Media
Media Manager
reachy_mini.media.media_manager.MediaManager
Source
Media Manager for handling camera and audio devices.
This class provides a unified interface for managing both camera and audio devices across different backends. It handles initialization, configuration, and cleanup of media resources.
Methods
close
Source
Close the media manager and release resources.
This method should be called when the media manager is no longer needed to properly clean up and release all media resources. It stops any ongoing audio recording/playback and closes the camera device.
note
After calling this method, the media manager can be reused by calling the appropriate initialization methods again, but it's generally recommended to create a new MediaManager instance if needed.
Example:
media = MediaManager()
try:
# Use media devices
frame = media.get_frame()
finally:
media.close()
get_DoA
Source
Get the Direction of Arrival (DoA) from the microphone array.
Returns:
TypeDescription
tuple[float, bool] | NoneA tuple (angle_radians, speech_detected), or None if the audio system is not available.
get_audio_sample
Source
Get an audio sample from the audio device.
Returns:
TypeDescription
Optional[np.ndarray]The recorded audio sample, or None if no data is available.
get_frame
Source
Get a frame from the camera.
note
This method returns None if the camera is not initialized or if there's an error capturing the frame. Always check the return value before using the frame.
Example:
if frame is not None:
# Process the frame
cv2.imshow("Camera", frame)
cv2.waitKey(1)
# Convert to RGB if needed
rgb_frame = cv2.cvtColor(frame, cv2.COLOR_BGR2RGB)
Returns:
TypeDescription
Optional[npt.NDArray[np.uint8]]The captured BGR frame as a numpy array with shape (height, width, 3), or None if the camera is not available or an error occurred. The image is in BGR format (OpenCV convention) and can be directly used with OpenCV functions or converted to RGB if needed.
get_input_audio_samplerate
Source
Get the input samplerate of the audio device.
get_input_channels
Source
Get the number of input channels of the audio device.
get_output_audio_samplerate
Source
Get the output samplerate of the audio device.
get_output_channels
Source
Get the number of output channels of the audio device.
play_sound
Source
Play a sound file.
Parameters:
NameTypeDescription
sound_filestrPath to the sound file to play.
push_audio_sample
Source
Push audio data to the output device.
Parameters:
NameTypeDescription
datanpt.NDArray[np.float32]The audio data to push to the output device (mono format).
start_playing
Source
Start playing audio.
start_recording
Source
Start recording audio.
stop_playing
Source
Stop playing audio.
stop_recording
Source
Stop recording audio.
Audio
reachy_mini.media.audio_base.AudioBase
Source
Abstract class for opening and managing audio devices.
This class defines the interface that all audio implementations must follow. It provides common audio parameters and methods for managing audio devices, including microphone input and speaker output functionality.
Methods
cleanup
Source
Cleanup resources before destruction.
This method should be called to release any resources held by the audio implementation before the object is destroyed.
Parameters:
NameTypeDescription
SAMPLE_RATEintDefault sample rate for audio operations (16000 Hz).
CHANNELSintDefault number of audio channels (2 for stereo).
loggerlogging.LoggerLogger instance for audio-related messages.
_respeakerOptional[ReSpeaker]ReSpeaker microphone array device handler.
clear_output_buffer
Source
Clear the output buffer.
This method flushes the output buffer to prevent push samples from being played. Overwrite if necessary. It seems that set_max_output_buffers with a low value may be enough for gstreamer backend.
get_DoA
Source
Get the Direction of Arrival (DoA) value from the ReSpeaker device.
The spatial angle is given in radians:
  • 0 radians is left
  • π/2 radians is front/back
  • π radians is right
info
The microphone array requires firmware version 2.1.0 or higher to support this feature. The firmware is located in src/reachy_mini/assets/firmware/*.bin. Refer to https://wiki.seeedstudio.com/respeaker_xvf3800_introduction/#update-firmware for the upgrade process.
