Integrate an Application into the Product Firmware
This guide is for developers who need to include an application in the reCamera Pro product build and firmware image. Select the target board configuration first. Build media beforehand only if your application links against media libraries.
How the Application Build Framework Works​
If you only need to compile a standalone C/C++ or RKNN application and do not need to change the product build or firmware integration, use Seeed's cross-compilation SDK instead.
project/app/Makefile discovers subdirectories with a wildcard:
app_src := $(wildcard ./*/Makefile ./component/fastboot_server/Makefile ./component/ao_record_service/Makefile)
Any directory under project/app/<your-app>/ with a Makefile is automatically included in the build; no separate registration is required.
The outputs are collected in two stages:
project/app/<your-app>/out/          ← PKG_BIN for the individual application
↓ MAROC_COPY_PKG_TO_APP_OUTPUT
project/app/out/ ← RK_APP_OUTPUT, aggregate of all applications
↓ copied again by the top-level Makefile
output/out/app_out/ ← RK_PROJECT_PATH_APP, used to package the rootfs
Key variables from project/app/Makefile.param:
VariableValue / meaning
RK_APP_CROSSCross-compiler prefix; aarch64-rockchip1240-linux-gnu for this board
RK_APP_CFLAGS-march=armv8-a -mtune=cortex-a53 (derived from the toolchain name)
RK_APP_OPTS-D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 plus optimization flags
RK_APP_MEDIA_INCLUDE_PATHoutput/out/media_out/include
RK_APP_MEDIA_LIBS_PATHoutput/out/media_out/lib
RK_APP_OUTPUTproject/app/out
RK_APP_CHIPrv1126b
RK_APP_BUILDROOT_STAGINGsysdrv/source/buildroot/buildroot-2023.02.6/output/staging
RK_APP_BUILDROOT_TARGETsysdrv/source/buildroot/buildroot-2023.02.6/output/target
RK_APP_JOBSNumber of parallel jobs
Optimization is controlled by RK_BUILD_VERSION_TYPE: the default RELEASE mode uses -Os, DEBUG uses -O0 -g -ggdb -pg, and ASAN adds -fsanitize=address -fno-stack-protector -fno-omit-frame-pointer -fsanitize-recover=all.
Makefile.param also adds tools/linux/toolchain/<cross-compiler>/bin to PATH automatically, so you do not need to source env_install_toolchain.sh.
Minimal Example: hello_world​
Create the Directory​
mkdir -p project/app/hello_world && cd project/app/hello_world
hello.c​
#include <stdio.h>
int main(int argc, char *argv[])
printf("Hello World from RV1126B IPC SDK!\n");
return 0;
Makefile​
ifeq ($(APP_PARAM), )
APP_PARAM := ../Makefile.param
include $(APP_PARAM)
endif
export LC_ALL=C
SHELL := /bin/bash
CURRENT_DIR := $(shell pwd)
PKG_NAME := hello_world
PKG_BIN ?= out
ifeq ($(RK_APP_HELLO_WORLD),y)
PKG_TARGET := hello_world-build
endif
all: $(PKG_TARGET)
@echo "build $(PKG_NAME) done"
hello_world-build:
rm -rf $(PKG_BIN); \
mkdir -p $(PKG_BIN)/bin;
$(RK_APP_CROSS)-gcc $(RK_APP_OPTS) $(RK_APP_CFLAGS) hello.c -o $(PKG_BIN)/bin/hello_world
$(call MAROC_COPY_PKG_TO_APP_OUTPUT, $(RK_APP_OUTPUT), $(PKG_BIN))
clean:
rm -rf $(PKG_BIN)
distclean: clean
info:
@echo "$(PKG_NAME): RK_APP_HELLO_WORLD=$(RK_APP_HELLO_WORLD)"
Recipe lines in a Makefile must be indented with a Tab, not spaces. Verify the indentation after copying the code above.
