Make DIY BSP from Orin Nano DevKit to reComputer Classic
This wiki shows how to clone a full development environment from an NVIDIA Jetson Orin Nano Developer Kit, build a Hybrid BSP that can be flashed to Seeed reComputer Classic (J4011/J4012, board config recomputer-orin-j401), and complete the flash.
It extends the same-carrier DIY BSP flow. If your source and target are both Seeed boards, use Creating a Custom BSP Package from Jetson Development Environment instead.
Related docs:
- Creating a Custom BSP Package from Jetson Development Environment
- Migrate /home Data from Jetson Orin Nano Developer Kit to reComputer
- Flash JetPack to a Selected Product
This guide uses JetPack 6.2 / L4T 36.4.3 as an example (module SKU 0005 = Orin Nano 8GB).
What You Are Building
| Goal | Artifact | Purpose |
| A. Same-carrier clone | mfi_jetson-orin-nano-devkit-nvme.tar.gz | Reflash DevKit with a full environment clone |
| B. Classic Bundle | mfi_recomputer-orin-j401.tar.gz | Flash Classic J4011: J401 board-level QSPI + DevKit full APP (including /home) |
| C. Safe fallback | Official J401 BSP + migrate /home only | Use when Hybrid results are abnormal |
Do not flash the DevKit mfi_jetson-orin-nano-devkit-nvme package directly onto Classic.
Do not treat editing a single .dtb inside the mfi directory as board adaptation.
Prerequisites
Hardware
- Source: Orin Nano Developer Kit (this example uses module SKU 0005 = Orin Nano 8GB, NVMe boot)
- Target: Seeed reComputer Classic J4011/J4012 (J401 carrier; module should ideally also be 0005)
- Host: Ubuntu 22.04 x86_64, USB Type-C cable (flash port)
- Disk: reserve ≥ 100GB free space (backup + dual mfi + snapshots)
Host Dependencies
sudo apt-get update -y
sudo apt-get install -y \
build-essential flex bison libssl-dev \
sshpass abootimg nfs-kernel-server \
libxml2-utils qemu-user-static
Before backup/flash:
sudo systemctl stop udisks2.service
sudo service nfs-kernel-server start
lsusb | grep 0955:7523 # must show NVIDIA Corp. APX
Board Comparison (This Example)
| Item | DevKit | Classic J4011 |
| board-name | jetson-orin-nano-devkit-nvme | recomputer-orin-j401 |
| Config file | p3768-0000-p3767-0000-a0-nvme.conf | recomputer-orin-j401.conf |
| Pinmux | ...-dp-a03 (DP) | ...-hdmi-a03 (HDMI) |
| Overlay | DevKit dynamic, etc. | tegra234-dcb-p3767-0000-hdmi.dtbo + tegra234-p3767-camera-p3768-imx219-dual-seeed.dtbo |
| SKU0005 main DTB | ...-0005-nv(-super).dtb | Still uses tegra234-p3768-0000+p3767-0005-nv-super.dtb |
Example backup board_spec:
3767-300-0005-V.2-1-1-jetson-orin-nano-devkit-nvme-
The reComputer Classic series has insufficient cooling to support MAXN Super mode. If you flash JetPack 6.2 onto a Classic device, do not enable MAXN.
1. Prepare the Linux_for_Tegra Workspace
Download the Seeed L4T working package from the table in Creating a Custom BSP Package from Jetson Development Environment (JetPack 6.2 / L4T 36.4.3 plus in this example).
sudo tar xpf L4T_36.4.3_plus.tar.gz
# Adjust the archive name to match your download
cd Linux_for_Tegra/
sudo ./apply_binaries.sh
cd ..
export ARCH=arm64
export CROSS_COMPILE="$PWD/aarch64--glibc--stable-2022.08-1/bin/aarch64-buildroot-linux-gnu-"
export PATH="$PWD/aarch64--glibc--stable-2022.08-1/bin:$PATH"
export INSTALL_MOD_PATH="$PWD/Linux_for_Tegra/rootfs/"
cd Linux_for_Tegra/source
./nvbuild.sh
./do_copy.sh
./nvbuild.sh -i
Verification:
test -f Linux_for_Tegra/recomputer-orin-j401.conf
test -f Linux_for_Tegra/jetson-orin-nano-devkit-nvme.conf
ls Linux_for_Tegra/kernel/dtb/tegra234-j401-*-recomputer.dtb
ls Linux_for_Tegra/kernel/dtb/tegra234-dcb-p3767-0000-hdmi.dtbo
2. Back Up the Full DevKit Environment
2.1 Put the Source Device in Recovery Mode
Connect the DevKit flash port to the host with a USB Type-C data cable and enter Recovery mode. On the host, lsusb should show 0955:7523 APX.
