reBot Arm T701 HT MIT Control SDK
reBot Arm T701 HT bimanual robot
The T701-HT SDK's MIT interface sets target position, target velocity, feedforward torque, position gain Kp, and velocity gain Kd together. This page introduces the single-motor sinusoidal tracking example, its parameters, feedback, and shutdown sequence. For whole-arm gravity compensation, joint impedance, and Cartesian control, see T701 HT with Pinocchio.
Prepare the Robot​
Get the SDK and install its dependencies using the T701 HT Quick Start installation instructions. Complete the serial mapping and joint and gripper feedback checks, then verify the selected motor's zero position.
  • Connections. The left arm uses CAN1; the right arm uses CAN2. Set board_serial in T701-HT_robot_param/serial_binding.yaml to the communication board's USB serial number.
  • Motor IDs. On each arm, ID1–ID7 are the seven joints, and ID8 is the gripper.
  • Working directory. Run all commands on this page from the SDK root. In each new terminal or SSH session, return to that directory and activate the environment.
conda activate t701-ht
Check the motion range before running
The selected motor starts moving immediately when you run a motion command, without another arm selection or confirmation. Secure the hardware, remove payloads, and clear the motion range and return path. Stay with the hardware and keep clear of joint and gripper pinch points.
The original target is ±π rad (±180°). The motion loop calls the low-level motor interface directly, without applying the high-level joint limits or gravity compensation. This trajectory may exceed the permitted range of an assembled joint or gripper. In particular, the high-level range for the ID8 gripper is −0.2 to 2.2 rad, so it cannot execute the original trajectory. Before running, adjust the target position and corresponding velocity to suit the selected mechanism, and verify the entire trajectory and return path.
Select and Run One Motor​
The example is scripts/motor_example/t701_ht_pos_vel_torque_kp_kd_control.py. After checking and adjusting the trajectory above, choose one command to match your wiring.
Left arm CAN1, motor ID8:
python scripts/motor_example/t701_ht_pos_vel_torque_kp_kd_control.py --can-port 1 --motor-id 8 --arm left
Right arm CAN2, motor ID8:
python scripts/motor_example/t701_ht_pos_vel_torque_kp_kd_control.py --can-port 2 --motor-id 8 --arm right
ArgumentValuesPurpose
--can-port1–7Logical CAN channel on the communication board. Standard wiring uses 1 for the left arm and 2 for the right.
--motor-id1–8Selects just one motor with this ID on the specified channel.
--armleft / rightSelects that side's motor types and homing configuration.
All three arguments are required; there is no default arm or motor selection. --arm neither selects the CAN channel nor mirrors the right-arm trajectory. The example generates a temporary single-motor configuration from the corresponding YAML, so you do not need to edit the whole-arm motor list.
MIT Parameters and Target Trajectory​
This excerpt comes from the motion loop; the example creates motor and robot. Set the selected motor's command, then send it.
motor.pos_vel_tqe_kp_kd(pos, vel, 0.0, 2, 0.5)
robot.motor_send_cmd()
Parameter (in call order)MeaningOriginal setting
posTarget position, radπ × sin(2π × 0.1 × t), with amplitude π rad.
velTarget velocity, rad/s0.2 × π² × cos(2π × 0.1 × t), the time derivative of target position.
tqeFeedforward torque, Nm0.0. Zero feedforward does not mean zero motor output torque.
kpPosition gain2.
kdVelocity gain0.5.
The original frequency is 0.1 Hz, the period is 10 seconds, and peak target velocity is about 1.974 rad/s. If you change the position to offset + A × sin(2π × f × t), use the corresponding velocity A × 2π × f × cos(2π × f × t), and verify that the full range from offset − A to offset + A is permitted.
t uses time.time(), so the initial phase depends on the launch time; the target does not necessarily start at zero. The source comment says “1.0 rad amplitude,” but the formula uses π rad.
The loop sleeps for 0.001 seconds after each send. Communication, computation, and printing add to the cycle time, so this is not a fixed 1 kHz real-time loop.
Read State Feedback​
At startup, the terminal displays the number of controlled motors. It then prints the selected motor's state every 100 loop iterations.
FieldMeaning
positionCurrent motor position, printed in rad and converted to degrees.
velocityCurrent motor velocity, rad/s.
torqueReported motor torque, Nm.
modeMode value returned by the low-level SDK.
faultFault code returned by the low-level SDK, printed in hexadecimal.
The example reads these fields through motor.get_current_motor_state(). The printing interval depends on actual loop timing. The example displays mode and fault values without decoding fault codes.
Return to Zero and Exit​
  1. The first Ctrl+C exits sinusoidal tracking and starts a smooth return of the selected motor to its saved zero position.
  2. Homing uses the position, velocity, and maximum torque interface pos_vel_MAXtqe(), with the homing configuration for the side selected by --arm.
  3. After homing, the shutdown logic sends damping brake commands. Press Ctrl+C again during homing to interrupt the return and attempt braking. Invalid feedback or a homing failure also causes the shutdown logic to attempt braking.
The first Ctrl+C triggers return motion. Damping braking is not a position hold; support the mechanism during startup and shutdown.
Use MIT Control for the Whole Arm​
The single-motor example uses a low-level motor object. Whole-arm control uses Lib.t701_ht.T701HT, with separate interfaces for joints and the gripper.
InterfaceParameters and sending behavior
motor.pos_vel_tqe_kp_kd(pos, vel, tqe, kp, kd)Five scalar parameters for one motor. Call robot.motor_send_cmd() afterward to send.
arm.pos_vel_tqe_kp_kd(pos, vel, tqe, kp, kd)Five joint vectors of length 7, excluding the gripper. Checks the configured target joint position range before sending; returns False for an out-of-range target.
arm.gripper_control_MIT(pos, vel, tqe, kp, kd, send=True)Five scalar gripper parameters. Checks the target gripper position range and sends by default. With send=False, only queues the command for sending with the joint command in the same cycle. Returns False for an out-of-range target.
The whole-arm MIT interface's target position checks do not replace trajectory design or torque limiting. For gravity feedforward, joint impedance, or automatic shutdown handling, use the complete examples linked from the Pinocchio page.
