microbit wiki page
Micro:bit Introduction
Hello, here is the Micro:bit feature page, welcome. We are here to prepare a generous resource for Micro:bit. Includes Micro:bit accessories, Miro:bit kits, matching sensors, actuators. There are also a large variety of rich tutorials to help you with Micro:bit.
Product List
  1. Micro:bit
  2. Grove Shield for micro:bit v2.0
  3. Grove Inventor Kit for micro:bit
MakeCode tutorial
1.Play with OledDisplay
Please refer to the github page
2.Play with the Grove - ThumbJoystick
3.play with Grove - VoiceRecognizer
Micro Python tutorial
1.Play with Grove - ThumbJoystick
Play with Grove - ThumbJoystick(python)
2.Use microbit to control WS2812 LEDs
Please download the ppt file
Grove compatible with Micro:bit
Name and link
Way of Use
Grove - Speaker
107020001
Use the Pins block
Grove - Relay
103020005
Use the Pins block
Grove - Red LED
104030005
Use the Pins block
Grove - Button
101020003
Use the Pins block
Grove - Buzzer
107020000
Use the Pins block
Grove - Ultrasonic Ranger
101020010
Use MakeCode Package
Grove - Button
111020000
Use the Pins block
Grove - PIR Motion Sensor
101020020
Use the Pins block
Grove - Green LED
104030007
Use the Pins block
Grove - White LED
104030009
Use the Pins block
Grove - Switch(P)
101020004
Use the Pins block
Grove - Water Sensor
101020018
Use the Pins block
Grove - Blue LED
104030010
Use the Pins block
Grove - Vibration Motor
105020003
Use the Pins block
Grove - Touch Sensor
101020037
Use the Pins block
Grove - Magnetic Switch
101020038
Use the Pins block
Grove - 4-Digit Display
104030003
Grove - Tilt Switch
101020025
Use the Pins block
Grove - Multi Color Flash LED(5mm)
104030014
Use the Pins block
Grove - Line Finder v1.1
101020172
Use the Pins block
Grove - Dry-Reed Relay
103020014
Use the Pins block
Grove - Collision Sensor
101020005
Use the Pins block
Grove - Variable Color LED
101020005
Use the Pins block
Grove - Purple LED(3mm)
104020002
Use the Pins block
Grove - LED String Light
104020005
Use the Pins block
Grove - FM Receiver
107020005
Use the Pins block
Grove - EL Driver
105020005
Use the Pins block
Grove - Solid State Relay
103020004
Use the Pins block
Grove - Recorder v3.0
107020029
Use the Pins block
Grove - IR Distance Interrupter v1.2
101020175
Use the Pins block
101020040
Use the Pins block
Grove - Recorder
103020018
Use the Pins block
Grove - Temperature Sensor
101020015
Use the Pins block
Grove - Moisture Sensor
101020008
Use the Pins block
Grove - Loudness Sensor
101020063
Use the Pins block
Grove - Sound Sensor
101020023
Use the Pins block
Grove - Rotary Angle Sensor(P)
101020048
Use the Pins block
Grove - Piezo Vibration Sensor
101020031
Use the Pins block
Grove - Light Sensor v1.2
101020132
Use the Pins block
101020017
Use the Pins block
Grove - Slide Potentiometer
101020036
Use the Pins block
Grove - Luminance Sensor
101020076
Use the Pins block
Grove - Electricity Sensor
101020027
Use the Pins block
Grove - Light Sensor (P) v1.1
101020173
Use the Pins block
Grove - 80cm Infrared Proximity Sensor
101020042
Use the Pins block
Grove - Mini Fan v1.1
108020021
Use the Pins block
101020014
Use the Pins block
Grove - Mini Fan
101020083
Grove - Gesture
105020004
Use the Pins block
2017/11/9
Grove - Thumb Joystick
101020028
Grove - Speech Recognizer
101020232
Grove - OLED Display 1.12'' V2
101020452
Grove - Optical Rotary Encoder(TCUT1600X01)
101020587
Use the Pins block
Grove - Mech Keycap
111020049
Grove - 2-Channel Solid State Relay
103020134
Grove - 2-Channel SPDT Relay
103020132
Grove - Round Force Sensor (FSR402)
101020553
Grove - Blue LED Button
111020046
Grove - Yellow LED Button
111020045
Grove - Red LED Button
111020044
Grove - Digital Distance Interrupter 0.5 to 5cm(GP2Y0D805Z0F)(P)
101020578
101020533
2018/9/27
Grove - Vibration Sensor (SW-420)
101020586
Use the Pins block
2018/11/01
