reBot Arm B601-DM ROS2 Integration
reBot Arm B601-DM
License: MITROS2 Humble | JazzyPython VersionVersion v0.2.3Platform
ROS2 Control · RViz Visualization · MoveIt2 Support
This tutorial shows how to run the ROS2 control workspace rebotarm_ros2 for the reBot Arm B601-DM. The workspace wraps the low-level reBotArm_control_py Python SDK into ROS2 topics, services, and actions, making it easier to integrate upper-level planning, visual grasping, RViz visualization, and custom application development.
note
This tutorial uses Ubuntu 24.04 + ROS2 Jazzy + Python 3.12 as the main reference environment. ROS2 Humble / Ubuntu 22.04 can follow the same workflow with the corresponding ROS2 distribution.
Project Features​
  1. Standard ROS2 Interfaces
    Provides common ROS2 interfaces such as /joint_states, FollowJointTrajectory, GripperCommand, and MoveToPose, making it easier to integrate with MoveIt2, visual grasping pipelines, or task-level systems.
  2. Ready-to-use Kinematics, Trajectory, and Gravity Compensation Nodes
    Provides out-of-the-box forward/inverse kinematics, trajectory execution, gravity compensation, and RViz visualization support.
  3. MoveIt 2 Integration
    Includes complete MoveIt 2 configuration and application demos, supporting the RViz MotionPlanning plugin for simulated planning and real hardware execution.
Specifications​
The hardware for this tutorial is provided by Seeed Studio.
ParameterSpecification
Robot Arm ModelreBot Arm B601-DM
Degrees of Freedom6-DOF + Gripper
Motor VersionDAMIAO motor version
CommunicationCAN Bus via USB2CAN serial bridge
Default Serial Port/dev/ttyACM0
Recommended SystemUbuntu 24.04 + ROS2 Jazzy + Python 3.12
Reference SystemUbuntu 22.04 + ROS2 Humble + Python 3.10
Bill of Materials (BOM)​
ComponentQuantityIncluded
reBot Arm B601-DM Robotic Arm1✅
Gripper1✅
USB2CAN Serial Bridge1✅
Power Adapter (24V)1✅
USB-C / Communication Cable1✅
Ubuntu Host PC1Self-prepared
Wiring​
  1. Connect the USB2CAN serial bridge to the robot arm CAN bus.
  2. Connect the 24V power supply and plug the USB2CAN adapter into the host PC.
  3. Confirm that the host recognizes the serial device:
ls /dev/ttyACM*
If you need to temporarily grant serial port permission:
sudo chmod 666 /dev/ttyACM0
It is recommended to add the current user to the dialout group instead. Log out and log back in for the change to take effect:
sudo usermod -a -G dialout $USER
Environment Requirements​
ItemRecommended Requirement
Operating SystemUbuntu 24.04, Ubuntu 22.04 can be used as reference
ROS2Jazzy, Humble can be used as reference
PythonSystem Python. Jazzy usually uses 3.12, while Humble usually uses 3.10
Installation Steps​
Step 0. Complete Basic Robot Arm Setup​
Before starting the ROS2 integration, please complete the reBot Arm B601-DM Getting Started Guide, including assembly, motor ID configuration, zero-position initialization, and basic connectivity verification.
Step 1. Install the ROS2 Version for Your Ubuntu System​
Please refer to the official ROS2 documentation:
If you are using Ubuntu 24.04, you should install ROS 2 Jazzy.
If you are using Ubuntu 22.04, you should install ROS 2 Humble.
Step 2. Install Build Tools and ROS Dependencies​
Install colcon, pip, Git, and the ROS packages required by this workspace:
sudo apt update
sudo apt install -y python3-colcon-common-extensions python3-pip git
sudo apt install -y \
ros-jazzy-control-msgs \
ros-jazzy-trajectory-msgs \
ros-jazzy-tf-transformations \
ros-jazzy-robot-state-publisher \
ros-jazzy-rviz2 \
ros-jazzy-pinocchio
Verify the installation:
source /opt/ros/jazzy/setup.bash
python3 -c "import pinocchio; print('pinocchio', pinocchio.__version__)"
If you use ROS2 Humble, replace the ros-jazzy-* package names with ros-humble-* and source /opt/ros/humble/setup.bash.
