Utils
Interpolation Functions
reachy_mini.utils.interpolation.minimum_jerk
Source
Compute the minimum jerk interpolation function from starting position to goal position.
reachy_mini.utils.interpolation.linear_pose_interpolation
Source
Linearly interpolate between two poses in 6D space.
reachy_mini.utils.interpolation.time_trajectory
Source
Compute the time trajectory value based on the specified interpolation method.
reachy_mini.utils.interpolation.delta_angle_between_mat_rot
Source
Compute the angle (in radians) between two 3x3 rotation matrices P and Q.
This is equivalent to the angular distance in axis-angle space. It is computed via the trace of the relative rotation matrix.
Parameters:
NameDescription
PA 3x3 rotation matrix.
QAnother 3x3 rotation matrix.
Returns:
The angle in radians between the two rotations.
References:
reachy_mini.utils.interpolation.distance_between_poses
Source
Compute three types of distance between two 4x4 homogeneous transformation matrices.
The result combines translation (in mm) and rotation (in degrees) using an arbitrary but emotionally satisfying equivalence: 1 degree ≈ 1 mm.
Parameters:
NameDescription
pose1A 4x4 homogeneous transformation matrix representing the first pose.
pose2A 4x4 homogeneous transformation matrix representing the second pose.
Returns:
A tuple of:
  • translation distance in meters
  • angular distance in radians
  • unhinged distance in magic-mm (translation in mm + rotation in degrees)
reachy_mini.utils.interpolation.compose_world_offset
Source
Compose an absolute world-frame pose with a world-frame offset.
  • translations add in world: t_final = t_abs + t_off
  • rotations compose in world: R_final = R_off @ R_abs
This rotates the frame in place (about its own origin) by a rotation defined in world axes, and shifts it by a world translation.
Parameters:
NameTypeDescription
T_abs(4,4) ndarrayAbsolute pose in world frame.
T_off_world(4,4) ndarrayOffset transform specified in world axes (dx,dy,dz in world; dR about world axes).
reorthonormalizeboolIf True, SVD-orthonormalize the resulting rotation to fight drift.
Returns:
NameTypeDescription
T_final(4,4) ndarrayResulting pose in world frame.
reachy_mini.utils.interpolation.InterpolationTechnique
Source
Enumeration of interpolation techniques.
Hardware Configuration
reachy_mini.utils.hardware_config.parser.MotorConfig
Source
Motor configuration.
reachy_mini.utils.hardware_config.parser.SerialConfig
Source
Serial configuration.
reachy_mini.utils.hardware_config.parser.ReachyMiniConfig
Source
Reachy Mini configuration.
reachy_mini.utils.hardware_config.parser.parse_yaml_config
Source
Parse the YAML configuration file and return a ReachyMiniConfig.
Rerun Visualization
reachy_mini.utils.rerun.Rerun
Source
Rerun logging for Reachy Mini.
Methods
log_camera
Source
Log the camera image to Rerun.
log_movements
Source
Log the movement data to Rerun.
set_absolute_path_to_urdf
Source
Set the absolute paths in the URDF file. Rerun cannot read the "package://" paths.
start
Source
Start the Rerun logging thread.
stop
Source
Stop the Rerun logging thread.
reachy_mini.utils.rerun.UrdfEntityPaths
Source
Helper for constructing link/joint entity paths that match the native URDF logger.
Wireless Version Utilities
reachy_mini.utils.wireless_version.utils.call_logger_wrapper
Source
Run a command asynchronously, streaming stdout and stderr to logger in real time.
Parameters:
NameDescription
commandlist or tuple of command arguments (not a string)
loggerlogger object with .info and .error methods
reachy_mini.utils.wireless_version.update.update_reachy_mini
Source
Update reachy_mini package and restart daemon.
Parameters:
NameDescription
loggerLogger for streaming output.
pre_releaseIf True, install pre-release from PyPI (ignored if git_ref set).
git_refIf set, install from this GitHub tag/branch instead of PyPI.
reachy_mini.utils.wireless_version.startup_check.check_and_fix_venvs_ownership
Source
For wireless units, check if files under venvs_path are owned by user pollen and fix if needed.
Parameters:
NameDescription
venvs_pathPath to the virtual environments directory (default: /venvs)
custom_loggerOptional logger to use instead of the module logger
reachy_mini.utils.wireless_version.startup_check.check_and_update_bluetooth_service
Source
info
Check if bluetooth service needs updating and update if different.
Compares the source bluetooth_service.py with the installed version at /bluetooth/bluetooth_service.py. If they differ, copies the new version and restarts the bluetooth service. Also syncs the commands/ folder.
reachy_mini.utils.wireless_version.startup_check.check_and_update_wireless_launcher
Source
info
Check if wireless daemon service needs updating and update if different.
Compares the source reachy-mini-daemon.service with the installed version. If they differ, copies the new version and reloads systemd.
reachy_mini.utils.wireless_version.startup_check.check_and_sync_apps_venv_sdk
Source
info
Check if apps_venv SDK matches daemon install source and sync if needed.
Compares both version AND install source (PyPI vs git ref). If daemon was installed from a git ref, apps_venv will be synced to the same ref.
reachy_mini.utils.wireless_version.update_available.is_update_available
Source
Check if an update is available for the given package.
reachy_mini.utils.wireless_version.update_available.get_pypi_version
Source
Get the latest version of a package from PyPI.
reachy_mini.utils.wireless_version.update_available.get_local_version
Source
Get the currently installed version of a package.
Core Utilities
reachy_mini.utils.create_head_pose
Source
Create a homogeneous transformation matrix representing a pose in 6D space (position and orientation).
Parameters:
NameTypeDescription
xfloatX coordinate of the position.
yfloatY coordinate of the position.
zfloatZ coordinate of the position.
rollfloatRoll angle
pitchfloatPitch angle
yawfloatYaw angle
mmboolIf True, convert position from millimeters to meters.
degreesboolIf True, interpret roll, pitch, and yaw as degrees; otherwise as radians.
Returns:
np.ndarray — A 4x4 homogeneous transformation matrix representing the pose.
URDF Parsing
reachy_mini.utils.parse_urdf_for_kinematics.get_data
Source
Generate the urdf_kinematics.json file.