Returns:
TypeDescription
tupleA tuple containing the DoA value as a float (radians) and the speech detection as a bool, or None if the device is not found.
get_audio_sample
Source
Read audio data from the device. Returns the data or None if error.
note
This method should be called after start_recording() has been called. The sample rate and number of channels can be obtained via get_input_audio_samplerate() and get_input_channels() respectively.
Example:
audio.start_recording()
samples = audio.get_audio_sample()
if samples is not None:
print(f"Got {len(samples)} audio samples")
Returns:
TypeDescription
Optional[npt.NDArray[np.float32]]A numpy array containing audio samples in float32 format, or None if no data is available or an error occurred. The array shape is typically (num_samples,) for mono or (num_samples, num_channels) for multi-channel audio.
Source
note
This value represents the number of audio samples captured per second for each channel.
Returns:
TypeDescription
intThe sample rate in Hz at which audio is being captured. Default is 16000 Hz.
get_input_channels
Source
note
For the ReSpeaker microphone array, this typically returns 2 channels representing the stereo microphone configuration.
Returns:
TypeDescription
intThe number of audio input channels (e.g., 1 for mono, 2 for stereo). Default is 2 channels.
Source
note
This value represents the number of audio samples played per second for each channel.
Returns:
TypeDescription
intThe sample rate in Hz at which audio is being played back. Default is 16000 Hz.
get_output_channels
Source
note
This determines how audio data should be formatted when passed to push_audio_sample() method.
Returns:
TypeDescription
intThe number of audio output channels (e.g., 1 for mono, 2 for stereo). Default is 2 channels.
play_sound
Source
Play a sound file.
note
This is a convenience method that handles the complete playback of a sound file from start to finish. For more control over audio playback, use start_playing(), push_audio_sample(), and stop_playing() methods.
Example:
audio.play_sound("/path/to/sound.wav")
Parameters:
NameTypeDescription
sound_filestrPath to the sound file to play. Supported formats depend on the specific implementation.
push_audio_sample
Source
note
This method should be called after start_playing() has been called. The audio data will be played at the sample rate returned by get_output_audio_samplerate().
Parameters:
NameTypeDescription
datanpt.NDArray[np.float32]Audio samples to be played. The array should contain float32 values typically in the range [-1.0, 1.0]. For mono audio: shape should be (num_samples,). For stereo audio: shape should be (num_samples, 2).
Source
Set the maximum number of output buffers to queue in the player.
Parameters:
NameTypeDescription
max_buffersintMaximum number of buffers to queue.
start_playing
Source
This method should initialize the audio playback system and prepare it to receive audio data via push_audio_sample().
note
Implementations should handle any necessary resource allocation and error checking. If playback cannot be started, implementations should log appropriate error messages.
start_recording
Source
This method should initialize the audio recording system and prepare it to capture audio data. After calling this method, get_audio_sample() should be able to retrieve recorded audio data.
note
Implementations should handle any necessary resource allocation and error checking. If recording cannot be started, implementations should log appropriate error messages.
stop_playing
Source
Stop playing audio and release resources.
This method should stop any ongoing audio playback and release all associated resources. After calling this method, push_audio_sample() calls will have no effect until start_playing() is called again.
note
Implementations should ensure proper cleanup to prevent resource leaks.
stop_recording
Source
Close the audio device and release resources.
This method should stop any ongoing audio recording and release all associated resources. After calling this method, get_audio_sample() should return None until start_recording() is called again.
note
reachy_mini.media.audio_gstreamer.GStreamerAudio
Source
Audio implementation using GStreamer.
Methods
clear_player
Source
Flush the player's appsrc to drop any queued audio immediately.
get_audio_sample
Source
Read a sample from the audio card. Returns the sample or None if error.
See AudioBase.get_audio_sample() for complete documentation.
Returns:
TypeDescription
Optional[npt.NDArray[np.float32]]The captured sample in raw format, or None if error.
Source
See AudioBase.get_input_audio_samplerate() for complete documentation.
get_input_channels
Source
See AudioBase.get_input_channels() for complete documentation.
Source
See AudioBase.get_output_audio_samplerate() for complete documentation.
get_output_channels
Source
See AudioBase.get_output_channels() for complete documentation.
play_sound
Source
Play a sound file.