Step 3. Clone the Code Repository​
This tutorial uses ~/rebotarm_ros2 as the workspace directory and the official Seeed-Projects repository:
cd ~
git clone https://github.com/Seeed-Projects/reBotArmController_ROS2.git rebotarm_ros2
cd ~/rebotarm_ros2
If you cloned into another directory, replace every ~/rebotarm_ros2 below with its absolute path. Relative paths such as third_party, src, and install are relative to the workspace root.
Step 4. Install motorbridge​
Install motorbridge from the official PyPI source:
python3 -m pip install --user --break-system-packages --index-url https://pypi.org/simple motorbridge
Step 5. Get the Low-level SDK​
cd ~/rebotarm_ros2
mkdir -p third_party
git clone https://github.com/Seeed-Projects/reBotArm_control_py.git third_party/reBotArm_control_py
Step 6. Build the Workspace​
Code version
The status heartbeat, gravity-compensation exit detection, and rectangle trace described here correspond to ROS2 controller PR #7. Before using these behaviors, make sure your checkout includes those changes, then rebuild and restart the control node.
cd ~/rebotarm_ros2
colcon build --symlink-install
source install/setup.bash
Verify the executable entries:
ros2 pkg executables rebotarmcontroller
Expected entries include:
rebotarmcontroller reBotArmController
rebotarmcontroller GravityCompensation
rebotarmcontroller GripperControl
rebotarmcontroller MoveTo
rebotarmcontroller MoveToPose
Quick Start​
caution
Before using the robot, note the following: The arm controller has a high degree of freedom. Before enabling the controller or powering the arm, make sure the workspace is clear of people and obstacles. Review every motion command carefully to avoid accidents. Dangerous operation is strictly prohibited; you are responsible for any consequences.
Start the Full System​
In each new terminal, enter the workspace and source both ROS2 and the workspace environment. Commands below use /opt/ros/jazzy/setup.bash; for ROS2 Humble, use /opt/ros/humble/setup.bash instead.
The full bringup launches:
  • reBotArmController control node
  • robot_state_publisher
  • Optional RViz
cd ~/rebotarm_ros2
ros2 launch rebotarm_bringup bringup.launch.py model:=dm channel:=/dev/ttyACM0 #Do not open the RViz visualization interface when starting communication
Every time you open a new terminal, you need to run the following commands first
cd ~/rebotarm_ros2
If your serial port is not /dev/ttyACM0, replace it with the actual device name:
ros2 launch rebotarm_bringup bringup.launch.py model:=dm channel:=/dev/ttyACM1
Start RViz Visualization​
ros2 launch rebotarm_bringup bringup.launch.py model:=dm channel:=/dev/ttyACM0 use_rviz:=true   #Open the RViz visualization interface when starting communication
If the model appears too small in RViz, adjust the view from the Views panel on the left:
  • Set Target Frame to base_link
  • Adjust Distance, for example to 1.0 or 1.5
  • Use the mouse wheel to zoom
  • Confirm that Fixed Frame is set to base_link
Start Only the Control Node​
If URDF and RViz are not needed:
ros2 launch rebotarm_bringup driver.launch.py model:=dm channel:=/dev/ttyACM0
You can also run the node directly:
ros2 run rebotarmcontroller reBotArmController
Unlike driver.launch.py, which passes configuration files from rebotarm_bringup/config, running the controller directly falls back to the default SDK arm configuration. For normal use, launching through ROS is recommended.
ROS2 Namespace​
The default namespace is:
/rebotarm
Therefore, all topics, services, and actions are prefixed with /rebotarm, for example:
/rebotarm/joint_states
/rebotarm/enable
/rebotarm/move_to_pose
If you need multiple robot arms or want to run alongside other ROS2 systems, you can change the namespace at launch time:
ros2 launch rebotarm_bringup bringup.launch.py model:=dm arm_namespace:=left_arm
In this case, /rebotarm/joint_states becomes /left_arm/joint_states.
