Device & System
Endpoint Overview​
MethodPathPurpose
GET/system/device-infoGet device serial number, firmware version, sensor and base board model
GET/system/resource-infoGet CPU, NPU, memory, and storage usage
GET/system/timeGet system time, timezone, and NTP configuration
PUT/system/timeSet system time
GET/system/batteryGet battery status
GET/system/checkCheck if first-time login
GET/system/sshQuery SSH running status
POST/system/sshStart or stop SSH
GET/system/secureQuery HTTPS status
POST/system/secureEnable or disable HTTPS
GET/config/exportExport device configuration
POST/config/uploadImport device configuration
POST/system/rebootReboot the device
POST/system/factory-resetRestore factory settings
Get Device Information​
GET /system/device-info
Response:
"sSerialNumber": "RC1126B-20240101-001",
"sFirmwareVersion": "V1.0.10",
"sSensorModel": "SC850SL",
"sBasePlateModel": "Base Board-V1.0,Expand Board-V1.0"
FieldDescription
sSerialNumberDevice serial number
sFirmwareVersionFirmware version
sSensorModelSensor board model
sBasePlateModelBase board model
Get System Resource Status​
GET /system/resource-info
Response:
"iCpuUsage": 12,
"iNpuUsage": 69,
"sMem": {
"iMemTotal": 1.94,
"iMemUsage": 33,
"iMemUsed": 0.65
"sStorage": {
"iStorageTotal": 11.29,
"iStorageUsage": 37,
"iStorageUsed": 4.22
FieldDescription
iCpuUsageCPU usage percentage
iNpuUsageNPU usage percentage
sMem.iMemTotalTotal memory
sMem.iMemUsedUsed memory
sMem.iMemUsageMemory usage percentage
sStorage.iStorageTotalTotal storage
sStorage.iStorageUsedUsed storage
sStorage.iStorageUsageStorage usage percentage
System Time​
Get System Time​
GET /system/time
Response:
"sMethod": "ntp",
"dNtpConfig": {
"sAddress": "pool.ntp.org",
"sPort": "123",
"status": 0
"iTimestamp": 1784083074,
"sTimezone": "Asia/Shanghai",
"sTz": "UTC+8"
FieldDescription
sMethodTime source, ntp or manual
dNtpConfig.sAddressNTP server address
dNtpConfig.sPortNTP port
dNtpConfig.statusNTP status, 0 means success
iTimestampUnix timestamp in seconds
sTimezoneTimezone city
sTzTimezone, e.g. UTC+8
Set System Time​
PUT /system/time
NTP mode request body:
"sMethod": "ntp",
"dNtpConfig": {
"sPort": "123"
"sTz": "UTC+8"
Manual mode request body:
"sMethod": "manual",
"sTz": "UTC+8"
Response:
"sTz": "UTC+8"
Battery Status​
GET /system/battery
Response:
"isAttached": true,
"displaySteps": 0,
"totalSteps": 5,
"isCharging": false
FieldDescription
isAttachedWhether a battery is attached
displayStepsCurrent battery level steps
totalStepsTotal battery level steps
isChargingWhether the battery is charging
Check First-Time Login​
GET /system/check
Response:
"bFirst": false
bFirst=true indicates the device is in the first-time login flow and the default password should be changed.
SSH​
Query SSH Status​
GET /system/ssh
Response:
"bRunning": true
Start or Stop SSH​
POST /system/ssh
Request body:
"bRunning": true
FieldDescription
bRunningtrue to start SSH, false to stop
HTTPS​
Query HTTPS Status​
GET /system/secure
Response:
"sEnable": true
Enable or Disable HTTPS​
POST /system/secure
Request body:
"sEnable": true
Response:
"code": 0,
"message": "Settings applied successfully"
After enabling HTTPS, use https://<DEVICE_IP> for subsequent access.
Configuration Management​
Export Configuration​
GET /config/export
Response:
"size": 35116544,
"url": "/download/config.tar"
FieldDescription
sizeConfiguration file size
urlDownload path; prepend the device IP for a full URL
Download URL:
http://<DEVICE_IP>/download/config.tar
Import Configuration​
POST /config/upload
Importing configuration overwrites the current device settings. Export the current configuration first as a backup.
Reboot​
POST /system/reboot
Response:
"code": 0,
"message": "success"
The device will reboot and the current connection will be lost. Wait for the device to come back online before continuing.
Factory Reset​
Factory reset requires two-stage confirmation.
Stage 1:
POST /system/factory-reset
Response:
"code": 0,
"sConfirmToken": "adfagghvshf"
Stage 2, submit the confirmation token within its validity period:
Request body:
Response:
"code": 0,
Factory reset erases all device configuration. Ensure you have a backup before proceeding.
Technical Support and Product Discussion​
Thank you for choosing our products! We are here to provide you with various support to ensure your experience with our products is as smooth as possible. We offer multiple communication channels to meet different preferences and needs.
