Teste de RGB
Funcionalidade
A luz RGB na placa ReSpeaker Lite utiliza o chip WS2812 e é controlada pelo pino GPIO1. O projeto alterna entre diferentes cores (vermelho, verde, azul e branco) para garantir que a luz RGB esteja funcionando corretamente.
Código
// Define parameters for the LED strip
#define PIN 1 // Pin connected to the RGB LED
#define NUMPIXELS 1 // Number of LEDs
Adafruit_NeoPixel strip(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800); // Initialize the LED strip object
// Initialize the serial monitor for debugging
// Initialize the RGB LED strip
strip.begin();
strip.show(); // Initialize all pixels to the off state
// Red color test
Serial.println("Red color test");
strip.setPixelColor(0, strip.Color(255, 0, 0)); // Set the first pixel to red
strip.show(); // Update the strip display
delay(1000); // Delay for 1 second
// Green color test
Serial.println("Green color test");
strip.setPixelColor(0, strip.Color(0, 255, 0)); // Set the first pixel to green
strip.show();
// Blue color test
Serial.println("Blue color test");
strip.setPixelColor(0, strip.Color(0, 0, 255)); // Set the first pixel to blue
strip.show();
// White color test
Serial.println("White color test");
strip.setPixelColor(0, strip.Color(255, 255, 255)); // Set the first pixel to white
strip.show();
// Turn off the LED
Serial.println("Turn off the LED");
strip.setPixelColor(0, strip.Color(0, 0, 0)); // Turn off the first pixel
strip.show();
Configuração
strip.setPixelColor: define a cor do LED na tira.
strip.show: aplica as alterações de cor ao LED.