Common APIs​
Status Topics​
APITypeDescription
/rebotarm/joint_statessensor_msgs/msg/JointState6-axis joint positions, velocities, and efforts
/rebotarm/arm_statusrebotarm_msgs/msg/ArmStatusControl mode, enabled state, state machine, and error codes
/rebotarm/joints/<joint>/staterebotarm_msgs/msg/JointMotorStateSingle-joint motor state
/rebotarm/gripper/staterebotarm_msgs/msg/JointMotorStateGripper motor state
Examples:
ros2 topic echo /rebotarm/joint_states --once
ros2 topic echo /rebotarm/arm_status --once
--once exits after receiving one message. The control node publishes arm_status every second and on startup or state changes, so no extra QoS options are needed. After rebuilding changed source, restart the control node. If no output arrives, press Ctrl+C to stop the check and confirm that the control node in terminal A is running.
Services​
APITypeDescription
/rebotarm/enablestd_srvs/srv/TriggerEnable the robot arm
/rebotarm/disablestd_srvs/srv/TriggerDisable the robot arm
/rebotarm/safe_homestd_srvs/srv/TriggerMove back to the safe home position
/rebotarm/set_moderebotarm_msgs/srv/SetModeSwitch between mit, pos_vel, and vel
/rebotarm/set_zerorebotarm_msgs/srv/SetZeroSet zero position for all joints or a single joint
/rebotarm/move_to_pose_ikrebotarm_msgs/srv/MoveToPoseIKIK pre-check and target joint solution
/rebotarm/gripper/setrebotarm_msgs/srv/SetGripperSet gripper motor position in rad
/rebotarm/gravity_compensation/startstd_srvs/srv/TriggerStart gravity compensation
/rebotarm/gravity_compensation/stopstd_srvs/srv/TriggerStop gravity compensation
Actions​
APITypeDescription
/rebotarm/move_to_poserebotarm_msgs/action/MoveToPoseEnd-effector pose motion
/rebotarm/follow_joint_trajectorycontrol_msgs/action/FollowJointTrajectoryStandard joint trajectory compatible entry point
/rebotarm/gripper/commandcontrol_msgs/action/GripperCommandStandard gripper action
Basic Control Examples​
1. Start the Control Node and Check Its State​
Terminal A: start the control node and keep it running. It handles topic, service, and action requests continuously. If bringup.launch.py or driver.launch.py is already running from Quick Start, keep that terminal open; do not start a second driver for the same arm.
cd ~/rebotarm_ros2
After reBotArmController started appears, keep terminal A running and use another terminal for subsequent commands.
Terminal B: load the environment and check that state messages arrive.
cd ~/rebotarm_ros2
Each --once command exits after one message. Continue with steps 2–5 in terminal B. To monitor continuously, load the same environment in an additional terminal and run ros2 topic echo /rebotarm/joint_states. A continuous topic listener is not required to send commands; the driver in terminal A must remain running.
The control node automatically enables the arm and starts its control loop after connecting. Normally, enabled and control_loop_active in arm_status are both true, so no manual /rebotarm/enable call is needed. If you previously disabled the arm, first confirm that no trajectory, homing, or gravity-compensation task is active, then re-enable it:
# Only needed to resume control after the arm was disabled
ros2 service call /rebotarm/enable std_srvs/srv/Trigger "{}"
2. Move to an End-effector Pose​
ros2 action send_goal /rebotarm/move_to_pose rebotarm_msgs/action/MoveToPose \
"{target_pose: {position: {x: 0.30, y: 0.0, z: 0.30}, orientation: {x: 0.0, y: 0.0, z: 0.0, w: 1.0}}, duration: 2.0}"
3. Send a Joint Target​
ros2 action send_goal /rebotarm/follow_joint_trajectory \
control_msgs/action/FollowJointTrajectory \
"{trajectory: {joint_names: ['joint1','joint2','joint3','joint4','joint5','joint6'],
points: [{positions: [0.1,0,0,0,0,0], time_from_start: {sec: 5}}]}}"
4. Safe Home and Disable​
ros2 service call /rebotarm/safe_home std_srvs/srv/Trigger
ros2 service call /rebotarm/disable std_srvs/srv/Trigger
Demo Examples​
Keep the control node in terminal A running and use terminal B for the examples below. Do not repeat the launch command when a driver is already running. In each new terminal, load the environment first:
cd ~/rebotarm_ros2
MoveTo and MoveToPose can run directly after the control node starts. GravityCompensation and GripperControl call /rebotarm/enable internally; do not manually enable the arm before starting them. Run examples one at a time, waiting for each to finish before starting another.
