mmWave Radar Sensor Introdution
Welcome to discover Seeed Studio's mmWave Radar Sensors. This page is designed to be a comprehensive source of information, guiding you through all aspects of these sensors.
Here, you can find details about product parameters, including operating frequencies, transmit power, motion and presence ranges, and detection angles. We also present straightforward installation methods such as top-mounting, side-mounting, and inclined installation. Additionally, we explore various application scenarios across automotive safety, smart home, and healthcare. Our mmWave Radar Sensors are suitable for a wide range of projects, providing you with reliable sensing solutions.
mmWave Radar Principle
Millimeter Wave (mmWave) radar uses Frequency Modulated Continuous Wave (FMCW) radar techniques to detect objects and their velocity, range, and angle. The FMCW radar continuously transmits a frequency-modulated signal and receives the reflected signals from objects. By analyzing the difference between the transmitted and received frequencies, the radar can determine the distance (range) and relative speed (velocity) of objects. This principle allows mmWave radar to detect fine movements, provide high accuracy, and function effectively in various environmental conditions such as rain, fog, or dust.
Schematic Diagram of Millimeter Wave Frequency Band, credit: EverythingRF
Different types of mmWave Radar Sensors
Millimeter-wave (mmWave) radar sensors are capable of detecting objects, measuring their distance, speed, and angle, and can penetrate various materials such as plastic, clothing, and drywall, making them suitable for a wide range of applications. In Seeed, We have leveraged the power of mmWave to come up with various sensors that can perform a variety of actions, such as fall detection and sleep breathing monitoring.
Our range of mmWave Radar Sensors are shown below, each with different features and functions.
| XIAO 60GHz mmWave Human Fall Detection Sensor MR60FDA2 | XIAO 60GHz mmWave Human Breathing and Heartbeat Sensor MR60BHA2 | 24Ghz mmwave Human Static Presence Sensor for XIAO | mmWave Human Detection Sensor Kit MR24HPC1 | 24GHz mmWave Human Static Presence Sensor Module MR24HPC1 Lite |
| XIAO 60GHz mmWave Human Fall Detection Sensor MR60FDA2 | XIAO 60GHz mmWave Human Breathing and Heartbeat Sensor MR60BHA2 | 24Ghz mmwave Human Static Presence Sensor for XIAO | mmWave Human Detection Sensor Kit MR24HPC1 | 24GHz mmWave Human Static Presence Sensor Module MR24HPC1 Lite | |
| Main Function | Fall Detection | Breathing and Heartbeat Detection | Human Detection | Human Detection | Human Detection |
| Operating Frequency | 60GHz | 60GHz | 24GHz | 24GHz | 24GHz |
| Transmit Power | / | / | / | 8dBm | 8dBm |
| Transmission and reception counts | Two transmissions and two receptions | Two transmissions and two receptions | One transmission and one reception | One transmission and one reception | One transmission and one reception |
| Motion Range | 6m | 6m | 6m | 5m | 5m |
| Presence Range | 3m | 1.5m | 4m | 4m | 4m |
| Detection Angle | 120x100° | 120x100° | 60×60° | 90×60° | 90×60° |
| Operating Voltage | 5V | 5V | 5V | 4.5-6V | 4.5-6V |
| Pins Spacing | 2.54mm | 2.54mm | 2.54mm | 2.00mm | 2.00mm |
| Size (WxH) | 30x48mm | 30x48mm | 22x18mm | 35x30mm | 35x30mm |
| Installation Method | Top installation | Side installation or inclined installation | No requirements | No requirements | No requirements |
| ESPHome Support | Native Firmware Support | Native Firmware Support | Guide | GitHub | GitHub |
| Category | Sensor with XIAO ESP32C6 as the MCU | Sensor with XIAO ESP32C6 as the MCU | Module, compatible with XIAO (pins to pins) | Sensor with XIAO ESP32C3 as the MCU | Module, compatible with XIAO, Arduino (via jumper wire) |
| Availability | $24.9 at Seeed Stduio | $24.9 at Seeed Stduio | $4.49 at Seeed Studio | $26.99 at Seeed Stduio | $6.9 at Seeed Studio |
Comparison of Different Parameters of mmWave Radars Sensors
Comparison of the Human Presence Detection Functions between mmWave Radar Sensors and Other Sensors
| mmWave Radars Sensor | Camera | Ultrasonic Sensor | LiDAR (Laser Radar) | Passive Infrared Sensor (PIR) | |
| Privacy | Non-visual detection, hidden signal frequency band, low risk of data leakage | Collects images containing a large amount of private information, prone to leakage | Does not involve the collection of private images, but the signal is easily detectable | The scanned data can expose scene information, with a risk of leakage | Does not involve the collection of private images, but the signal is easily detectable |
| Cost | Moderate | The cost varies based on resolution and functions, with some types being relatively high | Low cost | High cost of equipment and maintenance | Low cost |
| Precision | High precision, capable of accurately detecting the distance, speed and angle of the target | Greatly affected by lighting and resolution | Limited precision in short-distance detection | High-precision 3D imaging, but affected by the environment | Low detection precision, can only determine movement |
| Stability | Not affected by lighting and temperature, with stable performance | Restricted by lighting conditions, poor performance in low light | Easily affected by environmental noise | Greatly affected by adverse weather | Easily affected by environmental factors such as heat sources |
The comparison table highlights mmWave radar's advantages over cameras, ultrasonic sensors, LiDAR, and PIR sensors. It offers stable performance in diverse environments, making it effective for fall detection, respiratory and heart rate monitoring, and human presence detection. Additionally, mmWave radar protects privacy by not capturing identifiable images, ensuring user confidentiality.
