Network
Endpoint Overview​
MethodPathPurpose
GET/network/lanGet wired network configuration
PUT/network/lanSet wired network configuration
GET/network/wlanGet wireless IPv4 configuration
PUT/network/wlanSet wireless IPv4 configuration
GET/network/wifiGet current Wi-Fi connection info
GET/network/wifi-statusQuery Wi-Fi power status
POST/network/wifi-status?power=on/offToggle Wi-Fi power
GET/network/wifi-listScan nearby Wi-Fi networks
POST/network/wifiConnect to Wi-Fi
DELETE/network/wifiDisconnect or forget Wi-Fi
GET/web/settingQuery HTTP API settings
POST/web/settingSet HTTP API settings
GET/ftp/settingQuery FTP service settings
POST/ftp/settingSet FTP service settings
LAN and WLAN Configuration​
Get Configuration​
GET /network/lan
GET /network/wlan
Response:
"dIpv4": {
"sV4Address": "192.168.7.200",
"sV4Gateway": "192.168.6.2",
"sV4Method": "static",
"sV4Netmask": "255.255.254.0"
"dLink": {
"bEnableMethod": true,
"iPower": 1,
"sAddress": "40:FD:F3:25:1A:8E",
"sDNS1": "202.96.134.133",
"sDNS2": "223.5.5.5",
"sInterface": "wlan0"
FieldDescription
dIpv4.sV4AddressIPv4 address
dIpv4.sV4GatewayIPv4 gateway
dIpv4.sV4MethodIP assignment method, dhcp or static
dIpv4.sV4NetmaskIPv4 subnet mask
dLink.sDNS1 / dLink.sDNS2DNS servers
dLink.sAddressMAC address
dLink.sInterfaceNetwork interface name, e.g. eth0 or wlan0
dLink.iPowerInterface power state
dLink.bEnableMethodWhether manual configuration is enabled
Set Configuration​
PUT /network/lan
PUT /network/wlan
Request body:
"dIpv4": {
"sV4Address": "192.168.1.123",
"sV4Gateway": "192.168.1.1",
"sV4Method": "dhcp",
"sV4Netmask": "255.255.255.0"
"dLink": {
"sDNS1": "8.8.8.8",
"sDNS2": "8.8.4.4",
Response:
"code": 0,
"message": "SUCCESS TO SET IP"
Current Wi-Fi Info​
GET /network/wifi
The response structure is the same as LAN/WLAN configuration.
Wi-Fi Power​
Query Wi-Fi Power Status​
GET /network/wifi-status
Response:
"iPower": 1,
"id": 1,
"sType": "wifi"
FieldDescription
iPowerWi-Fi power state, 1 on, 0 off
idInterface ID
sTypeInterface type
Toggle Wi-Fi Power​
POST /network/wifi-status?power=on
POST /network/wifi-status?power=off
ParameterValueDescription
poweron, offTurn Wi-Fi on or off
Wi-Fi Scan and Connect​
Scan Wi-Fi List​
GET /network/wifi-list
Response:
"sBssid": "58:b4:bb:93:b8:e3",
"sSsid": "SEEED-MKT",
"iFrequency": 5180,
"iRssi": -44,
"sFlags": "[WPA-PSK-CCMP][WPA2-PSK-CCMP][ESS]",
"sConnected": true,
"sReserved": true
FieldDescription
sBssidWi-Fi BSSID, used as the unique identifier for connection
sSsidWi-Fi network name
iFrequencyFrequency channel
iRssiSignal strength
sFlagsSecurity type
sConnectedWhether currently connected
sReservedWhether the password is saved
Connect to Wi-Fi​
POST /network/wifi
Request body:
"sSsid": "58:b4:bb:93:b8:e3",
"sPassword": "your_wifi_password"
FieldDescription
sSsidWi-Fi unique identifier; use the sBssid value from /network/wifi-list
sPasswordWi-Fi password
Response:
"code": 0,
"message": ""
Disconnect or Forget Wi-Fi​
DELETE /network/wifi?disconnect=<ssid>
DELETE /network/wifi?Ignore=<ssid>
ParameterDescription
disconnectDisconnect from the specified Wi-Fi
IgnoreForget the specified Wi-Fi
Response:
"code": 0,
"message": "",
"status": 0
statusDescription
0Success
-1Timeout
-2Wrong password
HTTP API Settings​
Query Settings​
GET /web/setting
Response:
"sEnable": true,
"sApiKey": "M8RZVF3hXrVDk*%2%LlN*^7nuCRHPiIT"
FieldDescription
sEnableWhether HTTP API is enabled
sApiKeyAPI key
Set Settings​
POST /web/setting
Request body:
"sEnable": true,
"sApiKey": "your_api_key"
FTP Service Settings​
Query Settings​
GET /ftp/setting
Response:
"sEnable": false,
"sFtpPassword": "Seeed123.",
"sFtpPort": "21",
"sFtpUser": "ftpuser"
FieldDescription
sEnableWhether FTP service is enabled
sFtpPortFTP port
sFtpUserFTP username
sFtpPasswordFTP password
Set Settings​
POST /ftp/setting
Request body:
"sEnable": true,
"sFtpPort": "21",
"sFtpUser": "ftpuser",
"sFtpPassword": "StrongPassword123!"
Multicast​
GET /network/muticast
note
This endpoint is listed in the device API table. If the current firmware does not support it, the device may return a 404 or API Not Found response.
Error codes:
CodeDescription
10001FTP password too weak
10004FTP port out of range
10005FTP port already in use
Technical Support and Product Discussion​
Thank you for choosing our products! We are here to provide you with various support to ensure your experience with our products is as smooth as possible. We offer multiple communication channels to meet different preferences and needs.
