AI and NPU Development
This page covers application-side models, runtime libraries, and reference projects. For C/C++ builds, use recamera_pro_toolchain; you do not need to build the complete system. Paths such as project/app/rkai refer to internals of the full source package and are provided here as source-package references.
RV1126B has a dedicated NPU. The SDK contains three independent AI development paths. Choosing the right one early can save considerable time.
PathLocationUse caseWhat you do
RKNN Runtime (C API)media/rknn-llm-mk/, project/app/rkai/rkai/common/include/rknn_api.hRun your own detection / classification / segmentation modelConvert ONNX to .rknn on a PC, then run inference through the C API on the board
ROCKIVA (packaged algorithm library)media/iva/iva/Ready-made face, person, pet, and other detectionCall rockiva_*_api.h and use the bundled .data models
RKLLM (large language / multimodal models)media/rknn-llm-mk/rknn-llm/, project/app/rkllm-inference/Run an LLM / VLM on the boardConvert to .rkllm with rkllm-toolkit and run with librkllmrt.so on the board
1. RKNN Runtime​
Runtime Libraries and Headers​
Available copies in the SDK:
media/rknn-llm-mk/rknn-llm/examples/multimodal_model_demo/deploy/3rdparty/librknnrt/
├── Linux/librknn_api/include/rknn_api.h # C API header
├── Linux/librknn_api/include/rknn_matmul_api.h # Matrix multiplication API
├── Linux/librknn_api/aarch64/librknnrt.so # aarch64 runtime
├── Android/librknn_api/arm64-v8a/librknnrt.so
└── Android/librknn_api/armeabi-v7a/librknnrt.so
media/iva/iva/librockiva/rockiva-rv1126b-Linux/lib/librknnrt.so
media/isp/camera_engine_rkaiq/rkaiq/algos/aiisp/aiisp_relate/librknnrt_64bit.so
media/isp/camera_engine_rkaiq/rkaiq/algos/aiisp/aiisp_relate/librknnrt_32bit.so
project/app/rkai/rkai/common/include/rknn_api.h # Header used by applications
project/app/rkai/rkai/common/include/rknn_custom_op.h # Custom operators
project/app/rkai/rkai/common/include/rknn_matmul_api.h
On the device, the runtime library is /oem/usr/lib/librknnrt.so, which is added to LD_LIBRARY_PATH by /etc/profile.d/RkEnv.sh.
Version matching is mandatory: RKNN-Toolkit2 (PC-side conversion tool), rknn_api.h, and librknnrt.so must use compatible versions. The internal baseline for Seeed production firmware is RKNN 2.3.2 (target_platform='rv1126b'). The librknnrt.so bundled in the SDK may be a different version; use /oem/usr/lib/librknnrt.so on the device as the source of truth. Do not replace it with a library downloaded separately or copied from another board.
Before deployment, check the version on the device (the exact command output still needs hardware verification):
# strings /oem/usr/lib/librknnrt.so | grep -i "librknnrt version"
# cat /sys/kernel/debug/rknpu/version 2>/dev/null || dmesg | grep -i rknpu
Add /oem/usr/lib to RUNPATH when linking: -Wl,-rpath,/oem/usr/lib. Do not overwrite the library on the device.
NPU Core Configuration​
Core masks available in rknn_api.h:
ValueMeaning
RKNN_NPU_CORE_AUTOSelect automatically
RKNN_NPU_CORE_0Use core 0 only
RKNN_NPU_CORE_0_1Use cores 0 + 1 (rkllm-inference takes 2 as its argument)
RKNN_NPU_CORE_0_1_2Use all three cores (pass 3)
Other common flags include RKNN_FLAG_PRIOR_HIGH/MEDIUM/LOW (priority), RKNN_FLAG_ASYNC_MASK (asynchronous execution), RKNN_FLAG_COLLECT_PERF_MASK (performance collection), RKNN_FLAG_MEM_ALLOC_OUTSIDE (external memory), and RKNN_FLAG_SHARE_WEIGHT_MEM (share weights across models).
Model Conversion (on a PC)​
The SDK does not include RKNN-Toolkit2. Set up a separate Python environment on an x86_64 Linux host:
# An isolated conda or venv environment is recommended
pip install rknn-toolkit2==2.3.2
Conversion script outline:
from rknn.api import RKNN
rknn = RKNN(verbose=True)
rknn.config(
mean_values=[[0, 0, 0]],
std_values=[[255, 255, 255]],
target_platform='rv1126b', # Required; do not leave this unset
rknn.load_onnx(model='model.onnx')
rknn.build(do_quantization=False) # Establish an FP16 baseline first
rknn.export_rknn('model.rknn')
Guidelines:
  • Establish an FP16 baseline first, then verify that inference works and check accuracy before considering INT8 quantization.
  • INT8 requires a representative list of calibration images, one path per line. Keep the calibration set separate from the validation set.
  • Keep same-name .rknn.json metadata with the exported model, including input layout, normalization, color order, resize policy, output semantics, and post-processing. This is needed for deployment and debugging.