Comparison of 24 GHz and 60 GHz
The 24 GHz and 60 GHz millimeter-wave radars differ significantly in their characteristics. The 24 GHz radar offers strong penetration and a longer detection range, making it effective for human presence detection, particularly in automotive radar systems. In contrast, the 60 GHz radar, with weaker penetration but higher angular resolution, is ideal for precise applications like fall detection and heart rate monitoring, commonly found in smart home devices. Ultimately, selecting the right frequency depends on specific application needs, including detection range and target characteristics.
| Supports Human Presence Detection | Comparison of the Effect of Human Presence Detection | |
| 24GHz mmWave for XIAO | ✅ | This product offers human presence detection and is ready to use out of the box, meeting basic needs. Users can quickly achieve a relatively stable detection effect |
| MR24HPC1 Lite | ✅ | This product features human presence detection, allowing users with hands-on skills to adjust underlying parameters for optimal performance in complex scenarios. However, its detection accuracy is slightly lower than that of the 24GHz mmWave for XIAO when operated directly |
| MR60FDA2 | ✅ | The human presence detection feature is not the main function; it is primarily used as an auxiliary to support fall detection |
| MR60BHA2 | ✅ | The human presence detection feature is not the main function; it is primarily used as an auxiliary to support the respiratory rate and heart rate detection detection |
The 24GHz mmWave for XIAO is designed for users seeking convenience and fast access. It offers features like human presence detection and motion detection, all controllable via a Bluetooth mobile app. Ready to use out of the box, it simplifies setup and allows users to quickly benefit from its capabilities. Here’s the Bluetooth app interface:
The MR24HPC1 Lite is designed for hands-on users, featuring human presence, motion, and speed detection, with a focus on customizable parameter adjustments for various scenarios. Users can achieve optimal detection results by adjusting the correct parameters, but must carefully read the documentation to fully utilize its customization options. Below is the operation interface for its upper computer:
mmWave Radar Sensor: Typical Application Scenarios in our Life
mmWave radar sensors are utilized in a variety of innovative projects across different industries. Here are a few examples:
- Automotive Safety Systems: Enhancing driver assistance systems with features like adaptive cruise control, automatic emergency braking, and blind-spot detection.
- Smart Home Devices: Using radar sensors for gesture recognition, presence detection, and monitoring vital signs without physical contact.
- Industrial Automation: Implementing radar for monitoring machinery, detecting human presence in hazardous areas, and improving safety in automated environments.
- Healthcare Applications: Monitoring patients' vital signs, detecting falls, and providing non-invasive diagnostic tools.
- Drone Navigation: Enabling drones to avoid obstacles, navigate autonomously, and perform precision landings.
These projects demonstrate the versatility and potential of mmWave radar technology in transforming various fields through improved sensing and automation capabilities.
Certainly, you can also connect our mmWave radar sensor module to HomeAssistant. Here are some usage examples:
- MR60FDA2 Fall detection Sensor with Home Assistant
- MR60BHA2 Breath-Heartbeat Sensor with Home Assistant
- mmWave Kit And Grove Connect To ESPHome
- mmWave for XIAO to Home Assistant via Bluetooth
Installation method of mmWave Radar Sensors
Method 1: Top installation. Top-mounted hanging height 2.2-3.0m, maximum sensing radius 2m, the side with the mmWave sensor needs to align with the direction of detection.
Applicable to: MR60FDA2, MR24HPC1, 24GHz mmWave XIAO
The installation height threshold of MR60FDA2 is between 2.4 and 3.0 meters, and the height threshold for detecting falls is between 0 and 0.6 meters.
Method 2: Side installation. Side-mounted, it is recommended that the radar installation height be consistent with the chest height of the person being measured, and the module position and chest position ≤ 1.5m.