Joint Motion Example​
Control all 6 joints at once. The unit is rad:
ros2 run rebotarmcontroller MoveTo -- \
0.20 -0.20 -0.20 -0.20 0.10 -0.10 \
--duration 8.0
Control only one joint:
ros2 run rebotarmcontroller MoveTo -- --joint joint3 --position -0.20 --duration 5.0
End-effector Pose Example​
ros2 run rebotarmcontroller MoveToPose -- --x 0.30 --y 0.0 --z 0.30 --qw 1.0 --duration 2.0
Gravity Compensation Example​
ros2 run rebotarmcontroller GravityCompensation
The script first calls /rebotarm/enable, then starts gravity compensation. On Ctrl+C, it calls /rebotarm/safe_home followed by /rebotarm/disable. safe_home handles leaving gravity compensation before moving to the safe home position.
If the control node in terminal A closes, the gravity-compensation program in terminal B also exits automatically. It also exits if the status heartbeat is missing for about 3 seconds, without sending duplicate homing or disable requests. When RS is already in its default MIT mode, entering gravity compensation preserves the enabled state. DM retains its existing mode-switch procedure when changing from position/velocity mode to MIT.
Alternatively, call the services manually; do not run this sequence alongside the script. A normally started control node does not need another enable request. If it was disabled, follow Basic Control Examples to re-enable it first.
ros2 service call /rebotarm/gravity_compensation/start std_srvs/srv/Trigger
ros2 service call /rebotarm/gravity_compensation/stop std_srvs/srv/Trigger
Interactive Gripper Example​
ros2 run rebotarmcontroller GripperControl
On exit, the script closes the gripper and calls /rebotarm/disable. Re-enable the arm before sending further manual gripper commands. Running this script again enables the arm internally.
After launch, enter:
o / open    Open the gripper
c / close Close the gripper
q / quit Quit
Configuration​
Default configuration files are located at:
src/rebotarm_bringup/config/
FileDescription
arm.yamlMotor, feedback ID, and control parameters for the 6 arm joints
gripper.yamlGripper motor ID, feedback ID, vendor, and control parameters
driver_params.yamlROS parameter examples
Common launch parameters:
ParameterDefaultDescription
arm_configBuilt-in arm.yaml from bringupArm configuration path
gripper_configBuilt-in gripper.yaml from bringupGripper configuration path
channelEmpty stringUse YAML by default. Override the serial port when non-empty
joint_state_rate100.0Publish rate of /rebotarm/joint_states
cmd_arbitrationrejectLow-level command arbitration during arm trajectory execution. reject or preempt; gripper low-level commands do not preempt arm trajectories
arm_namespacerebotarmROS namespace prefix
frame_idbase_linkRobot arm base frame
ee_frame_idend_linkEnd-effector frame
use_rvizfalseWhether to start RViz
Low-level Command Topics​
The ROS2 workspace also provides low-level motor debugging topics:
APITypeDescription
/rebotarm/joints/<joint>/cmd/mitrebotarm_msgs/msg/JointMitCmdSingle-joint MIT raw command
/rebotarm/joints/<joint>/cmd/pos_velrebotarm_msgs/msg/JointPosVelCmdSingle-joint position-velocity raw command
/rebotarm/joints/<joint>/cmd/velrebotarm_msgs/msg/JointVelCmdSingle-joint velocity raw command
/rebotarm/gripper/cmd/mitrebotarm_msgs/msg/JointMitCmdGripper MIT raw command
/rebotarm/gripper/cmd/pos_velrebotarm_msgs/msg/JointPosVelCmdGripper position-velocity raw command
/rebotarm/gripper/cmd/velrebotarm_msgs/msg/JointVelCmdGripper velocity raw command
caution
Low-level command topics are intended for debugging and experiments. They do not perform IK, trajectory planning, or URDF limit checks. For application-level motion, prefer services and actions such as /move_to_pose, /follow_joint_trajectory, and /gripper/set.
