Device Management
The Device Management module provides a quick dashboard for understanding the current state of your connected Jetson device — hardware diagnostics, peripheral detection, and live system metrics — all without opening a terminal.
Connecting to a Device​
Enter the Jetson's IP address, SSH username, and password in the connection panel, then click Connect. See Connect Device for network setup details.
Features​
System Info​
Once connected, the dashboard displays:
InfoDescription
Device modele.g. reComputer Super J4012s
JetPack / L4T versionCurrent firmware version
CPU usagePer-core utilization in real time
GPU usageCurrent GPU load percentage
MemoryUsed / total RAM
DiskUsed / total storage
TemperatureCPU, GPU, and board thermal zones
Peripheral Detection​
Click Detect Peripherals to scan for connected hardware:
  • USB devices (cameras, Wi-Fi adapters, storage)
  • NVMe / M.2 drives
  • Display outputs
  • GPIO / I2C / SPI interfaces
Quick Diagnostics​
Click Run All Checks to run a one-click health check. The tool auto-checks Network, GPU / Torch, Docker, jtop, USB Camera, Boot Disk, and other key components, displaying each result inline with a pass / fail status and quick-fix shortcuts.
Click Peripherals Only to scan connected hardware — USB-WiFi, 5G module, Bluetooth, NVMe SSD, cameras, and HDMI display — without running the full diagnostic suite.
Install PyTorch​
If the GPU / Torch check shows "Not installed", click the Install PyTorch button to open the installation wizard. The tool auto-detects your JetPack version and selects the matching NVIDIA PyTorch wheel. You can also choose the Python target environment (system Python or a new Miniforge conda env).
Click Start Install to begin. The installation runs in the background — click Run in Background to continue using the tool while it completes.
