Wio Tracker L2 Introduction
The Wio Tracker L2 Series is a highly extensible Meshtastic® node featuring LoRa (862–930 MHz), the ESP32S3 for efficient processing, and an L76K GPS module for accurate location tracking. Designed for flexibility, it supports QSPI touch screen, E-Ink displays, TF Card, as well as solar panels and battery power, making it ideal for a wide range of IoT and off-grid applications.
- One Hardware, Endless Possibilities Build your own interface, dashboard, game, map tool, or interactive experience—L2 Pro is ready for whatever you want to make.
- 3.2'' High-Quality Touchscreen: Featuring a 320×240 high-clarity display with switchable MUI and Base UI, it delivers smooth on-device interaction for messaging, mapping, and control—without a mobile phone.
- ESP32S3 Powered, Ready to Build On: Powered by the dual-core ESP32-S3 with Wi-Fi and Bluetooth LE, L2 Pro provides a flexible platform for UI customization, feature development, and open-source applications.
- Offline Maps with GNSS Positioning: Pre-download offline maps to a MicroSD card and view your real-time GNSS location directly on the device, even without cellular coverage or Internet access.
- 3000mAh Long-Lasting Battery: Supports extended daily use with reduced charging frequency; operates within -10°C to 55°C conditions.
- Easy to Carry, Flexible Placement: A foldable antenna improves portability, and the 1/4" mounting interface supports flexible placement with compatible accessories.
- Prototype Faster with CodeCraft
Describe your idea in a few words, and Seeed Studio’s CodeCraft AI coding assistant will generate a first draft of the code in minutes. Review it, flash it to your Wio Tracker L2, and test it on the board.
L2 Series Model
The Wio Tracker L2 Series includes Wio Tracker L2 for custom builds and Wio Tracker L2 Pro with an enclosure and built-in battery.
| Product Name | Wio Tracker L2 | Wio Tracker L2 Pro |
| Image |
| Purchase Link | Coming Soon | |
| Processor | ESP32-S3 | ESP32-S3 |
| LoRa | SX1262 | SX1262 |
| GPS | ✅ | ✅ |
| Screen | ✅ | ✅ |
| MicroSD Card Slot | ✅ | ✅ |
| Solar Input | ✅ | ✅ |
| Battery | External Li-ion battery via connector | Built-in 3000mAh battery |
| Shell | — | ✅ |
| Item | Parameter |
| Processor | Wio-S3 (ESP32S3 + SX1262 Module) |
| LoRa | 863-928 MHz MAX TX Power: 22dBm@US915,14dBm@EU868 |
| GNSS | L76K (GPS, BeiDou, GLONASS, QZSS) |
| On-chip Memory | 16MB Flash / 8MB PSRAM |
| Antenna | LoRa: |
| Wifi/BLE 5.0: FPC antenna | |
| GPS: ceramic antenna | |
| Interface | Grove *1: |
| MicroSD Card Slot | |
| Quarter-inch threaded hole | |
| QSPI Interface | Compatible for IPS Screen & E-INK Screen |
| Power Input | USB Type-C: 5V⎓1.5A |
| Solar:JST-PH 2P-2.0mm, 5V ~ 13V | |
| Li-ion Battery (2P-1.25mm): 3.7V | |
| IPS Touch Screen | Size: 3.2 inch |
| Resolution: 240 × 320 pixels | |
| LED | Mesh LED * 1 Charging LED * 1 |
| Button | WAKE-UP * 1 User/Boot * 1 RST * 1 Power Switch * 1 |
| Audio | I2S Codec |
| MIC | |
| Speaker: 6Ω 0.8W | |
| Communication Distance | Up to 5.8 km |
| Dimension | (Antenna folded) L: 87.5 mm, W: 69 mm, H: 26.6 mm |
| Device Weight | 171.5g |
| Operation Temperature | -10℃ to +55℃ |
| Certification | FCC,CE,RoHS,Telec |
Battery
| Item | Parameter |
| Battery Capacity | Rechargeable Li-ion battery, 3000mAh |
| Battery Life Monitoring | Periodic uplink battery level |
| Charging Protocol | USB Type-C |
| Device Power Input | 5V, 1A |
| Fully-charged cut-off voltage | 4.2V |
| Charging Temperature Limit | 0 to +45℃ |
Power Consumption
For detailed power consumption data and estimated battery life under different configurations (screen mode, LoRa frequency band and modem preset, GPS usage, etc.), please refer to the Wio Tracker L2 Power Consumption Table.
Pin List
| Component | Pin | Pin No. | Protocol |
| Display | QSPI_CLK | GPIO42 | QSPI |
| QSPI_DAT0 | GPIO41 | ||
| QSPI_DAT1 | GPIO40 | ||
| QSPI_DAT2 | GPIO39 | ||
| QSPI_DAT3 | GPIO38 | ||
| QSPI_CS | GPIO46 | ||
| LCD_EN | EXP_P05 | GPIO | |
| QSPLRST | EXP_P06 | ||
| QSPLTE | NC | NC | |
| E-INK | E_INK_SCK | GPIO42 | SPI |
| E_INK_MOSI | GPIO41 | ||
| E_INK_CS | GPIO40 | ||
| E_INK_DC | GPIO39 | GPIO | |
| E_INK_BUSY | GPIO38 | ||
| IIC | IIC0_SCL | GPIO48 | IIC |
| IIC0_SDA | GPIO47 | ||
| LoRa | LoRa_CS | GPIO21 | SPI |
| LoRa_SCK | GPIO4 | ||
| LoRa_MISO | GPIO5 | ||
| LoRa_MOSI | GPIO6 | ||
| LoRa_RST | GPIO7 | GPIO | |
| LoRa_BUSY | GPIO8 | ||
| LoRa_DIO1 | GPIO9 | ||
| Grove | GROVE_DAT_1 | GPIO14 | GPIO |
| GROVE_DAT_2 | GPIO13 | ||
| GROVE_EN | EXP_P07 | ||
| GNSS | GNSS_RX | GPIO18 | UART |
| GNSS_TX | GPIO17 | ||
| GNSS_EN | EXP_P15 | GPIO | |
| GNSS_RST | EXP_P11 | ||
| I2S | CODEC_I2S0_MCLK | GPIO10 | I2S |
| CODEC_I2S0_LRCK | GPIO12 | ||
| CODEC_I2S0_SCLK | GPIO11 | ||
| CODEC_I2S0_DSDIN | GPIO16 | ||
| CODEC_I2S0_SDOUT | GPIO15 | ||
| SD | SD_CMD | GPIO03 | SD |
| SD_CLK | GPIO02 | ||
| SD_DAT0 | GPIO01 | ||
| SD_DET | EXP_P02 | GPIO | |
| USB | USB_N | GPIO19 | USB |
| USB_P | GPIO20 | ||
| LED | MESH LED | GPIO43 | GPIO |
| USER_LED | EXP_P12 | ||
| Button | WAKEUP_BUTTON | EXP_P00 | GPIO |
Hardware Overview
Wio Tracker L2 Pro
Schematic Diagram
