Getting Started with Pinocchio and MeshCat for reBot Arm B601-DM
traj_sim_geodesic
License: MITPython VersionPlatformPinocchio
6-DOF Robotic Arm · Multi-Motor Support · Kinematics Solver · Trajectory Planning · Fully Open Source
📖 Introduction
reBotArm Control is a Python control library for the reBot Arm B601 robotic arm, providing a complete solution from low-level motor control to high-level kinematics computation.
✨ Core Features
  • 🦾 Dual Model Support — B601-DM (Damiao motors) and B601-RS (RobStride motors)
  • 🧮 Kinematics Solver — Forward/Inverse kinematics based on Pinocchio
  • 🛤️ Trajectory Planning — SE(3) geodesic trajectory + CLIK tracking
  • 🔧 Flexible Configuration — YAML configuration file for quick hardware adaptation
⚙️ Quick Start
Requirements
ItemRequirement
Python3.10+
Operating SystemUbuntu 22.04+
Communication InterfaceUSB2CAN Serial Bridge or CAN Interface
Installation Steps
Step 1. Install uv (if not installed)
curl -LsSf https://astral.sh/uv/install.sh | sh
Step 2. Sync Environment (Install All Dependencies)
git clone https://github.com/vectorBH6/reBotArm_control_py.git
cd reBotArm_control_py
uv sync
uv sync will automatically create a virtual environment (if it doesn't exist) and install all dependencies according to pyproject.toml and uv.lock.
🔌 Hardware Configuration
Default: Damiao USB2CAN Serial Bridge
reBot Arm B601-DM uses the Damiao USB2CAN serial bridge module by default.
Hardware Connection:
  1. Connect the USB2CAN module to your computer via USB cable
  2. The system will automatically recognize it as /dev/ttyACM0 device
Configuration Verification:
# Check device
ls /dev/ttyACM0
# Scan motors
motorbridge-cli scan --vendor damiao --transport dm-serial \
--serial-port /dev/ttyACM0 --serial-baud 921600
Optional: Standard CAN Interface
Using other USB-CAN adapters (CANable, PCAN, etc.):
# Start CAN interface
sudo ip link set can0 up type can bitrate 500000
# Verify interface
ip -details link show can0
Motor Brand Configuration
Motor BrandTransmissionConfigurationBaud Rate
DamiaoSerial Bridgedm-serial921600
DamiaoCAN Interfacesocketcan500000
RobStrideCAN Interfacesocketcan500000
  • For Damiao motors using serial bridge, must set --transport dm-serial
  • Feedback ID rule: feedback_id = motor_id + 0x10
📁 Project Structure
reBotArm_control_py/
├── config/ # Configuration files
│ └── robot.yaml # Joint parameter configuration
├── example/ # Example programs
│ ├── Debug Tools/
│ │ ├── 1_damiao_text.py # Single motor console
│ │ └── 2_zero_and_read.py # Zero calibration
│ ├── Kinematics Tests/
│ │ ├── 5_fk_test.py # Forward kinematics
│ │ └── 6_ik_test.py # Inverse kinematics
│ ├── Real Machine Control/
│ │ ├── 7_arm_ik_control.py # IK real-time control
│ │ ├── 8_arm_traj_control.py # Trajectory planning
│ │ └── 9_gravity_compensation.py # Gravity compensation
│ └── sim/ # Simulation tools
├── reBotArm_control_py/ # Core library
│ ├── actuator/ # Actuator module
│ ├── kinematics/ # Kinematics module
│ ├── controllers/ # Controller module
│ └── trajectory/ # Trajectory planning module
├── urdf/ # URDF model
└── README.md
🎮 Example Programs
Debug Tools
1️⃣ Single Motor Console (1_damiao_text.py)
Direct motorbridge SDK single motor testing with three control modes.
Usage:
uv run python example/1_damiao_text.py
Interactive Commands:
CommandDescription
mit <pos_deg> [vel kp kd tau]MIT mode
posvel <pos_deg> [vlim]POS_VEL mode
vel <vel_rad_s>Velocity mode
enable / disableEnable/Disable
set_zeroSet zero position
stateView state
2️⃣ Zero Calibration & Angle Monitor (2_zero_and_read.py)
Automatically set all joint zeros and display joint angles in real-time.
Usage:
uv run python example/2_zero_and_read.py
Kinematics Tests
5️⃣ Forward Kinematics Test (5_fk_test.py)
Calculate end-effector pose from joint angles.
Input: 6 joint angles (degrees)
Output:
  • End-effector position (X, Y, Z) — Unit: meters
  • Rotation matrix (3×3)
  • Euler angles (Roll/Pitch/Yaw) — Unit: degrees
Example:
uv run python example/5_fk_test.py
> 0 0 0 0 0 0
> 45 -30 15 -60 90 180
6️⃣ Inverse Kinematics Test (6_ik_test.py)
Solve joint angles from desired end-effector pose.
Input Format:
  • Position only: <x> <y> <z> (meters)
  • Position + Orientation: <x> <y> <z> <roll> <pitch> <yaw> (degrees)
Example:
uv run python example/6_ik_test.py
> 0.25 0.0 0.15 # Position only
> 0.25 0.0 0.15 0 0 0 # Position + Orientation
Permission Setup
Before running real machine control examples, you need to set device permissions:
# Set serial device permission (Damiao USB2CAN)
sudo chmod 666 /dev/ttyACM0
# Or for CAN interface (e.g., can0)
sudo chmod 666 /dev/can0
7️⃣ IK Real-time Control (7_arm_ik_control.py)
Real-time end-effector control based on IK solver.
CommandDescription
x y z [roll pitch yaw]Target end-effector pose
stateView current/target state
posCurrent end-effector position
q/quit/exitQuit
Usage:
uv run python example/7_arm_ik_control.py
> 0.3 0.0 0.2
> 0.3 0.1 0.25 0 0.5 0
8️⃣ Trajectory Planning Control (8_arm_traj_control.py)
SE(3) geodesic trajectory planning + CLIK tracking.
Input Format:
x y z [roll pitch yaw] [duration]
Parameters:
  • x, y, z: Target position (meters)
  • roll, pitch, yaw: Target orientation (radians)
  • duration: Movement duration (seconds), default 2.0s
Usage:
uv run python example/8_arm_traj_control.py
> 0.3 0.0 0.3 0 0.4 0 2.0
9️⃣ Gravity Compensation Control (9_gravity_compensation.py)
Compensates for joint gravity using Pinocchio dynamics model.
Control Law:
tau = g(q)          — Gravity feedforward
pos = current motor position — Joint position follows current position
kp = 2, kd = 1 — Unified stiffness/damping for all motors
Expected Behavior:
  • The robotic arm can "float" in any posture
  • Won't fall due to its own weight when released
  • Can be manually moved to any position
Usage:
uv run python example/9_gravity_compensation.py
Output:
  • Real-time display of expected torque for each joint (N·m)
  • Press Ctrl+C to stop and disconnect
📄 License
This project is open source under the MIT License.
☎ Contact Us
🌟 If this project helps you, please give us a Star!