See AudioBase.play_sound() for complete documentation.
TODO: for now this function is meant to be used on the wireless version.
Parameters:
NameTypeDescription
push_audio_sample
Source
See AudioBase.push_audio_sample() for complete documentation.
start_playing
Source
Open the audio output using GStreamer.
See AudioBase.start_playing() for complete documentation.
start_recording
Source
Open the audio card using GStreamer.
See AudioBase.start_recording() for complete documentation.
stop_playing
Source
See AudioBase.stop_playing() for complete documentation.
stop_recording
Source
Release the camera resource.
See AudioBase.stop_recording() for complete documentation.
Audio Utils Functions
reachy_mini.media.audio_utils.get_respeaker_card_number
Source
Return the card number of the ReSpeaker sound card, or 0 if not found.
note
This function runs 'arecord -l' to list available audio capture devices and processes the output to find Reachy Mini Audio or ReSpeaker devices. It's primarily used on Linux systems with ALSA audio configuration.
The function returns:
  • Positive integer: Card number of detected Reachy Mini Audio device
  • 0: No Reachy Mini Audio device found, using default sound card
  • -1: Error occurred while trying to detect audio devices
Example:
card_num = get_respeaker_card_number()
if card_num > 0:
print(f"Using Reachy Mini Audio card {card_num}")
elif card_num == 0:
print("Using default sound card")
else:
print("Error detecting audio devices")
Returns:
TypeDescription
intThe card number of the detected ReSpeaker/Reachy Mini Audio device. Returns 0 if no specific device is found (uses default sound card), or -1 if there's an error running the detection command.
reachy_mini.media.audio_utils.has_reachymini_asoundrc
Source
Check if ~/.asoundrc exists and contains both reachymini_audio_sink and reachymini_audio_src.
note
This function checks for the presence of the ALSA configuration file ~/.asoundrc and verifies that it contains the necessary configuration entries for Reachy Mini audio devices (reachymini_audio_sink and reachymini_audio_src). These entries are required for proper audio routing and device management.
Example:
if has_reachymini_asoundrc():
print("Reachy Mini audio configuration is properly set up")
else:
print("Need to configure Reachy Mini audio devices")
write_asoundrc_to_home() # Create the configuration
Returns:
TypeDescription
boolTrue if ~/.asoundrc exists and contains the required Reachy Mini audio configuration entries, False otherwise.
reachy_mini.media.audio_utils.check_reachymini_asoundrc
Source
Check if ~/.asoundrc exists and is correctly configured for Reachy Mini Audio.
reachy_mini.media.audio_utils.write_asoundrc_to_home
Source
Write the .asoundrc file with Reachy Mini audio configuration to the user's home directory.
This function creates an ALSA configuration file (.asoundrc) in the user's home directory that configures the ReSpeaker sound card for proper audio routing and multi-client support. The configuration enables simultaneous audio input and output access, which is essential for the Reachy Mini Wireless version's audio functionality.
The generated configuration includes:
  • Default audio device settings pointing to the ReSpeaker sound card
  • dmix plugin for multi-client audio output (reachymini_audio_sink)
  • dsnoop plugin for multi-client audio input (reachymini_audio_src)
  • Proper buffer and sample rate settings for optimal performance
info
This function automatically detects the ReSpeaker card number and creates a configuration tailored to the detected hardware. It is primarily used for the Reachy Mini Wireless version.
The configuration file will be created at ~/.asoundrc and will overwrite any existing file with the same name. Existing audio configurations should be backed up before calling this function.
Audio Control Utils Functions
reachy_mini.media.audio_control_utils.ReSpeaker
Source
Class to interface with the ReSpeaker XVF3800 USB device.
Methods
close
Source
Close the interface.
read
Source
Read data from a specified parameter on the ReSpeaker device.
write
Source
Write data to a specified parameter on the ReSpeaker device.
reachy_mini.media.audio_control_utils.find
Source
Find and return the ReSpeaker USB device with the given Vendor ID and Product ID.
note
This function searches for USB devices with the specified Vendor ID and Product ID using libusb backend. The default values target XMOS XVF3800 devices used in ReSpeaker microphone arrays.
