Object Detection with YOLOv11 on reComputer-RK
This project provides industrial-grade, high-performance Computer Vision (CV) application solutions for Rockchip series development boards (RK3588 and RK3576). It features deep integration of the YOLOv11 object detection model, leveraging NPU acceleration for low-latency, high-frame-rate real-time inference.
Project Structure
The project is organized by platform to manage specific drivers and runtime requirements for the RKNN-Toolkit2:
reComputer-RK-CV/
├── docker/ # Environment setup files
│ ├── rk3576/ # Dockerfile for RK3576 (rknn-rt 2.1.0+)
│ └── rk3588/ # Dockerfile for RK3588 (rknn-rt 2.1.0+)
├── src/ # Implementation logic
│ ├── rk3576/ # RK3576 source, models, and dependencies
│ └── rk3588/ # RK3588 source, models, and dependencies
└── .github/workflows/ # CI/CD for automated image building
Hardware Compatibility
While both chips offer 6 TOPS of NPU performance, they require different hardware path mappings within Docker.
| Platform | SoC | NPU Node | Recommended Camera | Image Tag |
| RK3588 | RK3588/RK3588S | /dev/dri/renderD129 | /dev/video1 | rk3588-yolo |
| RK3576 | RK3576 | /dev/dri/renderD128 | /dev/video0 | rk3576-yolo |
Getting Started
Install Docker
Install the standard Docker engine on your board:
curl -fsSL https://get.docker.com -o get-docker.sh
sudo sh get-docker.sh
sudo systemctl enable --now docker
X11 Forwarding (Optional)
To see the detection window on a monitor connected directly to the board:
xhost +local:docker
Run the Detection Project
The application features Auto-Detection: if no display is found, it automatically starts an MJPEG stream accessible via your browser.
For reComputer RK3588:
sudo docker run --rm --privileged --net=host \
-e DISPLAY=$DISPLAY \
-v /tmp/.X11-unix:/tmp/.X11-unix \
-e PYTHONUNBUFFERED=1 \
--device /dev/video1:/dev/video1 \
--device /dev/dri/renderD129:/dev/dri/renderD129 \
-v /proc/device-tree/compatible:/proc/device-tree/compatible \
ghcr.io/seeed-projects/recomputer-rk-cv/rk3588-yolo:latest \
python web_detection.py --model_path model/yolo11n.rknn --camera_id 1
For reComputer RK3576:
--device /dev/video0:/dev/video0 \
--device /dev/dri/renderD128:/dev/dri/renderD128 \
ghcr.io/seeed-projects/recomputer-rk-cv/rk3576-yolo:latest \
python web_detection.py --model_path model/yolo11n.rknn --camera_id 0
Web Interaction & Real-time Streaming
The project includes a RESTful API compatible with Ultralytics standards, accessible via http://<Board_IP>:8000.
- Real-time Video Feed: Access /api/video_feed. Can be embedded directly in HTML:
<img src="http://<IP>:8000/api/video_feed">.
- Static Image Inference:
curl -X POST "http://localhost:8000/api/models/yolo11/predict" -F "file=@/home/user/test.jpg"
- Dynamic Configuration:
# Modify confidence threshold without restarting
curl -X POST "http://localhost:8000/api/config" -d '{"obj_thresh": 0.5}'
Developer Guide
Custom Model Deployment
- Place your converted .rknn model in a host directory.
- Create a class configuration file class_config.txt (e.g., "person", "car").
- Mount via -v and specify the paths in the startup command:
sudo docker run ... \
-v $(pwd)/my_model.rknn:/app/model/my_model.rknn \
-v $(pwd)/class_config.txt:/app/class_config.txt \
python web_detection.py --model_path model/my_model.rknn --class_path class_config.txt
CLI Arguments Reference
web_detection.py supports the following parameters:
| Argument | Description | Default |
--model_path | Path to the RKNN model file | (Required) |
--camera_id | Camera ID (e.g., 0 for /dev/video0) | 1 |
--class_path | Path to custom class configuration file | None (Default COCO 80) |
--port | Web server port | 8000 |
Demo Video
Watch YOLOv11 running on the latest EVT samples of Seeed's upcoming Rockchip RK3576 Dev Kit:
