Reachy Mini
Main class
reachy_mini.ReachyMini
Reachy Mini class for controlling a simulated or real Reachy Mini robot.
Methods
async_play_move
Asynchronously play a Move.
Parameters:
| Name | Type | Description |
move | Move | The Move object to be played. |
play_frequency | float | The frequency at which to evaluate the move (in Hz). |
initial_goto_duration | float | Duration for the initial goto to the starting position of the move (in seconds). If 0, no initial goto is performed. |
sound | bool | If True, play the sound associated with the move (if any). |
disable_gravity_compensation
Disable gravity compensation for the head motors.
disable_motors
Disable the motors.
Parameters:
ids | List[str] | None | List of motor names to disable. If None, all motors will be disabled. Valid names match src/reachy_mini/assets/config/hardware_config.yaml: body_rotation, stewart_1 … stewart_6, right_antenna, left_antenna. |
enable_gravity_compensation
Enable gravity compensation for the head motors.
enable_motors
Enable the motors.
Parameters:
ids | List[str] | None | List of motor names to enable. If None, all motors will be enabled. Valid names match src/reachy_mini/assets/config/hardware_config.yaml: body_rotation, stewart_1 … stewart_6, right_antenna, left_antenna. |
get_current_head_pose
Get the current head pose as a 4x4 matrix.
Returns:
np.ndarray — A 4x4 matrix representing the current head pose.
get_current_joint_positions
Get the current joint positions of the head and antennas (in rad).
Returns:
tuple — A tuple containing two lists:
- List of head joint positions (rad) (length 7)
- List of antennas joint positions (rad) (length 2)
get_present_antenna_joint_positions
Get the present joint positions of the antennas (in rad).
Returns:
list — A list of antennas joint positions (rad) (length 2).
goto_sleep
Put the robot to sleep by moving the head and antennas to a predefined sleep position.
goto_target
Go to a target head pose and/or antennas position using task space interpolation, in "duration" seconds.
Parameters:
head | Optional[np.ndarray] | 4x4 pose matrix representing the target head pose. |
antennas | Optional[Union[np.ndarray, List[float]]] | 1D array with two elements representing the angles of the antennas in radians. |
duration | float | Duration of the movement in seconds. |
method | InterpolationTechnique | Interpolation method to use ("linear", "minjerk", "ease_in_out", "cartoon"). Default is "minjerk". |
body_yaw | float | None | Body yaw angle in radians. Use None to keep the current yaw. |
look_at_image
Make the robot head look at a point defined by a pixel position (u,v).
TODO: image of reachy mini coordinate system
Parameters:
u | int | Horizontal coordinate in image frame. |
v | int | Vertical coordinate in image frame. |
duration | float | Duration of the movement in seconds. If 0, the head will snap to the position immediately. |
perform_movement | bool | If True, perform the movement. If False, only calculate and return the pose. |
Returns:
np.ndarray — The calculated head pose as a 4x4 matrix.
look_at_world
Look at a specific point in 3D space in Reachy Mini's reference frame.
TODO: include image of reachy mini coordinate system
Parameters:
x | float | X coordinate in meters. |
y | float | Y coordinate in meters. |
z | float | Z coordinate in meters. |
Returns:
play_move
Parameters:
set_automatic_body_yaw
Set the automatic body yaw.
Parameters:
body_yaw | float | The yaw angle of the body in radians. |
set_target
Set the target pose of the head and/or the target position of the antennas.
Parameters:
head | Optional[np.ndarray] | 4x4 pose matrix representing the head pose. |
body_yaw | Optional[float] | Body yaw angle in radians. |
set_target_antenna_joint_positions
Set the target joint positions of the antennas.
set_target_body_yaw
Set the target body yaw.
Parameters:
set_target_head_pose
Set the head pose to a specific 4x4 matrix.
Parameters:
pose | np.ndarray | A 4x4 matrix representing the desired head pose. |
body_yaw | float | The yaw angle of the body, used to adjust the head pose. |
start_recording
Start recording data.
stop_recording
Stop recording data and return the recorded data.
wake_up
Wake up the robot - go to the initial head position and play the wake up emote and sound.