Example:
from reachy_mini.media.audio_control_utils import find
# Find default ReSpeaker device
respeaker = find()
if respeaker is not None:
print("Found ReSpeaker device")
respeaker.close()
# Find specific device
custom_device = find(vid=0x1234, pid=0x5678)
Parameters:
NameTypeDescription
vidintUSB Vendor ID to search for. Default: 0x2886 (XMOS).
pidintUSB Product ID to search for. Default: 0x001A (XMOS XVF3800).
Returns:
TypeDescription
ReSpeaker | NoneA ReSpeaker object if the device is found, None otherwise.
reachy_mini.media.audio_control_utils.init_respeaker_usb
Source
Initialize the ReSpeaker USB device. Looks for both new and beta device IDs.
info
This function attempts to initialize a ReSpeaker microphone array by searching for USB devices with known Vendor and Product IDs. It tries:
  1. New Reachy Mini Audio firmware (0x38FB:0x1001) - preferred
  2. Old ReSpeaker firmware (0x2886:0x001A) - with warning to update
The function handles USB backend errors gracefully and returns None if no compatible device is found or if initialization fails.
Example:
from reachy_mini.media.audio_control_utils import init_respeaker_usb
# Initialize ReSpeaker device
respeaker = init_respeaker_usb()
print("ReSpeaker initialized successfully")
# Use the device...
doa = respeaker.read("DOA_VALUE_RADIANS")
respeaker.close()
else:
print("No ReSpeaker device found")
Returns:
TypeDescription
Optional[ReSpeaker]A ReSpeaker object if a compatible device is found, None otherwise.
Camera
reachy_mini.media.camera_base.CameraBase
Source
Abstract class for opening and managing a camera.
This class defines the interface that all camera implementations must follow. It provides common camera parameters and methods for managing camera devices, including image capture, resolution management, and camera calibration.
Methods
close
Source
Close the camera and release resources.
This method should stop any ongoing image capture and release all associated resources. After calling this method, read() should return None until open() is called again.
note
Parameters:
NameTypeDescription
loggerlogging.LoggerLogger instance for camera-related messages.
_resolutionOptional[CameraResolution]Current camera resolution setting.
camera_specsOptional[CameraSpecs]Camera specifications including supported resolutions and calibration parameters.
resized_KOptional[npt.NDArray[np.float64]]Camera intrinsic matrix resized to match the current resolution.
open
Source
Open the camera.
This method should initialize the camera device and prepare it for capturing images. After calling this method, read() should be able to retrieve camera frames.
note
Implementations should handle any necessary resource allocation, camera configuration, and error checking. If the camera cannot be opened, implementations should log appropriate error messages.
read
Source
Read an image from the camera. Returns the image or None if error.
note
This method should be called after open() has been called. The image resolution can be obtained via the resolution property.
Example:
camera.open()
frame = camera.read()
cv2.imshow("Camera Frame", frame)
cv2.waitKey(1)
Returns:
TypeDescription
Optional[npt.NDArray[np.uint8]]A numpy array containing the captured image in BGR format (OpenCV convention), or None if no image is available or an error occurred. The array shape is (height, width, 3) where the last dimension represents the BGR color channels.
set_resolution
Source
Set the camera resolution.
note
This method updates the camera's resolution and automatically rescales the camera intrinsic matrix (K) to match the new resolution. The rescaling preserves the camera's field of view and principal point position relative to the image dimensions.
Example:
from reachy_mini.media.camera_constants import CameraResolution
camera.set_resolution(CameraResolution.R1280x720at30fps)
Parameters:
NameTypeDescription
resolutionCameraResolutionThe desired camera resolution from the CameraResolution enum.
reachy_mini.media.camera_opencv.OpenCVCamera
Source
Camera implementation using OpenCV.
