Complete Guide to Bimanual SO-ARM Training
Introduction​
This guide walks through the complete pipeline for training a bimanual SO-ARM robotic system with LeRobot. It covers hardware setup, arm calibration, bimanual teleoperation, dataset recording and management, ACT policy training, and real-robot deployment. By following these steps, you can collect demonstration data with two leader arms and two follower arms, train an imitation-learning policy, and deploy it on the real robot.
First, connect the wires as follows.
RolePort
Left follower arm/dev/ttyACM0
Right follower arm/dev/ttyACM1
Left leader arm/dev/ttyACM2
Right leader arm/dev/ttyACM3
The follower arm type is so101_follower, and the leader arm type is so101_leader (in LeRobot, so100_leader and so101_leader share the same implementation).
Bimanual Collaboration Demo Video:
0. Prerequisites​
0.1 Install Dependencies​
For environment setup, please refer to the SO-ARM tutorial:
0.2 USB Permissions​
sudo chmod 666 /dev/ttyACM0 /dev/ttyACM1 /dev/ttyACM2 /dev/ttyACM3
1. Calibration (Key Step)​
1.1 Calibrate the Left Follower Arm​
lerobot-calibrate \
--robot.type=so101_follower \
--robot.port=/dev/ttyACM0 \
--robot.id=my_awesome_bimanual_follower_left
1.2 Calibrate the Right Follower Arm​
lerobot-calibrate \
--robot.port=/dev/ttyACM1 \
--robot.id=my_awesome_bimanual_follower_right
1.3 Calibrate the Left Leader Arm​
lerobot-calibrate \
--teleop.type=so101_leader \
--teleop.port=/dev/ttyACM2 \
--teleop.id=my_awesome_bimanual_leader_left
1.4 Calibrate the Right Leader Arm​
lerobot-calibrate \
--teleop.port=/dev/ttyACM3 \
--teleop.id=my_awesome_bimanual_leader_right
After calibration, the files will be saved at:
~/.cache/huggingface/lerobot/calibration/robots/so101_follower/my_awesome_bimanual_follower_left.json
~/.cache/huggingface/lerobot/calibration/robots/so101_follower/my_awesome_bimanual_follower_right.json
~/.cache/huggingface/lerobot/calibration/robots/so101_leader/my_awesome_bimanual_leader_left.json
~/.cache/huggingface/lerobot/calibration/robots/so101_leader/my_awesome_bimanual_leader_right.json
(Optional) If You Have Previously Calibrated with Other IDs​
For example, if you previously used my_awesome_follower_arm1, my_awesome_follower_arm2, etc., you can copy the calibration files:
CAL_DIR=~/.cache/huggingface/lerobot/calibration/robots
cp $CAL_DIR/so101_follower/my_awesome_follower_arm1.json \
$CAL_DIR/so101_follower/my_awesome_bimanual_follower_left.json
cp $CAL_DIR/so101_follower/my_awesome_follower_arm2.json \
$CAL_DIR/so101_follower/my_awesome_bimanual_follower_right.json
cp $CAL_DIR/so101_leader/my_awesome_leader_arm3.json \
$CAL_DIR/so101_leader/my_awesome_bimanual_leader_left.json
cp $CAL_DIR/so101_leader/my_awesome_leader_arm4.json \
$CAL_DIR/so101_leader/my_awesome_bimanual_leader_right.json
2. Bimanual Teleoperation​
2.1 Without Camera​
lerobot-teleoperate \
--robot.type=bi_so_follower \
--robot.left_arm_config.port=/dev/ttyACM0 \
--robot.right_arm_config.port=/dev/ttyACM1 \
--robot.id=my_awesome_bimanual_follower \
--teleop.type=bi_so_leader \
--teleop.left_arm_config.port=/dev/ttyACM2 \
--teleop.right_arm_config.port=/dev/ttyACM3 \
--teleop.id=my_awesome_bimanual_leader \
--display_data=true
2.2 With Camera​
You can use lerobot-find-cameras opencv to view camera indexes, and you can add or remove cameras as needed.
--robot.left_arm_config.cameras='{
left_wrist: {"type": "opencv", "index_or_path": 2, "width": 640, "height": 480, "fps": 30}
--robot.right_arm_config.cameras='{
right_wrist: {"type": "opencv", "index_or_path": 4, "width": 640, "height": 480, "fps": 30}
--display_data=true
Safety Tips​
  • Be aware of the surroundings to avoid collisions of the follower arms.
3. Record Dataset​
3.1 Save Locally (Do Not Upload to Hub)​
Add --dataset.root and --dataset.push_to_hub=false.
