Get Started with SES
Preparation
note
Before flashing the firmware, please ensure you device is T1000-E for LoRaWAN version and please don't flash other Meshtastic firmware to this tracker model, it may cause the device to be completely dead.
Hardware Preparation
  • SenseCAP T1000-E x 1
  • USB Cable x 1
  • Computer x 1
Software Preparation
Before you can start developing,the following software tools are required.
SEGGER Embedded Studio (SES)
SES is an all-in-one solution for managing, building, testing and deploying embedded applications. This means smooth, efficient development operations thanks to its wide range of features. The powerful project manager enables the management of projects large and small. Version control features enable automatic application deployment.
Download the corresponding installation package according to your operating system.
SEGGER Embedded Studio (SES)-Download
It's recommended to use 5.68 version.
nRF5 SDK
The nRF5 SDK provides a rich developing environment for nRF5 Series devices by including a broad selection of drivers, libraries, examples for peripherals, SoftDevices, and proprietary radio protocols.
nRF5 SDK-Download
Seeed T1000-E Example Package
Seeed provides an example project for developers to get started more quickly. This example includes LoRaWAN communication, positioning information acquisition, onboard sensor data acquisition, etc.
Seeed Example-Download
Add Seeed Example file to nRF5 SDK
Copy the Seeed T1000-E Example file to the following path of nRF5 SDK: .../nRF5_SDK_17.1.0_ddde560/examples/ble_peripheral/
Check the Bootloader info
Before start, please check the bootloader info first.
  • Step 1: Enter DFU mode
Connect the USB cable to your PC, press and hold the device button, then quickly connect the charging cable, there should be a driver named T1000-E display.
note
If no driver window pops up after pressing and holding the device button when connecting the cable, please quickly double-tap the charging cable as shown in the operation below.
  • Step 2: Check the INFO_UF2.TXT
The correct bootloader information is shown in the figure:
Run LoRaWAN Example Project
Import Example Project
Here we take 08_ses_lorawan_gnss project as an example. Open SES and open the example project.
Modify the LoRaWAN Params
Define the REGION/DEVICE_EUI/JOIN_EUI/APP_KEY in lorawan_key_config.h.
Build the modified project
Select the required project in the Project Explorer.
Choose Build > Build or press F7.
Convert to UF2 file
After the build is successful, there will be a .hex file in the output folder, we have included a Python script uf2conv.py in Firmware folder to convert the hex file to uf2 file.
Navigate to the file path and run the script:
python uf2conv.py filename.hex -c -f 0xADA52840 -o filename.uf2
Flash the Application Firmware
Connect the USB cable to your PC, press and hold the device button, then connect the charging cable, there should be a driver named T1000-E display.
  • Step 2: Flash LoRaWAN Application Firmware
Copy UF2 file to the DFU drive. Firmware should be flashed after the file is downloaded and the device reboots.
Connect to a LNS
In this section, we will connect the device to the LNS (here we take TTN as an example) to view the data, and check the location via TTN Mapper.
To begin, register for an account with The Things Industries or The Things Network.
Step 1: Create an application
Navigate to Applications page, click "+Create application".
Enter an Application ID, click Create Application to save your changes.
Step 2: Register the Device
Click "Register end device".
Set the following parameters:
Frequency Plan: Select the appropriate Frequency plan for the target region
LoRaWAN version:LoRaWAN Specification 1.0.4
Regional Parameters version: PR002 Regional Parameters V1.0.3
JoinEUI/DevEUI/APPEUI: Which you defined in the 'lorawan_key_config.h' file in the previous setting.
Check Live Data
Restore the Factory Firmware
  • Use the factory firmware back, flash the t1000_e_dev_kit_11_lorawan_tracker.uf2 firmware.
  • Use the SenseCAP cloud, need to import the SenseCAP keys by scanning the QR code on the device label.
