FAQs for reTerminal Usage
This document contains all the frequently asked questions related to reTerminal. This will be very helpful if you are suffering from any issues when using the reTerminal.
Q1: How to troubleshoot the black screen issue on reTerminal
For details, please click here
Q2: How can I flash Raspberry Pi OS which is originally shipped with reTerminal
Q3: How to flash Raspberry Pi OS/ 64-bit Ubuntu OS or Other OS to eMMC
Q4: How to install reTerminal drivers after flashing new Raspberry Pi OS/ Ubuntu OS or Other OS
Q5: How to upgrade Raspberry Pi OS and the installed packages
Q6: How can I flash OS if I replace the CM4 with non-eMMC version
Q7: How can I log in to Raspberry Pi OS/ Ubuntu OS or other OS using a USB to serial converter
Q8: I cannot wake up the reTerminal LCD after sleep
Q9: How can I boot an OS from USB Flash Drive
Q10: Why there is black glue around the chips on the CM4?
Q11: How to solve the issue of buzzer, LEDs do not work after installing the reTerminal drivers
Q12: How can I install Ubuntu on reTerminal?
Q13: The screen orientation is incorrect after installing Raspberry Pi OS Bullseye
Q14: Troubleshooting Touch Screen Inaccuracy
Q15: How to disable screen rotation on reTerminal
Q16: How to check if the Encryption Chip is ATECC608A-SSHDA-B or ATECC608A-TNGTLSS-G
Q17: How to solve screen refresh rate is too low
Tech Support
