Install Pytorch for reComputer Jetson
This wiki demonstrates how to install NVIDIA-optimized PyTorch on your reComputer, matching your JetPack version. It also covers how to use virtual environments (conda) to manage multiple PyTorch versions for development and deployment.
Prerequisites
  • reComputer with JetPack installed
  • Internet connection
Install PyTorch for reComputer
Here, we will introduce how to install PyTorch with CUDA support in the two commonly used versions of Jetpack 5 and Jetpack 6.
In reComputer, the commonly used version of Jetpack 5 is 5.1.3. Here, we will use it to introduce how to install PyTorch.
Step 1. Update system and install dependencies:
sudo apt-get -y update
sudo apt-get install -y python3-pip libopenblas-dev
Step 2. Download the official PyTorch wheel (example: torch-2.1.0 for JetPack 5.1.3, Python 3.8):
wget https://developer.download.nvidia.com/compute/redist/jp/v512/pytorch/torch-2.1.0a0+41361538.nv23.06-cp38-cp38-linux_aarch64.whl
pip install torch-2.1.0a0+41361538.nv23.06-cp38-cp38-linux_aarch64.whl
note
If you need a more recent version of torch that supports Jetpack 5.1.3, please download the compiled wheel file from here (torch-2.2 for python3.8).
Step 3. Verify installation:
import torch
print(torch.cuda.is_available())
print(torch.__version__)
Multiple PyTorch Versions with Conda
Miniconda is a lightweight installer for the Conda package manager, providing a minimal environment to quickly create and manage Python environments and packages.
Step 1. Install Miniconda:
bash Miniconda3-latest-Linux-aarch64.sh
info
  • Follow the instructions and enter "yes" to agree to the terms.
  • The installation path is recommended to use the default setting, such as ~/miniconda3.
  • Finally, it prompts whether to automatically add to .bashrc. It is recommended to enter "yes".
Step 2. Initialize and configure conda:
source ~/.bashrc
# Verify if conda is functioning properly
conda --version
# Disable automatic entry into the conda base environment
conda config --set auto_activate_base false
# Close and reopen the terminal. By default, it will not enter the base environment.
Step 3. Create a new environment and install a specific PyTorch wheel:
conda create -n torch_2.0 python=3.8
conda activate torch_2.0
Step 4. Download and install the PyTorch wheel file as shown in the previous sections.
info
For more details, see the NVIDIA PyTorch installation guide
