Quick Start
This page guides you from zero to completing a login and calling your first API.
Prerequisites​
  • The device is powered on and connected to your network
  • You know the device IP address (this guide uses 192.168.7.200 as an example)
  • You know the login username and password (default username is admin)
Step 1: Verify Device Accessibility​
Open this URL in a web browser:
https://192.168.7.200
If the device has HTTPS enabled with a self-signed certificate, the browser will warn that the certificate is not trusted. For local testing, you can proceed past the warning.
Step 2: Log In to Get a Token​
The login endpoint does not require authentication. Send a login request to the device:
POST https://192.168.7.200/cgi-bin/entry.cgi/system/login
Content-Type: application/json
Request body:
"sUserName": "admin",
"sPassword": "your_password"
note
The login password is transmitted in plaintext. If HTTPS is enabled, the password is protected by TLS during transmission.
On success, the response is:
"iStatus": 0,
"iAuth": 1,
"sWaittime": 0
FieldDescription
iStatus0 = correct password, -1 = wrong password, -3 = temporarily locked after repeated failures
iAuth1 = login successful, 0 = login failed, 2 = password change required
sWaittimeWait time in seconds when locked
The response headers will also contain:
Set-Cookie: token=<JWT_TOKEN>; Max-Age=86400; Path=/
This token is the authentication credential for all subsequent API requests.
Step 3: Call an API with the Token​
Retrieve device information:
GET https://192.168.7.200/cgi-bin/entry.cgi/system/device-info
Response:
"sSerialNumber": "RC1126B-20240101-001",
"sFirmwareVersion": "V1.0.10",
"sSensorModel": "SC850SL",
"sBasePlateModel": "Base Board-V1.0,Expand Board-V1.0"
If the request does not carry a Token or the Token has expired, the device returns:
"code": 401,
"message": "Unauthorized: Invalid token or NO token provided"
Token Lifetime​
The Token is valid for 24 hours by default (Max-Age=86400). After it expires, log in again to obtain a new Token.
Next Steps​
Technical Support and Product Discussion​
Thank you for choosing our products! We are here to provide you with various support to ensure your experience with our products is as smooth as possible. We offer multiple communication channels to meet different preferences and needs.