MoveIt 2​
MoveIt 2 is the motion planning framework used here for inverse kinematics, collision checking, trajectory planning and execution. The demos are separated into their own package so application flows stay isolated from the base driver. For more details, see the official MoveIt 2 Documentation.
MoveIt-related content is split into two packages:
PackagePurpose
rebotarm_moveit_configRobot model, SRDF, kinematics, joint limits, controller and RViz config
rebotarm_moveit_demosApplication demos based on MoveIt 2
The MoveIt environment uses simulated hardware through ros2_control and move_group for planning and execution. It is intended for validating the model, IK, trajectory planning and demo flow in RViz.
This repository also supports real hardware. Before connecting real hardware, make sure the arm zero configuration, joint directions, joint limits, velocity limits and gripper range are all correct, or keep the default repository configuration.
MoveIt Environment Setup​
Make sure the ROS2 environment is available first. You can install packages for the currently sourced ROS distribution through ROS_DISTRO:
sudo apt update
ros-${ROS_DISTRO}-moveit \
ros-${ROS_DISTRO}-moveit-configs-utils \
ros-${ROS_DISTRO}-moveit-kinematics \
ros-${ROS_DISTRO}-moveit-planners-ompl \
ros-${ROS_DISTRO}-moveit-simple-controller-manager \
ros-${ROS_DISTRO}-ros2-control \
ros-${ROS_DISTRO}-ros2-controllers \
ros-${ROS_DISTRO}-xacro
The MoveIt config and demos are included in this workspace. After installing dependencies, rebuild the workspace:
cd ~/rebotarm_ros2
Verify the MoveIt packages and demo entry points:
ros2 pkg list | grep rebotarm_moveit
ros2 pkg executables rebotarm_moveit_demos
rebotarm_moveit_demos draw_square
rebotarm_moveit_demos pick_place
Use MoveIt​
MoveIt planning can be used through the RViz GUI or through ROS nodes, in both simulation and real scenes.
Use MoveIt in simulation​
MoveIt uses the ros2_control virtual hardware interface for RViz simulation:
cd ~/rebotarm_ros2
ros2 launch rebotarm_moveit_config demo.launch.py model:=dm
By default this starts:
  • move_group
  • ros2_control_node
  • joint_state_broadcaster
  • rebotarm_controller
  • gripper_controller
  • RViz with the MoveIt MotionPlanning plugin
RViz opens automatically and loads the robot URDF model. You can control motion through the panel on the left side of the GUI.
To run the MoveIt environment without RViz:
ros2 launch rebotarm_moveit_config demo.launch.py model:=dm use_rviz:=false
Use MoveIt with reBotArm hardware​
For the real robot, first start the controller with the hardware interface instead of the virtual controller, then start the hardware MoveIt environment:
In another terminal:
cd ~/rebotarm_ros2
ros2 launch rebotarm_moveit_config hardware.launch.py model:=dm
To repeat: before running any demo on real hardware, make sure the workspace is clear of people and obstacles, verify the planned path in RViz, and be ready to stop the controller at any time.
Set a Goal and Execute in RViz​
  1. In MotionPlanning → Planning, set Start State to <current> to plan from current joint feedback. If it already shows <current>, select home, then switch back to <current> and wait for the state to update.
  2. Set Goal State to home, then open Joints to adjust the target. If home is already selected, choose another option and select home again. Confirm that the table heading says Group joints of goal state before editing. If it says Group joints of start state, you are editing the start; return to Planning and select Goal State again.
  3. For an initial simulation check, set only goal joint1 to about 10° and leave the other joints at zero. Rotational joint values in the Joints editor use degrees; ROS joint states and trajectories use radians.
  4. Click Plan, inspect the preview, then click Execute. If the arm state changes after planning, plan again from the current state.
In the ROS2 Humble RViz plugin, Joints edits whichever start or goal state was most recently updated. After setting Start State or finishing execution, confirm Group joints of goal state before editing again.
