Use the Skill to Develop reCamera 2002 Applications
reCamera 2002 AI coding agent skill
Introduction​
The reCamera 2002 C++ Dev Toolkit packages a reproducible C++ workflow for the reCamera 2002 (SG200X) into an Agent Skill. After installation, your coding agent can generate a demo workspace, prepare models, cross-compile RISC-V binaries, run host smoke tests, package artifacts, deploy over SSH, and collect evidence.
The skill is configuration-driven: demo.json describes what the demo should do, every stage is a command, and offline stages must pass before a device is involved.
note
This skill targets reCamera 2002 with the SG200X SoC (OS >= 0.2.4). It is not for reCamera Pro / RV1126B / RKNN. For reCamera Pro, use the reCamera Pro skill.
What the skill can do​
  • Generate a demo workspace from demo.json: directory layout, build scripts, and starter code
  • Fetch or convert models: Seeed-hosted models or ONNX → .cvimodel with TPU-MLIR
  • Cross-compile RISC-V C/C++ demos with the Xuantie toolchain and SG200X SDK
  • Run host smoke tests without a device, so logic errors fail before deployment
  • Package deterministic artifacts with hashes for reproducible delivery
  • Deploy over SSH, probe the device, and diagnose failures
  • Launch a live viewer with UDP H.264 video, detection overlays, and parameter tuning
  • Capture evidence and score output against a baseline
Supported environment​
ItemSupported configuration
DeviceSeeed reCamera 2002 (SG200X), OS >= 0.2.4
SoCSG200X
Target architectureriscv64 Linux
Model format.cvimodel (TPU-MLIR / CVI)
HostLinux x86_64 (macOS for host-side validation; Windows via WSL2)
Supported agentsClaude Code, Codex, Gemini CLI
Not supportedreCamera Pro / RV1126B / RKNN
Install the Skill​
Clone the toolkit repository, then copy the skill directory into your agent's skills directory:
git clone https://github.com/Seeed-Projects/recamera-2002-cpp-dev.git ~/src/recamera-2002-cpp-dev
# Claude Code
cp -r ~/src/recamera-2002-cpp-dev/skills/recamera-2002-cpp-dev ~/.claude/skills/
# OpenAI Codex
cp -r ~/src/recamera-2002-cpp-dev/skills/recamera-2002-cpp-dev ~/.codex/skills/
# Gemini CLI
cp -r ~/src/recamera-2002-cpp-dev/skills/recamera-2002-cpp-dev ~/.gemini/skills/
After installation, keep the skill directory name recamera-2002-cpp-dev. The same directory can serve multiple agents. If the skill does not appear in your current session, restart the agent.
Use the Skill: People Counting Walkthrough​
After installing the skill, you do not need to run each script by hand. Describe the goal to your coding agent and it follows the skill's workflow. Below is a real people-counting secondary-development session.
1. Describe the task​
Enter this in Claude Code / Codex:
Use the recamera-2002-cpp-dev skill to implement people counting in the camera view.
Starting a people counting task with the recamera-2002-cpp-dev skill
The agent handles validation, cross-compilation, packaging, deployment, and the live viewer automatically
From here you do not need to run any scripts by hand. The agent follows the skill from workspace generation all the way to the live view on the device, then prints LIVE_URL.
2. Deploy and open the live page​
The agent runs probe → install → start automatically, opens the host-side viewer, and prints LIVE_URL.
People counting countPeople counting result in the reCamera Live page
reCamera Live: live view, person boxes, counting line, parameter panel, and device log
The page shows the live view, person boxes, and in/out counts; counting line and ROI changes take effect immediately.
3. Iterate​
Continue the conversation:
Move the counting line up and shrink the ROI to the lower half of the frame.
Increase the track confirmation frames from 2 to 3 to reduce false counts.
Publish the current count and in/out totals to Home Assistant over MQTT.
The agent modifies the project, rebuilds, redeploys, and reuses the same verification flow.
Command Reference​
Only the two most common entry points are kept here. For the full command set, parameters, and caveats, see the official repository:
# Create a workspace with the live transport skeleton
python3 scripts/new_demo.py --name my_live --task detection --live udp --out ~/reCamera_demo
# Deploy and open the live page
python3 scripts/launch_demo.py --demo-dir ~/reCamera_demo/my_live --host <device-ip>
Development workflow​
  1. Generate the workspace from demo.json.
  2. Validate the project configuration offline.
  3. Build the RISC-V binary and record the toolchain lock.
  4. Smoke test the host logic without a device.
  5. Package a deterministic archive with artifact hashes.
  6. Deploy over SSH and probe the device.
  7. Capture evidence and score the result against a baseline.
By default, the skill builds and inspects artifacts locally. File transfer, service changes, and execution on the device happen only when you explicitly request and authorize them.
Troubleshooting​
ProblemPossible causeSolution
The skill is not listedThe agent has not reloaded its skills directoryRestart the agent and verify the install path shown above
Cross-compilation failsMissing Xuantie GCC 10.2.0, SG200X SDK, or SG200X_SDK_PATHUse a Linux/WSL2 host and re-run the environment check
Model conversion failsTPU-MLIR or the onnx package is missing, or the model contract is incompatibleInstall the optional dependencies and inspect the model input/output first
SSH deploy failsThe device is not reachable or the password is not setCheck the USB/RNDIS connection and set RECAMERA_PASSWORD
The binary runs on the host but not the deviceWrong architecture or incompatible C libraryVerify the ELF is riscv64 and matches the SG200X sysroot
Live view shows no detectionsThe live section is incomplete or detection is not implementedFix the demo before claiming success; report placeholder or degraded honestly
Resources​
Q&A​
Can I use this skill with reCamera Pro?​
No. This skill targets reCamera 2002 (SG200X) only. For reCamera Pro (RV1126B / RKNN), use the reCamera Pro Development Skill.
How do I export logs for troubleshooting?​
If deployment or the live view fails, collect the host-side demo logs and the device logs into one archive:
# On the host: pack the demo workspace logs and evidence
cd ~/reCamera_demo/my_live
tar -czf recamera-2002-host-logs.tar.gz logs/ evidence/ 2>/dev/null || true
# Collect device-side logs over SSH
ssh recamera@<device-ip> "dmesg > /tmp/dmesg.log; tar -czf /tmp/recamera-2002-device-logs.tar.gz -C /var/log . /tmp/dmesg.log 2>/dev/null" || true
scp recamera@<device-ip>:/tmp/recamera-2002-device-logs.tar.gz .
Send the archives together with a description of the problem, your hardware model, and the reCamera OS version to techsupport@seeed.io.
Thank you for choosing our products! We are here to provide you with different levels of support to ensure that your experience with our products is as smooth as possible. We offer multiple communication channels to cater to different preferences and needs.