Note: repo_id must contain /. For local datasets, you can use local/ as a placeholder prefix; it will not actually upload.
lerobot-record \
--dataset.repo_id=seeed/bimanual_so101_task \
--dataset.push_to_hub=false \
--dataset.single_task="Pick the cube with left arm and hand it to right arm" \
--dataset.num_episodes=50 \
--dataset.fps=30 \
--dataset.episode_time_s=30 \
--dataset.reset_time_s=10 \
--dataset.video=true \
--dataset.vcodec=libsvtav1 \
--display_data=true
Data will be saved to ~/.cache/huggingface/lerobot/seeed/bimanual_so101_task/, structured as follows:
├── meta/
│ ├── info.json
│ ├── episodes/
│ ├── stats/
│ └── tasks/
├── data/
└── videos/
3.2 Upload to Hugging Face Hub​
If you want to upload automatically, keep HF_USER and remove root and push_to_hub=false:
export HF_USER=your_hf_username
lerobot-record \
--robot.left_arm_config.port=/dev/ttyACM1 \
--robot.right_arm_config.port=/dev/ttyACM2 \
left_wrist: {"type": "opencv", "index_or_path": 0, "width": 640, "height": 480, "fps": 30}
right_wrist: {"type": "opencv", "index_or_path": 1, "width": 640, "height": 480, "fps": 30}
--teleop.left_arm_config.port=/dev/ttyACM3 \
--teleop.right_arm_config.port=/dev/ttyACM4 \
--dataset.repo_id=${HF_USER}/bimanual_so101_task \
--dataset.fps=30 \
--display_data=true
3.3 Continue Recording (Resume)​
If the recording exits unexpectedly (for example, pressing the right button to exit during the reset phase), or if you want to complete the collection in multiple sessions, you can use --resume to continue appending episodes to the same dataset.
Notes:
  • You must add --resume=true; otherwise LeRobotDataset.create() will report an error because the directory already exists.
  • --dataset.num_episodes refers to how many episodes to record this time, not the total target. For example, if 15 episodes have already been recorded and you want to reach 50, set it to 35.
  • Try to exit during an episode recording or after a natural end; avoid exiting during the "Reset the environment" phase (which may cause empty episode save failures).
lerobot-record \
--resume=true \
--dataset.num_episodes=35 \
--dataset.fps=30 \
--display_data=true
3.4 Replay and Delete Episodes​
Replay a Specific Episode​
lerobot-replay \
--dataset.episode=24
episode is a 0-based index, so 24 means the 25th episode.
Delete a Specific Episode​
python -m lerobot.scripts.lerobot_edit_dataset \
--repo_id=seeed/bimanual_so101_task \
--operation.type=delete_episodes \
--operation.episode_indices="[24]"
After deletion, the dataset will be rewritten in place, and the original data will be backed up to ~/.cache/huggingface/lerobot/seeed/bimanual_so101_task_old/. After confirming the new dataset is correct, you can manually delete the backup:
rm -rf ~/.cache/huggingface/lerobot/seeed/bimanual_so101_task_old
Delete the Entire Dataset​
4. ACT Training​
4.1 Train from Local Dataset​
lerobot-train \
--policy.type=act \
--policy.device=cuda \
--steps=60000 \
--output_dir=outputs/train/act_bimanual_so101 \
--wandb.enable=false \
--policy.push_to_hub=false
4.2 Train from Hugging Face Hub​
lerobot-train \
--policy.type=act \
--steps=100000 \
The above uses ACT's default parameters (chunk_size=100, dim_model=512, etc.).
5. Real-Robot Deployment​
5.1 Save Evaluation Data Locally​
lerobot-record \
--dataset.root=seeed_eval/eval_bimanual_so101_task8 \
--dataset.num_episodes=10 \
--dataset.fps=30 \
--policy.path=outputs/train/act_bimanual_so101/checkpoints/last/pretrained_model \
--display_data=true
5.2 Upload to Hugging Face Hub​
lerobot-record \
--dataset.repo_id=${HF_USER}/eval_bimanual_so101_task \
--dataset.fps=30 \
--display_data=true
6. FAQ​
ProblemCauseSolution
Teleoperation prompts to recalibratebi_so_follower cannot find calibration files with _left / _right suffixRecalibrate with IDs containing_left / _right, or copy existing calibration files
Leader arm cannot be moved by handLeader torque is not disabledRecalibrate or check the motors
"Directory already exists" when continuing recording--resume=true was not addedAdd--resume=true to the lerobot-record command
Left and right arms are swappedPort configuration errorSwapleft_arm_config.port and right_arm_config.port
Dataset not found during trainingroot was not specified for the local datasetAdd--dataset.root=./datasets/xxx during training
Dataset is uploaded automaticallypush_to_hub=false was not setAdd--dataset.push_to_hub=false during recording
Exits withYou must add one or several frames before calling add_episodeExited during the reset phase, the current episode has no framesDoes not affect already recorded data; continue recording with--resume=true; the current code has fixed this scenario and empty episodes will be automatically skipped