Applicable to: MR60BHA2, MR24HPC1, 24GHz mmWave XIAO
Method 3: inclined installation. For sleep breathing and heart rate detection needs, an inclined installation method can be adopted. The radar is required to be installed at a height of 1m directly above the head of the bed, tilted downward at 45° towards the middle of the bed, and the distance between the radar and the chest cavity is controlled to be within 1.5m. The radar normal direction is aligned with the main detection position to ensure that the radar can detect respiratory and heartbeat data.
Please use this module in an open space, and stay out of the following scenarios within the detecting range to prevent interference with the module:
- Multiple radars installed too close together
- Wind moves curtains and sways plants
- Water flow and water film
- Large areas of metal and mirror reflections
- Detection through glass and thin wooden boards
- Installation location prone to vibrations
- Use of low-quality power supplies
Open Source the Seeed Studio mmWave Radar Sensors
Seeed Studio MR60FDA2 mmWave kit Open-Source Materials
- STL: mmWave 3D Case
- GitHub Repository: Access the full codebase and documentation at the Seeed mmWave Library GitHub page.
- ESPHome Documentation: For further customization and integration, refer to the ESPHome documentation.
- MR60FDA2 Firmware upgrade tool: MR60FDA2_OTA.zip
- MR60FDA2 Firmware v4.0.18: MR60FDA2_eeprom_v4.0.18.bin
- MR60FDA2 GUI Software: Seeed_Studio_mmWave_Sensor_MR60FDA2_GUI.zip
- mmWave Sensor SCH V1.0: mmWave_Sensor_SCH_V1.0.pdf
- MR60FDA2 Module Technical Specification: MR60FDA2_Fall_Detection_Module_Datasheet.pdf
- MR60FDA2 Tiny Frame Interface Manual: Seeed_Studio_TinyFrame_Interface_Fall_detection_V1.1.pdf
Seeed Studio MR60BHA2 mmWave kit Open-Source Materials
- MR60BHA2 Firmware upgrade tool: MR60BHA2_OTA.zip
- MR60BHA2 Firmware v1.6.4: MR60BHA2_eeprom_1.6.4.bin
- MR60BHA2 GUI Software: Seeed_Studio_mmWave_Sensor_MR60BHA2_GUI.zip
- MR60BHA2 Module Technical Specification: MR60BHA2_Breathing_and_Heartbeat_Module.pdf
- MR60BHA2 Tiny Frame Interface Manual: Seeed_Studio_Tiny_Frame_Interface_Breathing_and_Heartbeat.pdf
Seeed Studio 24GHz mmWave for XIAO Open-Source Materials
- 24GHz mmWave for XIAO Technical Specification: 24GHz_mmWave_for_XIAO-Datasheet-V1.00.pdf
- 24GHz mmWave for XIAO User Manual: 24GHz_mmWave_for_XIAO-Usermanual-V1.00.pdf
- 24GHz mmWave for XIAO SCH: 24GHz-mmWave-for-xiao-SCH.pdf
Seeed Studio MR24HPC1 mmWave kit Open-Source Materials
- GitHub Repository: Access the full codebase and documentation at the Project open source.
- MR24HPC1 Module Quick Setup Template: MR24HPC1_Quick_Setup_Template-V1.0.pdf
- MR24HPC1 Module Technical Specification: 24GHz_mmWave_Sensor-Human_Static_Presence_Module_Lite_Datasheet.pdf
- MR24HPC1 Module User Manual V1.5: MR24HPC1_User_Manual-V1.5.pdf
Version 1
- MR24HPC1 Module SCH&PCB V1.0: mmWare-kit_sch&pcb.zip
- MR24HPC1 Module SCH V1.0: sch_mmware_kit.pdf
Version 2
- MR24HPC1 Module SCH&PCB V2.0: Human_Detection_Sensor_Board_V2.zip
- MR24HPC1 Module SCH V2.0: mmwave_kit_sch_V2.pdf
Seeed Studio 24GHz mmWave Sensor MR24HPC1 Open-Source Materials
- MR24HPC1 Module User Manual V2.0: MR24HPC1_User_Manual-V2.0.pdf
- MR24HPC1 Module Upper Computer Software: Human-Radar-Open-Protocol_2.0.exe
- MR24HPC1 Module CE Certification Documents: 101991030_CE.zip
The raw data and algorithms in the Seeed Studio mmWave Radar Sensors are non-open source. Thank you for your understanding and support!
✨ Contributor Project
- We have a task list for updating this page, which is categorized under our contributor project, as we are dedicated to enhancing the user experience and providing better support through the development of our wiki platform.
- Your contribution to this page is essential to us! We really value your input and would greatly appreciate your assistance in generating ideas.
