MUI Introduction
What is MUI?​
MUI (Meshtastic User Interface) is an open-source graphical interface designed for Meshtastic devices. It provides a more intuitive way for users to interact with device.
Key Features
  • Interactive Map: MUI displays node locations directly on online or offline maps. Check nearby devices and their positions without opening a mobile or desktop APP.
  • Convenient Device Configuration: Configure Meshtastic settings directly on the device, including radio, GPS, display, and other common options. No external app is required for routine configuration.
  • Intuitive Graphical Interface: MUI provides a touchscreen-optimized interface with clear menus and map-based navigation. Common operations can be completed with just a few taps, making the device easier to use for both new and experienced users.
Get start with MUI based on Wio Tracker L2​
UI Switching​
Go to Setting page -> Choose Reboot/Shutdown -> Long press the Bluetooth icon -> Click OK
The BaseUI switch popup appears when you long-press the Bluetooth icon.
If you just click the Bluetooth icon, you will enter Bluetooth mode. If so, long press the Bluetooth icon shown on the screen, the device will automatically reboot to MUI.
Phone Connection​
Go to Setting page, click Reboot/Shutdown, then click the Bluetooth icon.
The device will then reboot in Bluetooth mode. The Bluetooth pairing code will be shown on the screen.
LoRa Configuration​
In order to start communicating over the mesh, you must set your region. This setting controls which frequency range your device uses and should be set according to your regional location.
Region List
Region CodeDescriptionFrequency Range (MHz)Duty Cycle (%)Power Limit (dBm)
UNSETUnsetN/AN/AN/A
USUnited States902.0 - 928.010030
EU_868European Union 868MHz869.4 - 869.651027
Refer to LoRa Region by Country for a more comprehensive list.
info
EU_868 has to adhere to an hourly duty cycle limitation of 10%, calculated every minute on a rolling 1-hour basis. Your device will stop transmitting if you reach it, until it is allowed again.
Go to Setting page, click Region, choose region and then click the OK.
Now that you have set the LoRa region on your device, you can continue with configuring any LoRa Configs to suit your needs.
Map Usage​
Step1. Enable GPS
You need to enable GPS to get position. This can be configured directly on device by long pressing the position icon.
Also, you can configure it on your phone APP.
Step2. SD Card Preparation
You need to format and install map in your SD card. For detailedd SD card usage tutorial, please click here to view.
Step3. Install SD Card
Step4. View Map
Waiting for the map to load. After successfully connecting to Wi-Fi and obtaining location, the device will display an offline map.
Advance Interation​
Home Page​
Node Page​
  • Click any node: Expand node detailed parameter information
  • Long press any node: Enter chatting
  • Long press coordinate: See node position on map
Channel Page​
  • Click a channel: Enter channel chatting
  • Long press a channel: Mute/Unmute the channel
Only configured channels, such as the named channel shown in the left image below, can be interacted with. Channels like the one shown in the right image, which are not configured and only labeled, cannot be interacted with.
Message Page​
  • Click a chat: Enter a chatting.
  • Long press a chat: Reveals a DEL button to delete it.
  • Highlighted in orange: Indicates a new unread message.
Setting Page​
  • Reboot: Choose "Reboot/Shutdown", click the green "Reboot" icon.
  • Turn off: Choose "Reboot/Shutdown", click the red "Turn off" icon.
  • Enter Bluetooth mode: Choose "Reboot/Shutdown", click the blue "Bluetooth" icon.
  • Switch to BaseUI: Choose "Reboot/Shutdown", long press the blue "Bluetooth" icon.
Tool​
  • Mesh Detector: Displays detected active nodes
  • Signal Scanner: Displays RSSI and SNR of the selected node
  • Trace Route: Displays the routing path of the selected node
  • Statistic: Displays packet decoding information
  • Packet Log: Show device log
MUI Device Requirement​
MUI is designed to run on hardware that supports Meshtastic and provides a graphical display. To use all MUI features, including offline maps, your device should meet the following requirements.
ComponentRequirement
DisplayColor display with touch support
GNSSBuilt-in GNSS receiver for location services
LoRa®Compatible LoRa® radio for Meshtastic communication
StoragemicroSD card slot for offline maps
MCUA high-performance MCU is required, capable of supporting both screen display and Meshtastic firmware
Seeed Wio Tracker L2 is the recommended hardware platform for MUI.
It integrates all required components in a single device:
  • Color touchscreen
  • Built-in GNSS
  • LoRa® communication
  • Wi-Fi and Bluetooth® connectivity
  • microSD card slot for offline maps
  • USB Type-C for programming and power
No additional expansion boards are required.
FAQ​
How to activate keyboard​
Click the keyboard icon shown as below.
Then you can enter numbers and letters. Not every page has a keyboard icon; it usually appears only on pages where input is required.
Why my wifi automatically turned off​
When you enter Bluetooth pairing mode, the device wifi will be automatically set to be disabled. You can enable wifi in the phone app wdevice is in Bluetooth mode.
How to send mqtt message in MUI​
Device can not transmit mqtt message when it is in MUI. If you want to transmit mqtt message, please:
Step1. Enter Bluetooth pairing mode
Step2. Pair your device with phone APP
Step3. Configure mqtt in phone APP
Step4. Start message transmission
