Audio Development
This page describes application audio interfaces and the device configuration in the current product firmware. For ordinary C/C++ application builds, use recamera_pro_toolchain. You need the full BSP source only to modify ALSA, kernel audio, or product audio routing.
Hardware and Kernel Support
Audio-related kernel options are in sysdrv/source/kernel/arch/arm64/configs/rv1126b-recamera2.config:
| Configuration | Meaning |
CONFIG_SND_SOC_ES7202=y | Everest ES7202 multichannel ADC for microphone-array capture |
CONFIG_SND_SOC_ROCKCHIP_PDM_V2=y | PDM digital microphone interface v2 |
CONFIG_SND_SOC_RK817=y | RK817 codec (audio in the PMIC; speaker output path) |
CONFIG_SND_SOC_RK_DSM=y | Rockchip digital speaker processing |
CONFIG_SND_SOC_ROCKCHIP_ASRC=y | Asynchronous sample-rate conversion |
CONFIG_SND_SOC_ROCKCHIP_MULTI_DAIS=y | Multiple DAI links; capture and playback use separate DAIs |
CONFIG_SND_SOC_DUMMY_CODEC=y | Dummy codec |
CONFIG_SND_HRTIMER=y, CONFIG_SND_PCM_TIMER=y | Timer drivers |
Audio nodes are defined in rv1126b-recamera2-v1.dts and the DTSI files it includes. The userspace library source is media/alsa-lib/. It is built by ./build.sh media; outputs are under output/out/media_out/lib/.
Capture Path: Six Hardware Channels → Four Virtual Channels
This key reCamera Pro audio design is defined in /etc/asound.conf in an overlay. Source: project/cfg/BoardConfig_Recamera2/overlay/overlay-buildroot-asound/etc/asound.conf.
Three Layers
Layer 1 · Shared hardware (dsnoop) — allow multiple processes to read the same hardware device:
pcm.mic_hw_shared
type dsnoop
ipc_key 2026
ipc_perm 0666
slave.pcm "hw:0,0"
channels 6
rate 16000
format S16_LE
period_size 1024
buffer_size 4096
Layer 2 · Channel mapping (route) — map six physical channels to four virtual channels [Mic1, Mic2, Ref, Ref]:
pcm.ai_2mic_2ref
type route
slave.pcm "mic_hw_shared"
slave.channels 6
ttable {
0.0 1 # Hardware Ch0 → output Ch0 (Mic 1)
1.2 1 # Hardware Ch2 → output Ch1 (Mic 2)
2.4 1 # Hardware Ch4 → output Ch2 (Reference)
3.4 1 # Hardware Ch4 → output Ch3 (Reference copy)
Layer 3 · Application virtual devices (plug) — provide named devices with automatic format conversion for different modules:
| PCM device | Purpose |
ai_main | Main audio input |
ai_kws | Keyword spotting |
ai_asr | Speech recognition (ASR) |
ai_debug | Debugging / raw recording |
All four use type plug with slave.pcm "ai_2mic_2ref". Their control devices are:
ctl.ai_main / ctl.ai_kws / ctl.ai_asr / ctl.ai_debug → type hw; card 0
Why This Design Is Used
dsnoopavoids exclusive access: ALSA hardware devices are exclusive by default, but KWS, ASR, video-recording audio, and debug recording may need to capture at the same time.ipc_key 2026+ipc_perm 0666allows multiple processes to share the capture stream.routeprovides the AEC reference signal: Acoustic Echo Cancellation (AEC) needs a reference for what is currently playing on the speaker. Hardware channel 4 carries this reference and is copied to output channels 2 and 3.plugresolves format mismatches: Modules can require different rates or formats;plugconverts automatically.
How to Use It
# Record four channels (2 microphones + 2 references), 16 kHz S16_LE
# arecord -D ai_debug -c 4 -r 16000 -f S16_LE -d 10 /userdata/test.wav
# Record for ASR
# arecord -D ai_asr -c 4 -r 16000 -f S16_LE -d 5 /userdata/asr.wav
When using the ALSA API, pass "ai_main", "ai_kws", "ai_asr", or "ai_debug" as the device name. Do not use "hw:0,0"; it is exclusive and does not apply the channel mapping.
Opening
hw:0,0directly gives raw six-channel data. For the two-microphone + two-reference layout, useai_2mic_2refor one of itsplugwrappers.
Playback Path
The speaker uses the RK817 codec / RK_DSM. The default ALSA playback device is default (hw:0,x; verify the exact device number on hardware with aplay -l).
# aplay -l # List playback devices
# aplay -D default /oem/usr/share/xxx.wav
recamera_ipc includes a test audio file at project/app/recamera_ipc/common/speaker_test.wav for a speaker check.
