Reachy Mini (Wireless) - Setup Guide
The Reachy Mini (Wireless) is the autonomous version powered by a Raspberry Pi 4. It runs independently using its internal battery and Wi-Fi connection.
1. 🔧 Assembly
Reachy Mini comes as a kit. Building it is the first step of your journey!
Assembly Details
  • Time required: 2 to 3 hours.
  • Tools: Everything is included in the box.
  • Instructions: We strongly recommend following the video guide alongside the manual.
Pro Tip
We strongly recommend having the Online Guide or the assembly video open alongside the paper booklet (see below). The online version includes short video extracts for every step, which makes the assembly much easier to understand.
📖 Interactive Digital Guide📺 Full Assembly Video
Assembly Guide
Open Step-by-Step Guide
(Includes short video loops)
Watch on YouTube
Watch on YouTube
(Video with sections for each step)
2. 🛜 First Boot & Wi-Fi Configuration
Once assembled, you need to connect the robot to your Wi-Fi network.
Step 1: Power On
Turn on your Reachy Mini.
Step 2: Connect to Reachy
Wait a few moments. The robot will create a Wi-Fi network named reachy-mini-ap.
  • Password: reachy-mini
  • Or scan the QR Code:
QR-Code reachy-mini-ap
Step 3: Configure Wi-Fi
  • Open your browser and go to: http://reachy-mini.local:8000/settings.
  • Enter your local Wi-Fi credentials (SSID & Password) and click "Connect".
  • Wait a few moments for Reachy Mini to connect to your Wi-Fi network. The access point will disappear once connected. If the connection fails, Reachy Mini will restart the access point, and you can try again.
3. 🔄 Update System
Recommended
Before going further, it is highly recommended to update your robot to the latest version.
  1. Open Settings: Go to http://reachy-mini.local:8000/settings.
  2. Check for Updates: Click the "Check for updates" button.
  3. Install: If a new version is available, follow the on-screen instructions to install it.
4. 🕹️ Next Step: Using the Robot
Now that your robot is online and up to date, you can start controlling it!
👉 Go to the Usage Guide to learn how to:
  • Access the Dashboard.
  • Install and run Apps (like Conversation or Games).
  • Program your Reachy with Python.
5. 💻 Advanced: Connect directly to the internal Raspberry Pi via SSH
SSH Credentials
If you need to connect to Reachy Mini's internal Raspberry Pi via SSH, credentials are:
username: pollen
password: root
Once connected via SSH, you can check the integrity of your Raspberry Pi and robot setup with:
reachyminios_check
❓ Troubleshooting
Encountering an issue? 👉 Check the Troubleshooting & FAQ Guide
Expert Mode
Expert Guides
If you need to reinstall the Raspberry Pi from scratch or create a custom image, follow the expert guides below.