This class implements the CameraBase interface using OpenCV, providing cross-platform camera support for Reachy Mini robots. It automatically detects and configures supported camera models.
Methods
close
Source
See CameraBase.close() for complete documentation.
Parameters:
NameDescription
Inherits all attributes from CameraBase.-
Additionally manages OpenCV VideoCapture objects and camera connections.-
open
Source
Open the camera using OpenCV VideoCapture.
See CameraBase.open() for complete documentation.
read
Source
Read a frame from the camera.
See CameraBase.read() for complete documentation.
Returns:
The frame as a uint8 numpy array, or None if no frame could be read.
set_resolution
Source
reachy_mini.media.camera_gstreamer.GStreamerCamera
Source
Camera implementation using GStreamer.
Methods
close
Source
get_video_device
Source
Use Gst.DeviceMonitor to find the unix camera path /dev/videoX.
Returns the device path (e.g., '/dev/video2'), or '' if not found.
open
Source
Open the camera using GStreamer.
read
Source
Read a frame from the camera. Returns the frame or None if error.
Returns:
TypeDescription
Optional[npt.NDArray[np.uint8]]The captured BGR frame as a NumPy array, or None if error.
set_resolution
Source
Camera Utils Functions
reachy_mini.media.camera_utils.find_camera
Source
Find and return the Reachy Mini camera.
Looks for the Reachy Mini camera first, then Arducam, then older Raspberry Pi Camera. Returns None if no camera is found. Falls back to generic webcam if no specific camera is detected.
info
This function tries to detect cameras in the following order:
  1. Reachy Mini Lite Camera (preferred)
  2. Older Raspberry Pi Camera
  3. Arducam
  4. Generic Webcam (fallback)
The function automatically sets the appropriate video codec (MJPG) for Reachy Mini and Raspberry Pi cameras to ensure compatibility.
Example:
cap, specs = find_camera()
if cap is not None:
print(f"Found {specs.name} camera")
# Set resolution
cap.set(cv2.CAP_PROP_FRAME_WIDTH, 1280)
cap.set(cv2.CAP_PROP_FRAME_HEIGHT, 720)
# Capture a frame
ret, frame = cap.read()
cap.release()
else:
print("No camera found")
Parameters:
NameTypeDescription
apiPreferenceintPreferred API backend for the camera. Default is cv2.CAP_ANY. Options include cv2.CAP_V4L2 (Linux), cv2.CAP_DSHOW (Windows), cv2.CAP_MSMF (Windows), etc.
no_capboolIf True, close the camera after finding it. Useful for testing camera detection without keeping the camera open. Default is False.
Returns:
TypeDescription
Tuple[Optional[cv2.VideoCapture], Optional[CameraSpecs]]A tuple containing: cv2.VideoCapture (A VideoCapture object if the camera is found and opened successfully, otherwise None) and CameraSpecs (The camera specifications for the detected camera, or None if no camera was found).
reachy_mini.media.camera_utils.find_camera_by_vid_pid
Source
Find and return a camera with the specified VID and PID.
note
This function uses the cv2_enumerate_cameras package to enumerate available cameras and find one with the specified USB Vendor ID and Product ID. This is useful for selecting specific camera models when multiple cameras are connected to the system.
The Arducam camera creates two /dev/videoX devices that enumerate_cameras cannot differentiate, so this function tries to open each potential device until it finds a working one.
Example:
# Find Reachy Mini Lite Camera by its default VID/PID
cap = find_camera_by_vid_pid()
if cap is not None:
print("Found Reachy Mini Lite Camera")
cap.release()
# Find a specific camera by custom VID/PID
cap = find_camera_by_vid_pid(vid=0x0C45, pid=0x636D) # Arducam
if cap is not None:
print("Found Arducam")
Parameters:
NameTypeDescription
vidintVendor ID of the camera. Default is ReachyMiniLiteCamSpecs.vid (0x38FB).
pidintProduct ID of the camera. Default is ReachyMiniLiteCamSpecs.pid (0x1002).
apiPreferenceintPreferred API backend for the camera. Default is cv2.CAP_ANY. On Linux, this automatically uses cv2.CAP_V4L2 for better compatibility.
