reComputer-Jetson® Guide
Getting Started with reComputer-Jetson®
| Getting Started with reComputer-Jetson® J10X/J20X | Hardware Layout of reComputer-Jetson® J10X/J20X |
| Follow the instructions, connect peripherals, you can power it up and directly use it in few seconds. | You will get the basic idea of the reComputer J10/J20 for Jetson Series hardware layout here. |
| Getting Started with reComputer-Jetson® J30X/J40X | Hardware Layout of reComputer-Jetson® J30X/J40X |
| Follow the instructions, connect peripherals, you can power it up and directly use it in few seconds. | You will get the basic idea of the reComputer J30/J40 for Jetson Series hardware layout here. |
OS Installations
| reComputer-Jetson® J1010/J101 | reComputer-Jetson® J1020v1/A206 | reComputer-Jetson® J1020v2/J202 |
| reComputer-Jetson® J30X/J40X | reComputer-Jetson® A603 | reComputer-Jetson® A607 |
| reComputer-Jetson® A203 | reComputer-Jetson® A205 | reComputer-Jetson® Jetson Mate |
Applications
| Speech Subtitle Generation on Nvidia Jetson | Deploy Whisper on NVIDIA Jetson Orin for Real time Speech to Text | How to Run a Local LLM Text-to-Image on reComputer |
| In this wiki, we introduce you Speech Subtitle Generation on Jetson, which can offer real-time speech-to-subtitle services while avoiding information leakage on the internet. | In this wiki we introduce you Real Time Whisper on Jetson, this integration enables speech processing directly on the device, eliminating the need for constant network connectivity and enhancing privacy and security. | This wiki encompasses setting up and deploying local LLM-based text-to-image generation models on the Nvidia Jetson Orin NX 16GB |
| Quantized Llama2-7B with MLC LLM on Jetson | Knife Detection: An Object Detection Model Deployed on Triton Inference Sever Based on reComputer | Deploy Detection Model on Jetson by No Code Edge AI Tool |
| In this project, we introduce a quantized version of Llama2-7B, a large language model trained on 1.5TB of data, and deploy it on the Jetson Orin. | We provide this fundamental project that we are going to deploy a Deep Learning model on reComputer J1010 to detect prohibited items. | In this wiki, we'll go over how to download and install what we need under a fresh NVIDIA Jetson system, then open the Edge AI Tool and perform object detection with a live camera. |
| DashCamNet and PeopleNet with Jetson Xavier NX Multicamera | Intelligent Traffic Management System using DeepStream SDK | Getting Started with Docker |
| In this wiki, we deploy a TAO pre-trained model on Jetson and achieve high-speed inference. | For this AI vision application, we will use DeepStream SDK by NVIDIA and perform inference at the edge on an NVIDIA Jetson device. | In this wiki, we attempt to install Docker Compose and run Docker containers on Jetson. |
| Update Jetson Linux Over-the-Air Using Allxon | How to Train and Deploy YOLOv8 on reComputer | Maskcam - Crowd Face Mask Usage Monitoring based on Jetson Nano |
| Allxon can help you to upload the OTA Payload Package and make sure it can work. You will come across this step later in this wiki. | In this wiki, we train and deploy a object detection model for traffic scenes on the reComputer J4012. | In this wiki, we have implemented a mask detection feature using Jetson. |
- Troubleshooting Installation
- The remaining space in the eMMC in the received reComputer is only about 2GB, how to solve the problem of insufficient space?
- How to solve the compatibility issue between reComputer and VEYE camera?
