reBot-DM Holoscan5 Gravity Compensation
400 Hz Target Rate · Pinocchio Dynamics · Nsight Systems Latency Analysis
This tutorial uses NVIDIA Holoscan 5 to run a three-stage control loop. The loop reads the current joint angles, uses Pinocchio and the robot model to calculate the torque needed to counter gravity, then sends commands to the motors. Holoscan schedules the loop at a target rate of 400 Hz and runs all three stages on one thread to reduce latency and jitter from thread handoffs.
With gravity compensation enabled, the motors adjust their torque as the pose changes and support the weight of the reBot Arm B601-DM. As a result, it takes less force to guide the arm by hand. NVIDIA Technical Blog
Prerequisites
| Item | Requirement |
| Robot arm | reBot Arm B601-DM with Damiao motors and the gripper installed |
| Connectivity | B601-DM power supply, USB-to-CAN controller board, and a USB data cable |
| Host | Ubuntu 24.04 x86_64 with internet access to download the source and dependencies |
| Runtime | Python 3.12, Holoscan 5.0.0, and an NVIDIA driver compatible with CUDA 13 |
If the arm is still unassembled, follow the quick start to secure the base, complete the wiring, and verify the motor IDs and joint zero positions. Turn off power before connecting or disconnecting the power or CAN harness. B601-DM Quick Start
Check the system and driver on the host.
uname -m
getconf GNU_LIBC_VERSION
nvidia-smi
Expect x86_64, glibc 2.39 or later, and nvidia-smi output that lists your GPU. NVIDIA specifies a CUDA 13-compatible R580 or later driver for Holoscan 5. If the driver is missing or too old, use Ubuntu's Additional Drivers utility or sudo ubuntu-drivers list to find a driver branch for your hardware. Follow Ubuntu's installation guide, reboot, and check again. On Jetson, first verify the corresponding JetPack SDK version. Holoscan SDK installation requirements · Installing NVIDIA drivers on Ubuntu
Ubuntu 22.04 ships with glibc 2.35. Even with Python 3.12 installed in Conda, run Holoscan 5 on a host or in a container that meets its glibc requirement. The commands in this guide use Ubuntu 24.04's native Python environment. Holoscan wheel requirements
Run gravity compensation
Set up the environment and check the control graph
Download NVIDIA's example in Bash. Use the pinned revision so the commands, configuration, and tests below match the source.
sudo apt update
sudo apt install -y ca-certificates git nano python3.12-venv libgl1 libglib2.0-0t64 libgomp1 psmisc
git clone https://github.com/nvidia-holoscan/holoscan-tutorials.git
cd holoscan-tutorials
git checkout --detach e79b1a662f358dca734d8a4426c0aeb60699e264
cd tutorials/rebot-gravity-compensation
Choose one way to create a Python 3.12 environment.
- Python venv
- Conda
python3.12 -m venv .venv
source .venv/bin/activate
If you already have Conda, create a dedicated environment. You can choose a different environment name. Conda installation guide
conda create -n holoscan-rebot python=3.12 pip -y
conda activate holoscan-rebot
Stay in the example directory with your environment active. Download the model and install the example's dependencies.
python --version
python scripts/fetch-urdf.py
test -s urdf/DM/urdf/ReBot_Arm_DM.urdf
python -m pip install --only-binary=:all: -r requirements-python.txt \
'holoscan==5.0.0' 'nvidia-cuda-runtime==13.0.96'
python -m pip check
The download script retrieves the URDF from a pinned Seeed Studio revision, verifies the source file, and preserves the dynamics data. The requirements file installs Pinocchio 3.9.0 and motorbridge 0.5.0. Pinocchio's pip package is pin, and its Python import name is pinocchio. Official example source and dependencies
The control graph runs on the CPU, and importing Holoscan still loads the CUDA runtime. These commands add the shared libraries from the wheel to the current terminal's library search path. Whenever you open a new terminal, return to the example directory, reactivate your environment, and run these commands again. Holoscan wheel runtime libraries
CUDA_LIB_DIR="$(python - <<'PY'
from importlib.metadata import distribution
runtime = distribution("nvidia-cuda-runtime")
library = next(file for file in runtime.files if file.name == "libcudart.so.13")
print(runtime.locate_file(library).parent)
PY
test -n "$CUDA_LIB_DIR" && export LD_LIBRARY_PATH="$CUDA_LIB_DIR${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}"
python python/gravity_compensation.py --help
Before connecting the arm, you can load the model and compile the control graph. This check initializes the model and compiles the graph without opening the serial port or enabling the motors.