  • Do not guess model preprocessing parameters. Copy mean/std, input size, NCHW/NHWC, and RGB/BGR from the training or export script.
  • A successful conversion means only that an RV1126B-compatible .rknn was produced; it does not prove model accuracy or runtime correctness. Verify those separately.
On-Device Inference with the C API​
#include "rknn_api.h"
rknn_context ctx = 0;
rknn_init(&ctx, model_data, model_size, 0, NULL);
rknn_input_output_num io_num;
rknn_query(ctx, RKNN_QUERY_IN_OUT_NUM, &io_num, sizeof(io_num));
rknn_set_core_mask(ctx, RKNN_NPU_CORE_0_1);
rknn_input in[1] = {0};
in[0].type = RKNN_TENSOR_UINT8;
in[0].fmt = RKNN_TENSOR_NHWC;
in[0].size = width * height * 3;
in[0].buf = rgb_buffer;
rknn_inputs_set(ctx, 1, in);
rknn_run(ctx, NULL);
rknn_output out[1] = {0};
out[0].want_float = 1;
rknn_outputs_get(ctx, 1, out, NULL);
/* ... post-processing ... */
rknn_outputs_release(ctx, 1, out);
rknn_destroy(ctx);
For a C API application, start with the RKNN example in recamera_pro_toolchain. Manually configuring the sysroot, header paths, and link flags can introduce libraries that do not match the firmware; first use the example to establish a known-good build.
Do not use rknn-toolkit-lite2 (Python) to write a device-side C/C++ application. It is intended for quick validation; production applications should use the C API.
Existing Detection Models​
project/app/recamera_ipc/model/rknn/ contains models and metadata that can be used as references:
FileDescription
yolox_s.rknn + yolox_s.jsonYOLOX-S object detection
nanodet-plus-m_416.rknn + nanodet-plus-m_416.jsonNanoDet-Plus-M 416×416 detection
The .json files contain related metadata (input/output definitions, thresholds, and post-processing parameters). Create equivalent metadata for your own model if you want it to load in the recamera_ipc inference framework. Related code is under project/app/recamera_ipc/common/rc_infer/, rc_model/, and rockiva/.
Reference Projects​
PathContents
project/app/rkai/rkai/samples/rkai_samples_vlm.cppVLM (image-text understanding) example
project/app/rkai/rkai/samples/rkai_samples_vlm_vision.cppVision-only VLM example
project/app/rkai/rkai/samples/rkai_samples_llm.cppLLM example
project/app/rkai/rkai/rkai_VLM/, rkai_LLM/RKAI wrapper libraries (CMake, with include/ and src/)
project/app/rkai/rkai/app_conf/{config,inputs}Runtime configuration and input samples
project/app/rkai/rkai/RkLunch.shStartup script
project/app/testdemo/yoloworld_demo/End-to-end YOLO-World demo (with 3rdparty and resources)
media/rknn-llm-mk/rknn-llm/examples/rkllm_api_demo/Minimal RKLLM API example
media/rknn-llm-mk/rknn-llm/examples/multimodal_model_demo/Complete multimodal example (including deploy/3rdparty)
Documentation: project/app/rkai/rkai/doc/Rockchip_Developer_Guide_Linux_RKAI_CN.md (an English version is available).
2. ROCKIVA​
Located under media/iva/iva/, including CMakeLists.txt, librockiva/, and models/.
RV1126B package:
├── include/
│ ├── rockiva_common.h # Common types and initialization
│ ├── rockiva_one_api.h # Unified API (most commonly used)
│ ├── rockiva_det_api.h # Detection
│ ├── rockiva_face_api.h # Face processing
│ ├── rockiva_ba_api.h # Behavior analysis
│ └── rockiva_image.h # Image structures
├── lib/librockiva.so
├── lib/librknnrt.so # Includes another copy of the RKNN runtime
└── lib64/
Model data:
media/iva/iva/models/rockiva_data_rv1126b/
├── iva_object_detection_pfp.data # Person / face / pet detection
├── iva_object_detection_v3_pfp.data
└── iva_object_detection_v3_cls8.data # 8-class detection
Link with -lrockiva -lrknnrt and pass the .data model directory to the initialization API at runtime.
The main benefit of ROCKIVA is that it eliminates the need to train and post-process your own detector: it directly returns person / face / pet bounding boxes. It is suitable for enhancing motion detection, person alerts, fall detection, and similar features. A fall_detect project in this SDK can also serve as a reference.
Documentation: docs/zh/npu_iva/Rockchip_Developer_Guide_ROCKIVA_SDK_CN.pdf. (There is no npu_iva category in docs/en; only the Chinese manual is included.)
recamera_ipc already contains ROCKIVA integration code under project/app/recamera_ipc/common/rockiva/.