For Recovery mode steps, see: Flash JetPack to a Selected Product
During backup the device may briefly switch to 0955:7035 (Linux for Tegra / initrd). That is normal.
2.2 Backup Command
cd Linux_for_Tegra
sudo ./tools/backup_restore/l4t_backup_restore.sh \
-e nvme0n1 -b -c jetson-orin-nano-devkit-nvme
Do not use recomputer-orin-j401 for the first backup when the source is a DevKit. That will corrupt board_spec and later baselines.
2.3 Verification
ls -lah tools/backup_restore/images/
head -5 tools/backup_restore/images/nvpartitionmap.txt
You should see:
board_speccontainsjetson-orin-nano-devkit-nvmenvme0n1p1.tar.zst(or the later converted large APP) is GB-scaleQSPI0.imgexists (this is DevKit QSPI; Hybrid must not reuse it as Classic QSPI)
Recommended: snapshot immediately:
sudo cp -a tools/backup_restore/images ~/backup_images_dk_sku0005
3. Build DevKit Same-Carrier DIY BSP (Optional)
Put the device back into APX. On the host, lsusb should show 0955:7523 APX:
cd Linux_for_Tegra
sudo ./tools/kernel_flash/l4t_initrd_flash.sh \
--use-backup-image --no-flash --network usb0 --massflash 5 \
jetson-orin-nano-devkit-nvme internal
Artifacts:
mfi_jetson-orin-nano-devkit-nvme/mfi_jetson-orin-nano-devkit-nvme.tar.gz
For DevKit reflash only. Do not flash Classic with this package.
4. Required Reading: The QSPI Trap
With --use-backup-image, convert_backup_image_to_initrd_flash places:
| Backup content | Destination |
| NVMe / APP | tools/kernel_flash/images/external/ |
Source QSPI0.img | tools/kernel_flash/images/internal/ |
Therefore:
| Wrong approach | Result |
Only edit mfi/.../rootfs or one .dtb | Ineffective (what actually flashes is bak / QSPI) |
DevKit backup, then directly recomputer-orin-j401 + --use-backup-image | Still flashes DevKit QSPI (DP pinmux); HDMI/USB may be wrong |
Change conf, then --flash-only | --flash-only does not rebuild images from conf |
What really differs on Classic J4011 is HDMI pinmux + DCB/camera overlay in recomputer-orin-j401.conf:
PINMUX_CONFIG="tegra234-mb1-bct-pinmux-p3767-hdmi-a03.dtsi"
PMC_CONFIG="tegra234-mb1-bct-padvoltage-p3767-hdmi-a03.dtsi"
OVERLAY_DTB_FILE+=",tegra234-dcb-p3767-0000-hdmi.dtbo,tegra234-p3767-camera-p3768-imx219-dual-seeed.dtbo"
DCE_OVERLAY_DTB_FILE="tegra234-dcb-p3767-0000-hdmi.dtbo"
For SKU 0005, the main DTB filename is still NVIDIA’s *-0005-nv-super.dtb. Do not force-switch to *-0000-recomputer.dtb (that path is for NX 16GB).
5. Hybrid B': Build the Classic J4011 Bundle
Core idea:
- APP: keep using the DevKit backup (full user environment)
- QSPI: regenerate with
recomputer-orin-j401(without--use-backup-image) - Assemble into
DevKit backup APP ──► external/ (nvme0n1p1_bak.img, etc.)
J401 conf new QSPI ──► internal/ (QSPI shards, not DevKit monolithic QSPI0.img)
└──► mfi_recomputer-orin-j401(.tar.gz)
5.1 Prepare APP-only (Remove DevKit QSPI)
cd Linux_for_Tegra
sudo cp -a ~/backup_images_dk_sku0005 \
tools/backup_restore/images_app_only
sudo rm -f tools/backup_restore/images_app_only/QSPI0.img
sudo sed -i '/qspi/Id' tools/backup_restore/images_app_only/nvpartitionmap.txt
Convert APP-only into initrd flash external images (use the backup tool’s convert step, or reuse the large APP already under tools/kernel_flash/images/external/ from the DevKit mfi pack step).
