iSpy on reComputer
Introduction
iSpy is an open-source video surveillance application, designed to work with consumer webcams and IP cameras. It was originally launched in 2007 and has evolved into a full-featured monitoring solution.
Prerequisites
Hardware Requirements
reComputer R1125reComputer AI R2130reComputer AI Industrial R2145
reComputer Industrial R20xxreComputer Industrial R21xx
Download iSpy
Update system
Please use the following command to run.
sudo apt update
sudo apt upgrade -y
Download docker and docker compose
Please use the following command to install docker.
wget https://get.docker.com -O get-docker.sh
chmod +x
sudo sh get-docker.sh
sudo systemctl start docker
sudo systemctl enable docker
docker --version
The result is shown as below:
Please use the following command to install docker compose.
sudo curl -L "https://github.com/docker/compose/releases/download/$(curl -s https://api.github.com/repos/docker/compose/releases/latest | jq -r .tag_name)/docker-compose-$(uname -s)-$(uname -m)" -o /usr/local/bin/docker-compose
sudo chmod +x /usr/local/bin/docker-compose
docker-compose --version
Create docker-compose.yaml
Please use the following command to create docker-compose.yaml.
cd ~ && nano docker-compose.yaml
Then input the following content into the YAML file.
services:
agentdvr:
image: mekayelanik/ispyagentdvr:latest
container_name: AgentDVR
restart: unless-stopped
environment:
- PUID=1000
- PGID=1000
- TZ=America/New_York
- AGENTDVR_WEBUI_PORT=8090
ports:
- "8090:8090"
- "3478:3478/udp"
- "50000-50100:50000-50100/udp"
volumes:
- /appdata/AgentDVR/config/:/AgentDVR/Media/XML/
- /appdata/AgentDVR/media/:/AgentDVR/Media/WebServerRoot/Media/
- /appdata/AgentDVR/commands:/AgentDVR/Commands/
Please use the following command to create necessary folder.
sudo mkdir -p /appdata/AgentDVR/config /appdata/AgentDVR/media /appdata/AgentDVR/commands
Configure iSpy
Run docker compose
Please use the following command to init database.
sudo docker compose up -d
The result is shown as below.
Configure
Open the localhost:8090 port:
Add a camera by following the steps below:
Result
Once we have configured everything, we can view the live feed from the current camera.
