4G Raspberry Pi HAT - QMI Mode Setup on Raspberry Pi OS
Introduction
This guide explains how to configure internet access on a Raspberry Pi using a 4G HAT equipped with a Quectel EG25-G module. The Quectel EG25-G is a widely-used LTE modem that supports multiple network protocols, including QMI (Qualcomm MSM Interface) mode, which enables efficient and high-speed mobile broadband connectivity. By following this guide, you will learn how to set up the module in QMI mode, compile and use the quectel-CM dial-up tool, and establish a stable 4G internet connection on your Raspberry Pi. This method is ideal for applications requiring mobile internet access, such as IoT deployments, remote monitoring, and edge computing.
Prerequisites
Hardware Requirements
| Raspberry Pi 5 | Raspberry Pi 4G LTE CAT4 HAT |
Software Prerequisites
Remove Previous Dialing Configurations
Before proceeding, ensure that any other dialing methods are removed to avoid conflicts.
- Verify Correct Serial Port
Run the following command to verify you are using the correct AT command port (replace /dev/ttyUSB2 if needed):
sudo minicom -D /dev/ttyUSB2
- Check and Set USB Network Mode
Inside the minicom terminal, input:
AT+QCFG="usbnet"?
- If the response is
usbnet,0, no changes are needed.
To explicitly set the mode to 0:
AT+QCFG="usbnet",0
- Restart the Module
Reset the module using:
AT+CFUN=1,1
Verify Kernel Driver(qmi_wwan and others)
Check if the qmi_wwan driver is loaded:
lsmod
- If you see output indicating
qmi_wwanis loaded, the kernel driver is active.
Transplanting the Dial Tool
- Download and Extract the Tool
- After downloading, unzip the package into your home directory.
- Navigate to your home directory:
ls
- You should see a folder named
eg25qmi.
- Navigate to the Tool Directory
cd eg25qmi
ls
- You will see source files for the dial-up tool.
Compilation
- Compile the Dialing Tool
sudo make
- After compilation, newly generated files (highlighted in green) will be visible, including the
quectel-CMdial-up tool.
Verify the Compiled Files
ls
- The
quectel-CMexecutable should be present. This is the dial-up tool required for connecting to the internet.
Dial-Up Internet Access
- Start Dialing
sudo ./quectel-CM
- If the dialing process is successful, you will see an assigned IP address and gateway information.
- If the first attempt fails, wait and retry; the second attempt should succeed.
Post-Dialing Verification
- Check Network Interface
ifconfig
- Look for the
wwan0interface with an IP address.
- Test Connectivity
ping -I wwan0 8.8.8.8
- A successful ping confirms the connection is active.