Application-Level Audio Code
| Path | Contents |
project/app/recamera_ipc/common/audio/audio.c / audio.h | Main rkipc audio logic: capture, encoding, and multiplexing with video |
project/app/recamera_ipc/common/audio/rkaudio_mp3.c / .h | MP3 decoding and playback (for prompts, etc.) |
project/app/ao_record_demo/ao_record_demo.c | Recording demo; its Makefile is a template for linking rockit |
project/app/aov_sample/sample_aov_audio.c | Audio capture in low-power mode |
project/app/component/ao_record_service/ | Recording-service component, explicitly collected by project/app/Makefile |
media/samples/simple_test/simple_ai_get_frame.c | Minimal capture example |
media/samples/simple_test/simple_ai_bind_aenc.c | Bind capture to encoding |
media/samples/simple_test/simple_ai_bind_aenc_external_encoder.c | Use an external encoder |
media/samples/simple_test/simple_adec_bind_ao.c | Bind decoding to playback |
media/samples/simple_test/simple_adec_bind_ao_external_decoder.c | Use an external decoder |
media/samples/simple_test/simple_ao_send_frame.c | Send frames directly to playback |
media/samples/example/audio/sample_ai.c, sample_ai_aenc.c | Complete examples |
media/samples/example/test/sample_ai_aenc_adec_ao_stresstest.c | Audio stress test |
rockit Audio Modules
When using MPI, audio uses the same module model as video:
| Module | Header | Purpose |
AI | rk_mpi_ai.h | Audio capture |
AO | rk_mpi_ao.h | Audio playback |
AENC | rk_mpi_aenc.h | Audio encoding (G.711/AAC, etc.) |
ADEC | rk_mpi_adec.h | Audio decoding |
Typical path: AI → AENC → (multiplex with VENC into a stream); playback uses ADEC → AO. Connect modules with RK_MPI_SYS_Bind().
When setting AI channel attributes, match the channel count to asound.conf (four channels = two microphones + two references); use a 16,000 Hz sample rate and S16_LE format.
Audio Algorithms (VQE / RockAA)
Rockchip front-end algorithms—AEC, Acoustic Noise Suppression (ANS), and Automatic Gain Control (AGC)—are provided through RockAA / VQE:
docs/zh/audio/Rockchip_Developer_Guide_Audio_Algorithm_VQE_Introduction_CN.pdf(VQE algorithm guide)docs/zh/audio/Rockchip_Developer_Guide_RockAA_Utils_CN.pdf(RockAA tools)docs/zh/audio/Rockchip_Developer_Guide_Sound_Event_Detection.pdf(sound event detection)media/common_algorithm/(common algorithm libraries)
The echo-reference channel in asound.conf is reserved for VQE's AEC. To enable VQE, enable the relevant algorithm options in the AI channel attributes and make sure the reference-channel data is routed correctly.
Microphone Array Testing
docs/zh/audio/Rockchip_Developer_Guide_Microphone_Array_TEST_CN.pdf describes array consistency testing. For production, use scripts under project/app/recamera_utils/hw_test/, or record the raw six-channel input through ai_debug and inspect each channel.
To diagnose channel-order problems, record a four-channel WAV and inspect its tracks in Audacity. Tap or speak into each microphone and confirm that Mic1, Mic2, Ref, Ref match the ttable mapping.
Common Problems
| Symptom | Cause | Resolution |
arecord: main:831: audio open error: Device or resource busy | Opened hw:0,0 directly, bypassing dsnoop | Use a virtual device such as ai_debug |
Opening ai_* reports Unknown PCM | /etc/asound.conf was not applied | Confirm the overlay was packaged (RK_POST_OVERLAY includes overlay-buildroot-asound) and inspect cat /etc/asound.conf on the device |
| Channel count is wrong (expected 4, got 6) | Used hw:0,0 instead of ai_2mic_2ref | Use the route layer |
| Poor AEC / echo remains | Reference channel is missing or mapped incorrectly | Check ttable entries 2.4 / 3.4; verify hardware Ch4 is the echo reference (hardware verification required) |
| Recording is silent | Selected the wrong channels (for example, Ch1 / Ch3 / Ch5 only) | Record all six raw channels first to identify which channels carry a signal |
| No sound during playback | RK817 / DSM path is disabled, or volume is muted | Check with amixer -c 0 scontrols; unmute in alsamixer |
| Wrong playback pitch due to sample-rate mismatch | plug is inactive or ASRC is disabled | Confirm kernel CONFIG_SND_SOC_ROCKCHIP_ASRC=y and explicitly set -r 16000 |
| Intermittent failures when multiple processes record | ipc_key conflict | Keep key 2026 unique across applications, or change asound.conf and rebuild |
Related Documents
| Document | Path |
| RV-series ACodec Developer Guide | docs/zh/audio/Rockchip_Developer_Guide_Linux_RV_Series_ACodec_CN.pdf |
| VQE Algorithm Introduction | docs/zh/audio/Rockchip_Developer_Guide_Audio_Algorithm_VQE_Introduction_CN.pdf |
| RockAA Tools | docs/zh/audio/Rockchip_Developer_Guide_RockAA_Utils_CN.pdf |
| Microphone Array Test | docs/zh/audio/Rockchip_Developer_Guide_Microphone_Array_TEST_CN.pdf |
| Sound Event Detection | docs/zh/audio/Rockchip_Developer_Guide_Sound_Event_Detection.pdf |
| Audio Troubleshooting | docs/zh/audio/Rockchip_Trouble_Shooting_Linux_Audio_CN.pdf |
English versions are under docs/en/audio/ with similar names; Sound_Event_Detection is available only in Chinese.
