Real-time YOLO object detection using reCamera based on Cpp
This document demonstrates how to implement real-time photo capture, YOLO object detection, and result access by HTTP with C++ based on cross-compilation on reCamera terminals. This approach avoids the overheating issues encountered when using Node-RED on reCamera. You can refer to this document to modify the C++ code for customized computer vision applications.
Environment Preparation
Pre-compilation
First, you need to refer to the "Develop with C/C++" document to configure the cross-compilation environment on your linux. Note: Reconfigure the path after each boot:
export SG200X_SDK_PATH=$HOME/recamera/sg2002_recamera_emmc/
export PATH=$HOME/recamera/host-tools/gcc/riscv64-linux-musl-x86_64/bin:$PATH
Then,download the Realtime_detection_http project, and compile it.
cd Realtime_detection_http/
mkdir build && cd build
cmake ..
make
The presence of the green executable file Realtime_detection_http in the build directory indicates successful compilation:
Then open the reCamera terminal, and copy the executable file to the reCamera terminal directory.
sudo scp Realtime_detection_http [email protected]:/home/recamera/
ReCamera Preparation
1.Download the YOLOv11 which has been deployed from On Device Models, then copy the model's .cvimodel file to your reCamera terminal:/home/recamera/. 2.Before executing the code, please access the reCamera workspace to terminate the process (refer to Develop with c/c++) to prevent memory consumption. 3.Then navigate to /etc/init.d/, copy both the S93sscma-supervisor and S91sscma-node folders to /home/recamera/ or another location for backup, and delete the original S93sscma-supervisor and S91sscma-node folders to prevent memory consumption and program occupation.
cd /etc/init.d/
sudo scp S93sscma-supervisor /home/recamera/
sudo scp S91sscma-node /home/recamera/
sudo rm -r S93sscma-supervisor
sudo rm -r S91sscma-node
Run the program
Run the program as administrator under the /home/recamera/ on the reCamera terminal:
sudo ./Realtime_detection_http
Results
The terminal displays the following, indicating normal program operation:
You can access http://192.168.42.1/modeldetector via web browser or Postman.The reCamera will immediately capture a photo and return objects detected by YOLOv11. Browser:
Postman:
The returned information includes the following data:
- Code:1 (Running)
- Msg: Error messages
- Initialize_camera_duration:Camera initialization duration is displayed only during the first access.
- Initialize_model_duration:Model initialization duration is displayed only during the first access.
- Data:
- Score: Detection confidence score (0-1)
- Target: Name of detected object
- Box:[x1, y1, x2, y2]: Detection box coordinates (in pixels representing [left, top, right, bottom] edges)
- Center:[x, y]: Normalized center position of the detection box (ratio relative to image width/height)
- Size:[w, h]: Normalized width and height of the detection box (ratio relative to image dimensions)
- Release_duration: Time taken to clear camera cache (ms)
- Capture_duration: Image acquisition duration (ms)
- Image_preprocessing_duration: Image preparation before inference duration (ms)
- Detection_duration: Model detection duration (ms) (Including Preprocessing,Inference,Postprocessing)
- Duration: Total program execution time (ms)
- Timestamp: Unix timestamp
The terminal will display:
- Camera initialization parameters:
- Resolution: 1920×1080
- Frame rate: 5 fps
- Capture channel: Channel 2
- Captured image size (e.g. Jpeg size: 216149 (pixels))
- Memory usage (MB) during different steps:
- Pre-capture (Memory usage)
- Releasing (Memory usage_during_)
- Post-capture (Memory usage_after)
- After image preprocessing (Memory usage_before_model)
- After model detection (Memory usage_after_model)
- Model detection duration (ms)
- Preprocessing (e.g.pre: 9ms)
- Inference (e.g.infer: 40ms)
- Postprocessing (e.g.post:395ms)
On the reCamera terminal, detected images can be automatically saved:
You can continuously access it with your device to obtain real-time detection results for applications such as intelligent security and surveillance.
You can modify the returned message's format in registerModelDetector() (Realtime_detection_http/src/http.cpp) and model_detector() (Realtime_detection_http/src/model_detector.cpp). You can also use your own deployed model when calling the initialize_model(const std::string& model_path) in registerModelDetector(), and modify the camera initialization settings in initialize_camera()(Realtime_detection_http/src/model_detector.cpp):
After detection, you can press Ctrl+C to terminate the operation.The program will stop the camera.
For more details, please refer to our GitHub repository.