3. RKLLM (On-Device Large Language Models)​
SDK Contents​
media/rknn-llm-mk/rknn-llm/:
Directory / fileContents
rkllm-runtime/Linux/On-device runtime (librkllmrt.so)
rkllm-toolkit/PC-side model conversion tools (packages/, examples/)
examples/rkllm_api_demo/Text-only LLM example
examples/multimodal_model_demo/Image-text multimodal example (includes deploy/3rdparty)
examples/rkllm_server_demo/Server deployment example
doc/Rockchip_RKLLM_SDK_CN_1.2.3.pdf / _EN_Official RKLLM SDK 1.2.3 manuals
rknpu-driver/rknpu_driver_0.9.8_20241009.tar.bz2NPU kernel driver package
benchmark.md, CHANGELOG.md, README.mdPerformance benchmarks and change log
The Makefile wrapper is media/rknn-llm-mk/Makefile; it is built as part of ./build.sh media.
Application: rkllm-inference​
project/app/rkllm-inference/ (enabled with RK_APP_RKLLM_INFERENCE=y) produces two binaries:
  • rkllm_inference_demo: interactive image-text inference
  • rkllm_benchmark_demo: single-run inference benchmark
make -C project/app/rkllm-inference
# Outputs: project/app/rkllm-inference/out/bin/{rkllm_inference_demo,rkllm_benchmark_demo}
Run it with:
rkllm_inference_demo \
<image_path> <encoder_model_path> <llm_model_path> \
<max_new_tokens> <max_context_len> <rknn_core_num> \
[img_start] [img_end] [img_content]
ArgumentMeaning
image_pathInput image
encoder_model_pathVision encoder .rknn
llm_model_pathLanguage model .rkllm
max_new_tokensMaximum number of generated tokens
max_context_lenContext length
rknn_core_num2 → RKNN_NPU_CORE_0_1; 3 → RKNN_NPU_CORE_0_1_2; any other value → AUTO
img_start/img_end/img_contentVision special tokens; defaults to Qwen-VL style vision_start, vision_end, and image_pad tokens
Interactive input supports 0 / 1 for built-in example prompts, custom text, image-text questions prefixed with <image>, clear to clear the KV cache, and exit to quit.
Benchmark output includes model loading, preprocessing, vision encoding, TTFT, decoding, end-to-end time, and throughput. prefill_time, decode_time, and memory_usage come from RKLLM's RKLLMPerfStat. After vision encoding, it explicitly unloads the encoder before loading the LLM to reduce memory pressure on this constrained platform.
Dependencies: librknnrt.so, librkllmrt.so, and target-platform OpenCV. It reuses rknn_api.h from project/app/rkai/rkai/common/include/rknn_api.h.
If your VLM uses different vision placeholder tokens, pass the correct img_start / img_end / img_content values at runtime. Otherwise, output may be incorrect.
Memory and Feasibility Notes​
RV1126B has much less memory than a typical LLM deployment platform. Before running an LLM / VLM:
  • Use rkllm_benchmark_demo to check memory_usage and make sure the model will not trigger OOM.
  • The board configuration sets RK_BOOTARGS_CMA_SIZE="8M", which is a small CMA region; large models mainly consume regular system memory and NPU memory.
  • INT4 / INT8 quantization is usually required; FP16 models will likely not fit.
4. AI-ISP​
RK_AIISP_MODEL=NONE means AI-ISP is not enabled in this board configuration, although the code path is present:
  • media/isp/camera_engine_rkaiq/rkaiq/algos/aiisp/ (includes librknnrt_32bit.so / librknnrt_64bit.so)
  • Examples: media/samples/example/demo/sample_demo_aiisp.c, sample_demo_dual_aiisp.c
  • Stress tests: sample_demo_aiisp_stresstest.c, sample_demo_dual_aiisp_stresstest.c
  • AINR-related IQ files are under iqfiles/isp35/ainr/
To enable AI-ISP, set RK_AIISP_MODEL to a specific model in the board configuration and provide the corresponding resources.
5. Performance and Stress Tests​
ToolPath
NPU stress testproject/app/recamera_utils/stress_test/npu_stress.py
CPU stress testproject/app/recamera_utils/stress_test/cpu_stress.py
eMMC / SD stress testproject/app/recamera_utils/stress_test/emmc_sd_stress.py
EMC testproject/app/recamera_utils/stress_test/emc_test.py
RKLLM benchmarkrkllm_benchmark_demo
Before running a sustained AI workload, evaluate thermal and power behavior. Long periods of full NPU load can trigger thermal throttling; see docs/zh/bsp/Rockchip_Developer_Guide_Thermal_CN.pdf.
  1. On a PC, convert ONNX to .rknn for target_platform='rv1126b' with RKNN-Toolkit2 2.3.2; start with FP16.
  2. Write a minimal application with rknn_api.h and verify on the board that the model loads and returns output. Start with a static image, without the camera.
  3. Check accuracy by comparing outputs with ONNX on the same input set.
  4. Add the video stream: get NV12 frames from rockit → convert to RGB / resize with RGA → pass to the NPU. See Video and ISP Development.
  5. For general person / face detection, evaluate ROCKIVA before implementing the same functionality yourself.
  6. Consider INT8 quantization and multi-core optimization (RKNN_NPU_CORE_0_1) only after the pipeline works.