The cyan sphere and red, green, and blue rings are end-effector interaction controls for manual planning. In the lower-left Displays panel, expand MotionPlanning → Planning Request:
  • Drag the end effector manually: disable Query Start State and enable Query Goal State to edit the goal.
  • Run rectangle or pick-place scripts: disable both Query Start State and Query Goal State to hide the sphere and rings. Enable Query Goal State again to resume manual dragging.
  • Keep the robot and trace visible: keep PlanningScene and RectangleTrace enabled. Set the RectangleTrace topic to /draw_square/markers. If an older RViz window has no trace display, choose Add → By display type → MarkerArray and set its Topic to /draw_square/markers, or restart MoveIt to load the updated RViz configuration.
If execution reports Invalid Trajectory: start point deviates from current robot state more than 0.05, followed by failed or timeout reached, the trajectory start does not match current joint feedback. In this error, expected is the trajectory start and current is the feedback, rather than the final goal. Reset the start, confirm you are editing the goal, and replan. Increasing execution timeouts or relaxing the start tolerance does not fix this mismatch.
Use demo.launch.py for simulation, or the hardware driver plus hardware.launch.py for the real arm. Do not run both MoveIt environments together. To inspect joint-state publishers, run:
ros2 topic info /joint_states --verbose
ros2 topic info /rebotarm/joint_states --verbose
Run the Draw-square Demo​
This example uses mock simulation: a simulated ros2_control hardware interface displays the robot and its motion in RViz without simulating physical contact. The demo connects to the running MoveIt environment. model:=dm selects the robot model; it does not select simulation or real hardware.
1. Terminal A: start simulation and keep it running. If this simulation is already running, do not launch it again:
cd ~/rebotarm_ros2
For ROS2 Humble, replace jazzy with humble in these and subsequent commands. The demo drives the real arm only when you started the hardware driver and hardware.launch.py as described above. Do not run both environments together.
2. Terminal B: run the rectangle demo. After changing demo code, run colcon build --symlink-install --packages-select rebotarm_moveit_demos rebotarm_moveit_config from the workspace and source the environment again. You do not need to click Plan or Execute in RViz:
cd ~/rebotarm_ros2
ros2 launch rebotarm_moveit_demos draw_square.launch.py model:=dm
draw_square first closes the gripper. After confirming success, it resets the arm, moves through the four corners of a coplanar rectangle, and returns to the first corner. If the gripper interface is unavailable or closing fails, the demo stops.
In RViz, the thin cyan line is the reference rectangle; the yellow line is the actual gripper_tcp motion sampled from TF. Recording starts after the first corner is reached, excluding the reset and approach motions. Running the demo again clears the previous trace. The demo uses joint-space planning between corners, so the actual motion is not guaranteed to follow the four straight reference edges.
Default parameters are in:
src/rebotarm_moveit_demos/config/draw_square.yaml
Common parameters:
ParameterDescription
start_pointJoint reset position before the demo starts
closed_gripper_positionSimulated single-side gripper joint position when closed, default 0.0
hardware_closed_gripper_positionHardware gripper motor position when closed, default 0.0; verify hardware limits before use
rectangle_centerRectangle center in base_link
rectangle_width / rectangle_heightRectangle dimensions in meters
tcp_rpyTCP orientation, defaulting to a downward-facing gripper
tcp_yaw_offsetsAlternative IK yaw values used to avoid large joint6 wraps
Run the Pick-place Demo​
Keep the mock simulation in terminal A running. After the rectangle demo finishes, run the following in terminal B. Keep both Query Goal State and Query Start State disabled in RViz; do not click Plan or Execute.
