Core Concepts & Architecture
Understanding how Reachy Mini works under the hood will help you build robust applications and debug issues.
Software Architecture
Reachy Mini uses a Client-Server architecture:
  1. The Daemon (Server):
    • Runs on the computer connected to the robot (or the simulation).
    • Handles hardware I/O (USB/Serial), safety checks, and sensor reading.
    • Exposes a REST API (localhost:8000) and WebSocket.
  2. The SDK (Client):
    • Your Python code (reachy_mini package).
    • Connects to the Daemon over the network.
    • Advantage: You can run your AI code on a powerful server while the Daemon runs on a Raspberry Pi connected to the robot.
Coordinate Systems
When moving the robot, you will work with two main reference frames:
1. Head Frame
Located at the base of the head. Used for goto_target and set_target commands.
Reachy Mini Head Frame
2. World Frame
Fixed relative to the robot's base. Used for look_at_world commands.
Reachy Mini World Frame
Safety Limits ⚠️
Reachy Mini has physical and software limits to prevent self-collision and damage. The SDK will automatically clamp values to the closest valid position.
Joint / AxisLimit Range
Head Pitch/Roll[-40°, +40°]
Head Yaw[-180°, +180°]
Body Yaw[-160°, +160°]
Yaw DeltaMax 65° difference between Head and Body Yaw
Motor Modes
You can change how the motors behave:
  • mini.enable_motors(): Stiff. Holds position.
  • mini.disable_motors(): Limp. No power.
  • mini.enable_gravity_compensation(): "Soft" mode. You can move the head by hand, and it will stay where you leave it. (Only works with the Placo kinematics backend.)
Next Steps