PYTHONPATH=python python - <<'PY'
import holoscan as hsdk
from gravity_compensation import build_graph, load_configuration
from rebot_gravity import GravityCompensation
from rebot_robot import Robot
config, params = load_configuration("config/rebotarm_dm.yaml")
controller = GravityCompensation(config, params)
controller.initialize()
plan = hsdk.compile(build_graph(Robot(config), controller), hsdk.CompileOptions())
if not plan:
raise SystemExit(plan.summary())
print(f"URDF loaded: nq={controller.model.nq}, nv={controller.model.nv}")
print("Control graph compiled successfully.")
PY
Expect nq=8, nv=8 and a successful compile message. The model has six arm coordinates and two finger coordinates. The physical arm has seven motors. For a fuller software regression check, run the fake-motor tests later in this guide.
Connect the arm and configure the serial port
Make sure the base is secure, connect the USB data cable, and power on the arm. Run the following command to grant read and write access to the serial devices.
sudo chmod 666 /dev/ttyACM*
Copy the official configuration and edit channel in the copy. Replace the example path with your actual serial port.
cp config/rebotarm_dm.yaml config/rebotarm_local.yaml
nano config/rebotarm_local.yaml
channel: "/dev/ttyACM0"
| Setting | Official example value |
| Motor IDs and feedback IDs | 1–7 and 17–23, respectively, in decimal |
| Motor models | 4340P for joint1–joint3, and 4310 for joint4–joint6 and the gripper |
| Serial baud rate | 921600 |
| Arm gains | kp: 1.5 and kd: 1.0 |
| Gravity torque scale and joint direction | tau_scale and joint_direction both default to 1 for all six arm joints |
| Command watchdog | 100 ms |
Keep the official gains, directions, and scaling for the first run. If the motor IDs, mounting orientations, or joint zero positions differ from the actual hardware, verify them against the quick start first. If you change the base orientation or add a payload, use a dynamics model that accounts for the change. Official motor configuration
Start, verify, and stop the controller
The start command enables the physical motors. Remove any extra payload, clear the range of motion, and put the arm in a position where it stays supported if torque is lost. Make sure someone on site can cut power promptly. A fault can also cause the controller to remove support torque.
Run the commands in the same environment. Make sure the controller has exclusive access to the serial port.
unset MOTORBRIDGE_LIB
python python/gravity_compensation.py config/rebotarm_local.yaml
The program checks the model, current pose, and motor state, then configures the watchdog and starts sending commands. Once you see the message below, slowly guide the arm through a small movement. Check that it supports its weight and moves with your hand. If it pushes back noticeably, drops, oscillates, or reports a motor error, support the arm and stop the controller before troubleshooting.
Gravity compensation active.
To shut down normally, first guide the arm back to a supported position, then press Ctrl+C. The program attempts to disable the motors as it exits, which removes the support torque. On a normal exit, the terminal shows a stop message and the command batch count.
How the control loop works
| Operator | Role |
joint_feedback | Runs on a 2.5 ms schedule and reads joint positions, velocities, and motor status |
gravity | Computes feedforward gravity torque from the URDF and current joint angles and generates stiffness and damping parameters |
motor_commands | Validates commands and sends MIT control commands to all seven motors through motorbridge |
The three operators execute in sequence in the same Holoscan control partition. Each queue between operators holds one pending message. Pinocchio computes the gravity term as g(q) = RNEA(q, 0, 0). The scheduling target is 400 Hz. Use Nsight Systems to measure the actual interval between iterations.
The watchdog checks for overdue command batches. motorbridge returns cached feedback. If motor feedback stops while commands can still be sent, the example may continue to read stale values. Have someone monitor the arm on site during hardware tests. Official technical guide
Optional fake-motor tests
The two official test suites cover gravity torque, the control graph, shutdown on fault, and Cartesian point hold. Stop the hardware controller before running the following commands. You can unplug the arm's USB cable for these tests. Run them from the example directory with the environment active. The commands build the fake motor library used by the tests without requiring the C++ SDK.
sudo apt install -y curl g++
mkdir -p build/wiki-test
curl -fL \
https://raw.githubusercontent.com/motorbridge/motorbridge/082cbb8c36dfdc8fbf9baa4cc02c5992ab0dc2ad/motor_abi/include/motor_abi.h \
-o build/wiki-test/motor_abi.h
g++ -std=c++20 -shared -fPIC -I build/wiki-test tests/fake_motor_abi.cpp \
-o build/wiki-test/librebot_fake_motor_abi.so
REBOT_FAKE_ABI="$PWD/build/wiki-test/librebot_fake_motor_abi.so"
REBOT_TEST_MOTOR_LIBRARY="$REBOT_FAKE_ABI" python tests/test_python_gravity.py
REBOT_TEST_MOTOR_LIBRARY="$REBOT_FAKE_ABI" python tests/test_python_cartesian.py
At the pinned revision, expect 20 tests in the first suite and 15 in the second, each ending with OK. The fault-injection tests produce expected error logs. Passing these tests verifies the software path. Follow Steps 2 and 3 to check the wiring, motor directions, joint zero positions, and behavior on the physical arm.