If you started the hardware driver and hardware.launch.py instead, the same command drives the real arm. The pick-place demo does not start or switch between simulation and hardware environments:
cd ~/rebotarm_ros2
ros2 launch rebotarm_moveit_demos pick_place.launch.py model:=dm
src/rebotarm_moveit_demos/config/pick_place.yaml
Common parameters:
ready_pointReady joint position used before and after pick/place
pick_positionObject bottom-center position in base_link
pick_tcp_rpy / place_tcp_rpyTCP orientation for pick and place
object_dimensionsPlanning-scene object dimensions in meters
max_gripper_widthMaximum total gripper opening, default 0.09m
open_gripper_position / closed_gripper_positionSimulated single-side gripper joint open/close positions
hardware_open_gripper_position / hardware_closed_gripper_positionHardware gripper motor open/close positions
grasp_gripper_to_object_widthCompute the grasp position from object width
In mock simulation, pick_place adds a virtual object to the planning scene. Scene attachment and detachment make the object follow the gripper; this does not simulate physical contact or grasping force.
pick_place opens the gripper, moves to the pick pose, closes the gripper, moves to the place pose, and releases the object. Simulated gripper joint positions and real hardware gripper motor positions are different parameters. Before running on real hardware, confirm the gripper open/close direction and limits.
MoveIt configuration files​
FileDescription
rebotarm_moveit_config/config/rebotarm.urdf.xacroRobot model used by MoveIt
rebotarm_moveit_config/config/rebotarm.srdfMoveIt groups, end effector and default states
rebotarm_moveit_config/config/kinematics.yamlIK solver configuration
rebotarm_moveit_config/config/joint_limits.yamlJoint limits used by MoveIt planning
rebotarm_moveit_config/config/moveit_controllers.yamlMoveIt trajectory execution controller config
rebotarm_moveit_config/config/ros2_controllers.yamlros2_control controller config
rebotarm_moveit_config/config/initial_positions.yamlInitial joint positions for simulated hardware
rebotarm_moveit_demos/config/draw_square.yamlDraw-square demo parameters
rebotarm_moveit_demos/config/pick_place.yamlPick-place demo parameters
FAQ​
1. open serial port /dev/ttyACM0 failed appears at startup​
This means the default serial port does not exist or the device name has changed. First check the actual serial device:
ls /dev/ttyACM*
Then specify it with channel:
2. Device or resource busy appears at startup​
This means the serial port is already occupied by another process. Common causes include a previously launched ROS2 node, an SDK example, or a debugging script that has not exited. Check the processes first:
ps aux | grep -E "reBotArmController|ros2|python"
Stop the process occupying the serial port and restart. The arm and gripper should share the same low-level Controller. Do not open the same serial port separately for the arm and gripper.
3. Permission denied​
If the serial device exists but permission is denied:
Log out and log back in for the change to take effect. For temporary debugging, you can also run:
4. Robot model is not displayed in RViz​
Check the following:
  • Whether the workspace has been sourced: source install/setup.bash
  • Whether Fixed Frame is set to base_link
  • Whether robot_state_publisher started correctly
  • Whether the URDF mesh path is package://rebotarm_bringup/description/meshes/...
5. FastDDS SHM port warning appears​
If the terminal shows something like:
[RTPS_TRANSPORT_SHM Error] Failed init_port fastrtps_port7002: open_and_lock_file failed
This is usually caused by leftover FastDDS shared-memory lock files after a previous ROS2 process exited abnormally. If services and actions still respond normally, this warning usually does not affect control.
To clean it up, stop the related ROS2 processes first, then run:
pkill -f ros2
pkill -f reBotArmController
rm -f /dev/shm/fastrtps_port*
If you want to temporarily bypass shared memory transport, set the following before launching ROS2:
export FASTDDS_BUILTIN_TRANSPORTS=UDPv4
6. What if I use Humble?​
Humble users can follow the same workflow, replace jazzy with humble in the commands, and install the corresponding dependencies according to the Humble official documentation. After switching ROS2 distributions, run colcon build again.
7. pinocchio cannot be found​
If a node or verification command reports:
ModuleNotFoundError: No module named 'pinocchio'
First make sure the Pinocchio package for your ROS2 distribution is installed:
sudo apt install -y ros-jazzy-pinocchio
Then make sure the current terminal has sourced the ROS2 environment:
python3 -c "import pinocchio; print(pinocchio.__version__)"
If it still cannot be found, check whether the current Python search path contains the ROS2 Python package path:
python3 -c "import sys; print('\n'.join(sys.path))"
After sourcing Jazzy, you should see a path similar to /opt/ros/jazzy/lib/python3.12/site-packages. If you use Humble, replace jazzy with humble in the commands.
Contact​
References​
