Comunicação SPI no Seeed Studio XIAO SAMD21
Interface de Comunicação SPI​
Hardware​
Materiais necessários
Conexão de Hardware
  • Passo 1. CSK do Grove-High Precision pressure Sensor é conectado ao SCK do Seeed Studio XIAO.
  • Passo 2. CS do sensor é conectado ao D3 do Seeed Studio XIAO.
  • Passo 3. SDO do sensor é conectado ao MISO do Seeed Studio XIAO.
  • Passo 4. SDI do sensor é conectado ao MOSI do Seeed Studio XIAO.
  • Passo 5. GND do sensor é conectado ao GND do Seeed Studio XIAO.
  • Passo 6. 3V3 do sensor é conectado ao 3.3V do Seeed Studio XIAO.
  • Passo 7. Conecte o Seeed Studio XIAO ao PC por meio de um cabo Type-C.
Software​
#include <Dps310.h>
// Dps310 Opject
Dps310 Dps310PressureSensor = Dps310();
//pin number of your slave select line
//XMC2GO
int16_t pin_cs = 3;
//for XMC 1100 Bootkit & XMC4700 Relax Kit uncomment the following line
//int16_t pin_cs = 10;
Serial.begin(9600);
while (!Serial);
//Call begin to initialize Dps310
//The parameter pin_nr is the number of the CS pin on your Microcontroller
Dps310PressureSensor.begin(SPI, pin_cs);
//temperature measure rate (value from 0 to 7)
//2^temp_mr temperature measurement results per second
int16_t temp_mr = 2;
//temperature oversampling rate (value from 0 to 7)
//2^temp_osr internal temperature measurements per result
//A higher value increases precision
int16_t temp_osr = 2;
//pressure measure rate (value from 0 to 7)
//2^prs_mr pressure measurement results per second
int16_t prs_mr = 2;
//pressure oversampling rate (value from 0 to 7)
//2^prs_osr internal pressure measurements per result
int16_t prs_osr = 2;
//startMeasureBothCont enables background mode
//temperature and pressure ar measured automatically
//High precision and hgh measure rates at the same time are not available.
//Consult Datasheet (or trial and error) for more information
int16_t ret = Dps310PressureSensor.startMeasureBothCont(temp_mr, temp_osr, prs_mr, prs_osr);
//Use one of the commented lines below instead to measure only temperature or pressure
//int16_t ret = Dps310PressureSensor.startMeasureTempCont(temp_mr, temp_osr);
//int16_t ret = Dps310PressureSensor.startMeasurePressureCont(prs_mr, prs_osr);
if (ret != 0)
Serial.print("Init FAILED! ret = ");
Serial.println(ret);
else
Serial.println("Init complete!");
uint8_t pressureCount = 20;
float pressure[pressureCount];
uint8_t temperatureCount = 20;
float temperature[temperatureCount];
//This function writes the results of continuous measurements to the arrays given as parameters
//The parameters temperatureCount and pressureCount should hold the sizes of the arrays temperature and pressure when the function is called
//After the end of the function, temperatureCount and pressureCount hold the numbers of values written to the arrays
//Note: The Dps310 cannot save more than 32 results. When its result buffer is full, it won't save any new measurement results
int16_t ret = Dps310PressureSensor.getContResults(temperature, temperatureCount, pressure, pressureCount);
if (ret != 0)
Serial.println();
Serial.println();
Serial.print("FAIL! ret = ");
else
Serial.println();
Serial.println();
Serial.print(temperatureCount);
Serial.println(" temperature values found: ");
for (int16_t i = 0; i < temperatureCount; i++)
Serial.print(temperature[i]);
Serial.println(" degrees of Celsius");
Serial.println();
Serial.print(pressureCount);
Serial.println(" pressure values found: ");
for (int16_t i = 0; i < pressureCount; i++)
Serial.print(pressure[i]);
Serial.println(" Pascal");
//Wait some time, so that the Dps310 can refill its buffer
delay(10000);
  • Passo 4. Clique em Tools > Serial Monitor, ou pressione Ctrl+Shift+M juntos, abra o monitor serial após o upload bem-sucedido, a saída aparece como segue:
