Advanced: Reflash the Raspberry Pi OS image
Expert Guide Only
This guide explains how to reflash the ReachyMiniOS image to Reachy Mini's CM4. Doing this will factory reset your Reachy Mini.
Most users do not need this. Reachy Mini comes pre-installed. Only follow these steps if you have a broken installation that you couldn't debug.
Download the OS image (and bmap)
First, download the latest OS image and .bmap file from: https://github.com/pollen-robotics/reachy-mini-os/releases
The .bmap file is used by bmaptool (Linux/macOS). If you're flashing with Raspberry Pi Imager (Windows), you only need the OS image file.
Install rpiboot
Linux / macOS
Windows
Download and install the rpiboot GUI from the official Raspberry Pi repository: https://github.com/raspberrypi/usbboot/raw/master/win32/rpiboot_setup.exe
Install a flashing tool
Linux
Install bmaptool:
sudo apt install bmap-tools
Linux users
Linux users can use either bmaptool or Raspberry Pi Imager (the Windows option). Raspberry Pi Imager is generally much slower than bmaptool for this workflow, so prefer bmaptool when available.
macOS
Install bmaptool from the official repository:
python3 -m pip install --user "git+https://github.com/yoctoproject/bmaptool.git"
export PATH="$HOME/.local/bin:$PATH"
bmaptool --version
macOS users
macOS users can use either bmaptool or Raspberry Pi Imager (the Windows option). Raspberry Pi Imager is generally much slower than bmaptool for this workflow, so prefer bmaptool when available.
Windows
Download and install Raspberry Pi Imager: https://www.raspberrypi.com/software/
Setup
Step 1: Shut down the robot completely before proceeding.
Step 2: Start rpiboot
Start rpiboot (it will wait for the robot to be connected):
  • Linux / macOS: run the rpiboot command in your terminal:
    sudo ./rpiboot -d mass-storage-gadget64
  • Windows: run the RPiBoot executable that you installed in the previous step.
Step 3
Set the switch to DOWNLOAD (SW1) on the head PCB:
pcb_usb_and_switch
Step 4: Plug the USB cable (the one shown in the image above, named USB2).
Step 5: Power on the robot.
The internal eMMC should now appear as a mass-storage device.
Unmount and Flash the ISO
Linux
Make sure the device is unmounted before flashing.
Check and Unmount the Device
Your device should be visible as /dev/sdx (something like /dev/sda).
Check mounted partitions by running:
lsblk
If you see bootfs and rootfs like below, it means it is mounted:
sda           8:0    1  14.6G  0 disk
├─sda1 8:1 1 512M 0 part /media/<username>/bootfs
└─sda2 8:2 1 14.1G 0 part /media/<username>/rootfs
Unmount the partitions:
sudo umount /media/<username>/bootfs
sudo umount /media/<username>/rootfs
Flash the ISO
sudo bmaptool copy <reachy_mini_os>.zip --bmap <reachy_mini_os>.bmap /dev/sda
For example with the v0.0.10 release:
sudo bmaptool copy image_2025-11-19-reachyminios-lite-v0.0.10.zip --bmap 2025-11-19-reachyminios-lite-v0.0.10.bmap /dev/sda
macOS
Your device should be visible as /dev/diskX (something like /dev/disk4).
mount
Look for entries like /dev/disk4s1 or /dev/disk4s2 that mention bootfs or rootfs.
Unmount the entire disk (not individual partitions):
diskutil unmountDisk /dev/disk4
Replace /dev/disk4 with your actual disk identifier.
note
unmountDisk unmounts all volumes on the disk (bootfs, rootfs...) at once.
Flash the ISO
Use /dev/rdiskX (note the r prefix!) instead of /dev/diskX. The r prefix provides raw disk access, which is mandatory for the flash command to succeed.
sudo bmaptool copy <reachy_mini_os>.zip --bmap <reachy_mini_os>.bmap /dev/rdiskX
For example with the v0.0.10 release (replace /dev/rdisk4 with your actual disk identifier):
sudo bmaptool copy image_2025-11-19-reachyminios-lite-v0.0.10.zip --bmap 2025-11-19-reachyminios-lite-v0.0.10.bmap /dev/rdisk4
Windows (Raspberry Pi Imager)
Use the Raspberry Pi Imager executable to flash the OS image:
  1. Open Raspberry Pi Imager
  2. Select Raspberry Pi 4 as the device
  3. Select Use custom for the operating system, and provide the downloaded OS image (.zip, or the extracted .img)
  4. Select the only available disk for the storage system (typically RPi-MSD- 0001)
  5. Click Write
Restore Normal Boot Mode
Step 1: Power off the robot
Step 2: Move the switch back to DEBUG
Step 3: Disconnect the USB cable
Step 4: Power the robot back on
Check that Everything Is Working
Connect your computer to the robot's WiFi hotspot:
  • Network name: reachy-mini-ap
  • Password: reachy-mini
SSH into the robot:
ssh [email protected]
# password: root
Then run:
reachyminios_check
success
If successful, you should see:
Image validation PASSED
