.bashrc
Enter workspace and clone packages:
cd ${ISAAC_ROS_WS}/src
git clone https://github.com/NVIDIA-ISAAC-ROS/isaac_ros_common.git
Pull official Isaac Common Docker image and enter Docker:
cd ${ISAAC_ROS_WS}/src/isaac_ros_common && \
./scripts/run_dev.sh
Initial environment configuration completed.
