Apps
Core App Classes
reachy_mini.ReachyMiniApp
Source
Base class for Reachy Mini applications.
Methods
run
Source
Run the main logic of the app.
Parameters:
NameTypeDescription
reachy_miniReachyMiniThe Reachy Mini instance to interact with.
stop_eventthreading.EventAn event that can be set to stop the app gracefully.
stop
Source
Stop the app gracefully.
wrapped_run
Source
Wrap the run method with Reachy Mini context management.
reachy_mini.apps.manager.AppManager
Source
Manager for Reachy Mini apps.
Methods
close
Source
Clean up the AppManager, stopping any running app.
current_app_status
Source
Get the current status of the app.
install_new_app
Source
Install a new app by name.
is_app_running
Source
Check if an app is currently running or stopping.
list_all_available_apps
Source
List available apps (parallel async).
list_available_apps
Source
List available apps for given source kind.
remove_app
Source
Remove an installed app by name.
restart_current_app
Source
Restart the current app.
start_app
Source
Start the app as a subprocess, raises RuntimeError if an app is already running.
stop_current_app
Source
Stop the current app subprocess.
update_app
Source
Update an installed app by reinstalling it from HuggingFace.
This preserves the original source info and reinstalls to get the latest version.
Parameters:
NameTypeDescription
app_namestrName of the app to update.
loggerlogging.LoggerLogger for progress output.
App Management
reachy_mini.apps.manager.AppState
Source
Status of a running app.
reachy_mini.apps.manager.AppStatus
Source
Status of an app.
reachy_mini.apps.manager.RunningApp
Source
Information about a running app.
App Information
reachy_mini.apps.AppInfo
Source
Metadata about an app.
reachy_mini.apps.SourceKind
Source
Kinds of app source.
App Assistant
Assistant Functions
reachy_mini.apps.assistant.validate_app_name
Source
Validate the app name.
reachy_mini.apps.assistant.is_git_repo
Source
Check if the given path is inside a git repository.
reachy_mini.apps.assistant.validate_location
Source
Validate the location where to create the app project.
reachy_mini.apps.assistant.validate_location_and_git_repo
Source
Validate the location where to create the app project, ensuring it's not in a git repo.
reachy_mini.apps.assistant.create_cli
Source
Create a new Reachy Mini app project using a CLI.
Source
Create a new Reachy Mini app project with the given name at the specified path.
Parameters:
NameTypeDescription
consoleConsoleThe console object for printing messages.
app_namestrThe name of the app to create.
app_pathPathThe directory where the app project will be created.
Returns:
TypeDescription
PathThe path to the created app project.
reachy_mini.apps.assistant.install_app_with_progress
Source
Install the app in a temporary virtual environment with a progress spinner.
reachy_mini.apps.assistant.check
Source
Check an existing Reachy Mini app project.
Parameters:
NameTypeDescription
app_pathstrLocal path to the app to check.
reachy_mini.apps.assistant.request_app_addition
Source
Request to add the new app to the official Reachy Mini app store.
reachy_mini.apps.assistant.try_to_push
Source
Try to push changes to the remote repository.
reachy_mini.apps.assistant.publish
Source
Publish the app to the Reachy Mini app store.
Parameters:
NameTypeDescription
app_pathstrLocal path to the app to publish.
commit_messagestrCommit message for the app publish.
officialboolRequest to publish the app as an official Reachy Mini app.
no_checkboolDon't run checks before publishing the app.
privatebool | NoneIf True, make private. If False, make public. If None, prompt.
App Sources
reachy_mini.apps.sources.hf_auth.save_hf_token
Source
Save a HuggingFace access token securely.
Validates the token against the Hugging Face API and, if valid, stores it using the standard Hugging Face authentication mechanism for reuse across sessions.
Parameters:
NameTypeDescription
tokenstrThe HuggingFace access token to save.
Returns:
TypeDescription
dictA dict containing: "status" ("success" or "error"), "username" (the associated Hugging Face username if successful), and "message" (an error description if unsuccessful).
reachy_mini.apps.sources.hf_auth.get_hf_token
Source
Get stored HuggingFace token.
Returns:
TypeDescription
str | NoneThe stored token, or None if no token is stored.
reachy_mini.apps.sources.hf_auth.delete_hf_token
Source
Delete stored HuggingFace token(s).
note
logout() without arguments logs out from all saved access tokens.
reachy_mini.apps.sources.hf_auth.check_token_status
Source
Check if a token is stored and valid.
Returns:
TypeDescription
dictStatus dict with is_logged_in and username.
reachy_mini.apps.sources.hf_space.list_available_apps
Source
List apps available on Hugging Face Spaces.
reachy_mini.apps.sources.hf_space.list_all_apps
Source
List all apps available on Hugging Face Spaces (including unofficial ones).
reachy_mini.apps.sources.local_common_venv.get_app_site_packages
Source
Public API to get the site-packages directory for a given app's venv.
info
  • For separate venvs: returns the app's venv site-packages
  • For shared environment (SDK mode): returns the current environment's site-packages
reachy_mini.apps.sources.local_common_venv.get_app_python
Source
Get the Python executable path for an app (cross-platform).
info
  • For separate venvs: returns the app's venv Python
  • For shared environment: returns the current Python interpreter
reachy_mini.apps.sources.local_common_venv.list_available_apps
Source
List apps available from entry points or separate venvs.
reachy_mini.apps.sources.local_common_venv.install_package
Source
Install a package given an AppInfo object, streaming logs.
Parameters:
NameTypeDescription
appAppInfoAppInfo with package details.
wireless_versionboolWhether running on wireless version.
desktop_app_daemonboolWhether running as desktop app daemon.
force_reinstallboolIf True, force reinstall even if already installed (for updates).
reachy_mini.apps.sources.local_common_venv.get_app_module
Source
Get the module name for an app without loading it (for subprocess execution).
reachy_mini.apps.sources.local_common_venv.uninstall_package
Source
Uninstall a package given an app name.
App Utilities
reachy_mini.apps.utils.running_command
Source
Run a shell command and stream its output to the provided logger.