5.2 Regenerate QSPI with J401 conf
Device must be in APX. Module parameters should match the backup (this example: 3767 / 0005 / 300 / V.2):
cd Linux_for_Tegra
sudo BOARDID=3767 BOARDSKU=0005 FAB=300 BOARDREV=V.2 CHIP_SKU=00:00:00:D5 \
--external-device nvme0n1p1 \
-c tools/kernel_flash/flash_l4t_t234_nvme.xml \
-p "-c bootloader/generic/cfg/flash_t234_qspi.xml --no-systemimg" \
--no-flash --massflash 5 --showlogs --network usb0 \
recomputer-orin-j401 internal
Logs should show HDMI pinmux, e.g. tegra234-mb1-bct-pinmux-p3767-hdmi-a03.
Recommended: save the new QSPI internal:
sudo cp -a tools/kernel_flash/images/internal ~/j401_qspi_internal_save
5.3 Assemble mfi
The final directory should satisfy:
| Path | Content |
mfi_recomputer-orin-j401/recomputer-orin-j401.conf | Present |
.../tools/kernel_flash/images/internal/ | New J401 QSPI (no DevKit monolithic QSPI0.img, or hash differs from DevKit; flash.idx is often multi-line shards) |
.../tools/kernel_flash/images/external/nvme0n1p1_bak.img | GB-scale APP |
Optional archive:
cd Linux_for_Tegra
sudo tar czf mfi_recomputer-orin-j401.tar.gz mfi_recomputer-orin-j401
6. Flash to Classic J4011
6.1 Put Target in APX
lsusb → 0955:7523 NVIDIA Corp. APX
6.2 Flash Command
If the extracted directory already exists locally, do not run tar xpf again:
cd Linux_for_Tegra/mfi_recomputer-orin-j401
--flash-only --massflash 1 --network usb0 --showlogs
Only when another PC has only the .tar.gz:
sudo tar xpf mfi_recomputer-orin-j401.tar.gz
cd mfi_recomputer-orin-j401
6.3 Normal Messages During Flash
| Log | Meaning |
p3768-0000-p3767-0000-a0.conf: No such file or directory | Common with --flash-only; images are prebuilt, continue |
rpcbind already running | Safe to ignore |
blockdev: cannot open /dev/mmcblk0boot0 | Orin Nano has no such partition; usually harmless |
RCM-boot + SSH ready | Normal flash entry |
DTB ...-0005-nv-super.dtb | Correct for SKU0005 |
Multiple internal lines + Starting to flash to qspi | Flashing J401 QSPI |
tar ... zstd ... nvme0n1p1_bak.img | Restoring APP (longest step; may take tens of minutes) |
Do not power off or unplug until you see a successful completion message.
6.4 Post-Flash Checks (On Classic)
cat /proc/device-tree/model
ls /boot/kernel_tegra234*.dtb
ls /boot/*.dtbo | grep -E 'hdmi|imx219-dual-seeed' || true
# Whether peripherals actually work (more important than model / dtbo filenames)
xrandr 2>/dev/null | head -20
lsusb | head
ip -br link
ls /boot/*.dtbo 2>/dev/null | head -40
sudo dmesg | grep -iE 'dtb|overlay|hdmi|tegra234' | tail -30
# Whether the original DevKit user environment survived (CUDA example)
nvcc --version
Without sudo, dmesg may report Operation not permitted. That is a permissions issue; use sudo.
On device: model / DTB
On device: CUDA installed on the original DevKit still works
How to Interpret Results (SKU 0005)
1) /proc/device-tree/model still shows DevKit — normal for SKU 0005
Example:
NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super
Reason: for SKU 0005, recomputer-orin-j401.conf selects NVIDIA’s tegra234-p3768-0000+p3767-0005-nv-super.dtb. It does not switch to tegra234-j401-*-recomputer.dtb, so the model string still looks like the official DevKit. Do not conclude “flashed the wrong DevKit bundle” from this line alone.
