Deploy YOLOv5 object detection model
This wiki will introduce how to train the official YOLOv5 target detection model and deploy the trained model to Grove Vision AI(V2) or XIAO ESP32S3 devices.
Dataset preparation
It is recommended to use the roboflow platform for data sets. This platform can perform data set annotation and some data enhancement strategies, and supports the export of multiple data set formats. You can view the yolov5 data set preparation Introduction
Clone YOLOv5 official repository
- By default, you already have the python environment and pip package management tool and python>=3.8.
# Clone YOLOv5 official repository
git clone https://github.com/ultralytics/yolov5
- Install the required environment
# Cut to the YOLOv5 folder
cd yolov5
# Use pip to install required dependencies
Train
- Execute the following command to start training the model
python train.py --weights yolov5n.pt --data ${dataset yaml file path} --imgsz 192
Export model to tflite
- After training, the model will be in the
runs/train/exp*/weights/folder. Make sure that the evaluation indicators of your model meet your needs. - First export the saved_model format model using the following command
python export.py --weights ${Your trained model path (.pt format)} --imgsz 192 --include saved_model
- Then use the following code to quantify and convert the exported saved_model model into tflite model format
import tensorflow as tf
import os.path as osp
converter = tf.lite.TFLiteConverter.from_saved_model(r'Your saved_model folder path')
tflite_model = converter.convert()
def representative_dataset():
for _ in range(100):
yield [
tf.random.uniform((1, 192, 192
, 3))
converter.optimizations = [
tf.lite.Optimize.DEFAULT
converter.target_spec.supported_ops = [
tf.lite.OpsSet.TFLITE_BUILTINS_INT8
converter.inference_input_type = tf.int8
converter.inference_output_type = tf.int8
converter.representative_dataset = representative_dataset
tflite_quant_model = converter.convert()
with open(osp.join(r'The location path to be saved','yolov5n_int8.tflite'), 'wb') as f:
f.write(tflite_quant_model)
- Afterwards, you will see a
yolov5n_int8.tflitemodel file under the save path folder of the club,This model file can be deployed toGrove Vision AI(V2)orXIAO ESP32S3devices..
Model graph optimization
- Grove Vision AI (V2) supports vela-optimized models and can also accelerate model inference. First, execute the following command to install the vela command line tool (
XIAO ESP32S3device is not supported yet).
pip3 install ethos-u-vela
- After that, you need to download
velarelated configuration file, or copy the following content into a file, which can be namedvela_config.ini
; file: my_vela_cfg.ini ; -----------------------------------------------------------------------------
; Vela configuration file ; -----------------------------------------------------------------------------
; System Configuration
; My_Sys_Cfg
[System_Config.My_Sys_Cfg]
core_clock=400e6
axi0_port=Sram
axi1_port=OffChipFlash
Sram_clock_scale=1.0
Sram_burst_length=32
Sram_read_latency=16
Sram_write_latency=16
Dram_clock_scale=0.75
Dram_burst_length=128
Dram_read_latency=500
Dram_write_latency=250
OnChipFlash_clock_scale=0.25
OffChipFlash_clock_scale=0.015625
OffChipFlash_burst_length=32
OffChipFlash_read_latency=64
OffChipFlash_write_latency=64
; Memory Mode
; My_Mem_Mode_Parent
[Memory_Mode.My_Mem_Mode_Parent]
const_mem_area=Axi1
arena_mem_area=Axi0
cache_mem_area=Axi0
- Finally, use the following command to optimize the graph
vela --accelerator-config ethos-u55-64 \
--config vela_config.ini \
--system-config My_Sys_Cfg \
--memory-mode My_Mem_Mode_Parent \
--output-dir ${Save path of the optimized model} \
${The path of the tflite model that needs to be optimized}
Deploy
The model file that needs to be deployed is the
tflitefile exported above. You can burn the model file to the target device according to the following tutorial. -
We strongly recommend using our web tool to burn the trained tflite model into the device. Detailed operations are provided in the Deployment Tutorial
Note: Since the ESP32S3 device does not support model deployment after vela graph optimization, you do not need to perform tflite model graph optimization if you want to deploy the model to the XIAO ESP32S3 device.
