Skills
The Skills module provides 50+ built-in automation scripts that handle common Jetson setup and configuration tasks — from installing drivers to deploying AI frameworks — with a single click.
Skill Categories​
Drivers & Fixes​
SkillDescription
USB-WiFi (88x2bu)Install driver for RTL88x2BU Wi-Fi adapters
5G Module SupportConfigure 5G cellular module connectivity
Bluetooth Conflict FixResolve common Bluetooth + Wi-Fi coexistence issues
NVMe BootConfigure the system to boot from NVMe SSD
Docker CleanupRemove unused Docker images and containers to free space
AI / LLM​
SkillDescription
PyTorch (Jetson)Install the NVIDIA-optimized PyTorch wheel for JetPack
OllamaInstall Ollama LLM inference engine
DeepSeekDeploy DeepSeek models on Jetson
Qwen2Install Qwen2 LLM with Jetson optimizations
LeRobotSet up Hugging Face LeRobot for embodied AI
vLLMInstall vLLM high-throughput inference server
Vision / YOLO​
SkillDescription
YOLOv8Install Ultralytics YOLOv8 with TensorRT export
DeepStreamSet up NVIDIA DeepStream SDK
NVBLOXInstall NVBLOX for 3D scene reconstruction
Depth EstimationConfigure depth estimation pipeline
Network & Remote​
SkillDescription
VS Code ServerInstall code-server for browser-based IDE
VNC ServerSet up noVNC remote desktop
SSH Key SetupConfigure passwordless SSH key authentication
Proxy ConfigConfigure system-wide HTTP/HTTPS proxy
System Tuning​
SkillDescription
Max Performance ModeSet Jetson to maximum CPU/GPU clock speeds (nvpmodel)
Swap ConfigCreate or resize swap space
Fan ControlConfigure fan curve and cooling profile
Cache CleanupClear package and pip caches to recover disk space
Running a Skill​
  1. Connect to your Jetson device.
  2. Open the Skills tab.
  3. Browse by category or search by keyword.
  1. Click Run on the desired skill.
  1. A log window shows the execution output in real time.
Community Skills (OpenClaw)​
Skills use the OpenClaw format. You can add your own custom skills by placing them in the skills/openclaw/ directory — the tool auto-loads them on startup.