Optional CPU pinning comparison with Nsight Systems
Install Nsight Systems and run nsys --version to check that the CLI is available. Both profiling runs drive the physical arm. Run them one at a time and confirm that the previous process has stopped before starting another. At the end of each run, return the arm to a supported position before pressing Ctrl+C. Nsight Systems download
First, capture a run with the default scheduling and no CPU pinning.
mkdir -p build/profiles
nsys profile --trace=nvtx --sample=none --backtrace=none --cpuctxsw=none \
--output=build/profiles/gravity-unpinned \
Next, check which logical CPUs are available and choose an allowed CPU number. The value 2 below is an example.
lscpu -e=CPU,CORE,SOCKET,NODE
taskset -pc $$
REBOT_CPU=2
--output=build/profiles/gravity-pinned \
python python/gravity_compensation.py config/rebotarm_local.yaml --cpu "$REBOT_CPU"
Inspect both reports. Use new output filenames for repeat runs.
nsys stats --report nvtx_sum build/profiles/gravity-unpinned.nsys-rep
nsys stats --report nvtx_sum build/profiles/gravity-pinned.nsys-rep
Open the .nsys-rep reports in the Nsight Systems GUI and inspect the NVTX ranges for the three operators on the timeline. Keep the arm pose, capture duration, and host load as consistent as possible across both runs.
| Metric | How to measure it |
| Operator duration | Check the statistics for the corresponding NVTX range in nvtx_sum. |
| Loop interval and jitter | Compare successive joint_feedback entry timestamps. The target interval is 2.5 ms. |
| In-graph latency | Use message markers to match events from the same iteration, then measure from entry into joint_feedback to entry into motor_commands. Measure serial transmission separately. |
For batch analysis, export the report to SQLite. Run nsys export --help to check for --include-blobs. If the option is missing, upgrade Nsight Systems before exporting structured message payloads. To match publish and receive events on the same edge, use source_identity and sequence. Then follow the operator's input and output to trace the same control iteration. Holoscan NVTX annotations
nsys export --type sqlite --include-blobs=true \
-o build/profiles/gravity-pinned.sqlite build/profiles/gravity-pinned.nsys-rep
--cpu sets affinity only for the control thread. NVIDIA also isolated a physical core and its SMT sibling, discarded the first 10 seconds as warm-up, and kept more than one million iterations per run. Record your own sample count, CPU topology, and isolation settings when reproducing the experiment. Use a short trace to inspect graph behavior and a sufficiently large sample for tail-latency percentiles. NVIDIA's benchmark conditions · Message correlation guide
Optional C++ comparison
Install Holoscan SDK 5.0 with its development components, a C++20 compiler, CMake 4 or later, Ninja, Rust/Cargo, and Python 3.12. NVIDIA used SDK build 5.0.0.7 for this example. SDK installation guide · Example C++ build instructions
Run these commands from the example directory. If you have already verified that the model file exists, skip the first line.
python3.12 scripts/fetch-urdf.py
./scripts/bootstrap-deps.sh
cmake --preset default
cmake --build --preset default
ctest --preset default
After the tests pass, use Steps 2 and 3 to check the hardware and starting pose. Then use the following command in place of the Python launch command. To profile C++ with Nsight Systems, change the executable and the output name in the profiling commands. Keep the serial configuration and comparison conditions the same.
./build/rebot_gravity_compensation config/rebotarm_local.yaml
Troubleshooting
| Symptom | What to check |
| pip cannot find the Holoscan wheel | Check python --version, uname -m, and getconf GNU_LIBC_VERSION, then use a compatible Python version and system. |
libcudart.so.13 is missing | Check that the CUDA runtime wheel is installed in the active Python environment and set LD_LIBRARY_PATH again. |
libcuda.so.1 is missing | Check the host's NVIDIA driver and nvidia-smi output. The CUDA runtime wheel does not include the host driver. |
| The URDF is missing or Pinocchio fails to import | Rerun the model download script from the example directory. Check the pin version and import path in the active environment. Avoid loading ROS extensions from a different Python environment. |
| The serial port fails to open or is busy | Check the USB data cable, the channel path, and the serial port permissions. Use fuser -v /dev/ttyACM0 with your actual device path to identify the process using the port, then stop it from its original terminal. |
| A motor stops reporting feedback or reports a fault | Support the arm and stop the controller first. Verify the motor IDs, power supply, wiring, and firmware instructions. Save the full error and joint number, and keep the watchdog enabled. |
| The arm drops, pushes back, or oscillates | Support the arm and stop the controller first. Check the base orientation, joint zero positions, model, and payload. |
| The graph fails to compile or start with a CPU specified | Run taskset -pc $$ to check which CPUs are allowed, or remove --cpu to restore default scheduling. |