Returns:
TypeDescription
cv2.VideoCapture | NoneA VideoCapture object if the camera with matching VID/PID is found and opened successfully, otherwise None.
Camera Constants
reachy_mini.media.camera_constants.CameraResolution
Source
Base class for camera resolutions.
Enumeration of standardized camera resolutions and frame rates supported by Reachy Mini cameras. Each enum value contains a tuple of (width, height, fps).
note
The enum values are tuples containing (width, height, frames_per_second). Not all resolutions are supported by all camera models - check the specific camera specifications for available resolutions.
Example:
# Get resolution information
res = CameraResolution.R1280x720at30fps
width, height, fps = res.value
print(f"Resolution: {width}x{height}@{fps}fps")
# Check if a resolution is supported by a camera
from reachy_mini.media.camera_constants import ReachyMiniLiteCamSpecs
res = CameraResolution.R1920x1080at60fps
if res in ReachyMiniLiteCamSpecs.available_resolutions:
print("This resolution is supported")
Available Resolutions:
ResolutionDescription
R1536x864at40fps1536x864 resolution at 40 fps
R1280x720at60fps1280x720 resolution at 60 fps (HD)
R1280x720at30fps1280x720 resolution at 30 fps (HD)
R1920x1080at30fps1920x1080 resolution at 30 fps (Full HD)
R1920x1080at60fps1920x1080 resolution at 60 fps (Full HD)
R2304x1296at30fps2304x1296 resolution at 30 fps
R1600x1200at30fps1600x1200 resolution at 30 fps
R3264x2448at30fps3264x2448 resolution at 30 fps
R3264x2448at10fps3264x2448 resolution at 10 fps
R3840x2592at30fps3840x2592 resolution at 30 fps
R3840x2592at10fps3840x2592 resolution at 10 fps
R3840x2160at30fps3840x2160 resolution at 30 fps (4K UHD)
R3840x2160at10fps3840x2160 resolution at 10 fps (4K UHD)
R3072x1728at10fps3072x1728 resolution at 10 fps
R4608x2592at10fps4608x2592 resolution at 10 fps
reachy_mini.media.camera_constants.CameraSpecs
Source
Base camera specifications.
Dataclass containing specifications for a camera model, including supported resolutions, calibration parameters, and USB identification information.
note
The intrinsic matrix K has the format:
[[fx,  0, cx],
[ 0, fy, cy],
[ 0, 0, 1]]
Where fx, fy are focal lengths in pixels, and cx, cy are the principal point coordinates (typically near the image center).
Example:
from reachy_mini.media.camera_constants import CameraSpecs
# Create a custom camera specification
custom_specs = CameraSpecs(
name="custom_camera",
available_resolutions=[CameraResolution.R1280x720at30fps],
default_resolution=CameraResolution.R1280x720at30fps,
vid=0x1234,
pid=0x5678,
K=np.array([[800, 0, 640], [0, 800, 360], [0, 0, 1]]),
D=np.zeros(5)
Parameters:
NameTypeDescription
namestrHuman-readable name of the camera model.
available_resolutionsList[CameraResolution]List of supported resolutions and frame rates for this camera model.
default_resolutionCameraResolutionDefault resolution used when the camera is initialized.
vidintUSB Vendor ID for identifying this camera model.
pidintUSB Product ID for identifying this camera model.
Knpt.NDArray[np.float64]3x3 camera intrinsic matrix containing focal lengths and principal point coordinates.
Dnpt.NDArray[np.float64]5-element array containing distortion coefficients (k1, k2, p1, p2, k3) for radial and tangential distortion.
reachy_mini.media.camera_constants.ArducamSpecs
Source
Arducam camera specifications.
reachy_mini.media.camera_constants.ReachyMiniLiteCamSpecs
Source
Reachy Mini Lite camera specifications.
reachy_mini.media.camera_constants.ReachyMiniWirelessCamSpecs
Source
Reachy Mini Wireless camera specifications.