2) DTB filenames under /boot
Commonly visible:
/boot/kernel_tegra234-p3768-0000+p3767-0000-nv.dtb
/boot/kernel_tegra234-p3768-0000+p3767-0005-nv.dtb
You may not see a *-0005-nv-super.dtb filename; the actual boot DTB is often chosen by UEFI/QSPI. The /boot listing is reference only.
3) Empty grep hdmi|imx219-dual-seeed — not a failure by itself
After Hybrid flash, /boot/*.dtbo often still contains the generic overlay list from the DevKit backup. You may not see tegra234-dcb-p3767-0000-hdmi.dtbo or ...-imx219-dual-seeed.dtbo. Seeed HDMI/camera settings mostly take effect through the new J401 QSPI / UEFI overlay path.
4) Judge by “does it work?”
| Check | Healthy example |
| USB | Hubs, mouse, Bluetooth, USB Ethernet enumerated (lsusb shows multiple devices) |
| Wired Ethernet | enP8p1s0 etc. are UP |
| Wi‑Fi | wlP1p1s0 is UP |
| Display | Desktop works; or xrandr has output |
| User environment | Original DevKit users, software, and data remain |
| CUDA | nvcc --version works (this example 12.6), indicating APP clone is intact |
When to Edit extlinux.conf
Only if HDMI / USB / boot is abnormal, try adding under LABEL primary in /boot/extlinux/extlinux.conf:
FDT /boot/kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb
(If that file is missing under /boot, try ...-0005-nv.dtb, or copy from BSP kernel/dtb/ first.)
sudo reboot
If still abnormal, use Section 7 Plan A (official J401 BSP + migrate /home).
7. Plan A Fallback (Official Path)
If Hybrid flash leaves partitions/UEFI/peripherals abnormal:
- Flash the official
recomputer-orin-j401BSP per Seeed’s flow (do not flash the DevKit mfi). - Extract
/homefrom backup (nvme0n1p1.tar.zst) or follow Migrate /home Data from Jetson Orin Nano Developer Kit to reComputer. - Restore
/homeon Classic, then reinstall system-level software as needed (/usr,/etc, Docker, etc. need separate handling).
Pros: cleanest board firmware. Cons: not a full / disk clone.
8. Key Paths Quick Reference
| Type | Path (under Linux_for_Tegra/) |
| DK mfi | mfi_jetson-orin-nano-devkit-nvme.tar.gz |
| Classic Bundle mfi | mfi_recomputer-orin-j401.tar.gz |
| J401 conf | recomputer-orin-j401.conf |
| HDMI DCB | kernel/dtb/tegra234-dcb-p3767-0000-hdmi.dtbo |
| Seeed dual IMX219 | kernel/dtb/tegra234-p3767-camera-p3768-imx219-dual-seeed.dtbo |
| J401 DTB | kernel/dtb/tegra234-j401-p3768-0000+p3767-*-recomputer.dtb |
| SKU0005 DTB | kernel/dtb/tegra234-p3768-0000+p3767-0005-nv-super.dtb |
9. Flow Overview
[Host] Extract L4T + apply_binaries + nvbuild
[DevKit APX] backup -c jetson-orin-nano-devkit-nvme
├─► (optional) --use-backup-image → mfi_jetson-orin-nano-devkit-nvme
├─► snapshot backup_images_dk_sku0005
│ ├─ APP-only (remove QSPI)
│ └─► external APP
└─► [APX] J401 without --use-backup-image → generate QSPI
assemble mfi_recomputer-orin-j401
[Classic APX] --flash-only
check display/USB/NVMe/user environment
10. FAQ
Q: Both the directory and .tar.gz exist—do I still need to extract?
A: No. If mfi_recomputer-orin-j401/ exists, cd into it and run --flash-only.
Q: Target Classic module is not 0005?
A: Change BOARDSKU, pick the matching DTB per p3767_super_overlay in recomputer-orin-j401.conf, then regenerate QSPI.
Q: I only want to keep /home, not clone the whole disk?
A: Use Plan A (Section 7). It is simpler and more reliable.
Q: Why does the DIY BSP wiki example use recomputer-orin-j401?
A: That example assumes source and target are both Seeed boards. When the source is an official DevKit, backup must first use jetson-orin-nano-devkit-nvme, then follow this Hybrid Classic adaptation tutorial.