Add a Build Switch​
Edit the file selected by .BoardConfig.mk (project/cfg/BoardConfig_Recamera2/BoardConfig-EMMC-RK801-RV1126B_V1-IPC_64BIT.mk) and add this in the app configuration section:
export RK_APP_HELLO_WORLD=y
The switch is optional (you can remove the ifeq condition from the Makefile to build unconditionally), but keeping it is recommended so you can enable or disable the application for different boards. Existing applications such as recamera_notify, recamera_onvif, recamera_services, recamera_web, and rkllm-inference use RK_APP_xxx switches.
Build and Verify​
./build.sh app                          # Build enabled applications through the aggregate entry point
ls output/out/app_out/bin/hello_world # Confirm the output exists
make -C project/app/hello_world # Build only this application (run lunch first)
make -C project/app/hello_world distclean
To test the application on the device without reflashing the image:
scp output/out/app_out/bin/hello_world root@<device-IP>:/userdata/
ssh root@<device-IP> '/userdata/hello_world'
To include the application in a firmware image:
./build.sh firmware
sudo ./rkflash.sh rootfs
How Output Directories Map into the Rootfs​
When build.sh packages the rootfs, it merges app outputs by directory name:
Directory under app_outLocation on the device
bin//bin or /usr/bin
lib//usr/lib, /lib
etc//etc
share//usr/share
root/Root of the rootfs, / (copied as-is; see __COPY_FILES $RK_PROJECT_PATH_APP/root in __PACKAGE_ROOTFS)
install_to_userdata//userdata partition
The root/ directory is the most flexible option: to install a file at /usr/bin/foo, place it under <PKG_BIN>/root/usr/bin/foo. The project/app/wifi_app application does this with install_out/root/usr/bin.
Use install_to_userdata/ for data that belongs on a writable partition, such as models, configuration, or recordings.
The current SDK has a source issue in the app install_to_userdata/ packaging path that may prevent files from being included in the userdata image. See Source Review and Known Issues for the impact and workaround.
Packaging also processes symbols automatically (__RELEASE_FILESYSTEM_FILES() in build.sh): it removes lib*.la, lib*.a, and all pkgconfig directories. RELEASE mode runs strip on executables and *.so*, except libpthread*.so* and ld-*.so*; .ko files receive --strip-debug. DEBUG mode skips stripping and also installs libc debug symbols.
Real-World Example: Linking Media Libraries​
project/app/ao_record_demo/Makefile is a practical template showing how to link against rockit:
RK_APP_CFLAGS = -I $(RK_APP_MEDIA_INCLUDE_PATH) \
-I $(RK_APP_MEDIA_INCLUDE_PATH)/libdrm \
-I $(RK_APP_MEDIA_INCLUDE_PATH)/rkaiq \
-I $(RK_APP_MEDIA_INCLUDE_PATH)/rkaiq/uAPI \
-I $(RK_APP_MEDIA_INCLUDE_PATH)/rkaiq/uAPI2 \
-I $(RK_APP_MEDIA_INCLUDE_PATH)/rkaiq/algos \
-I $(RK_APP_MEDIA_INCLUDE_PATH)/rkaiq/common \
-I $(RK_APP_MEDIA_INCLUDE_PATH)/rkaiq/xcore \
-I $(RK_APP_MEDIA_INCLUDE_PATH)/rkaiq/iq_parser \
-I $(RK_APP_MEDIA_INCLUDE_PATH)/rkaiq/iq_parser_v2 \
-I $(RK_APP_MEDIA_INCLUDE_PATH)/rkaiq/smartIr \
-I $(RK_APP_OUTPUT)/include \
-I $(RK_APP_OUTPUT)/include/freetype2
RK_APP_LDFLAGS = -L $(RK_APP_MEDIA_LIBS_PATH) -L $(RK_APP_OUTPUT)/lib
RK_APP_OPTS += -Wl,-rpath-link,$(RK_APP_MEDIA_LIBS_PATH):$(RK_APP_PATH_LIB_INCLUDE)/root/usr/lib:$(RK_APP_OUTPUT)/lib
LD_FLAGS += $(RK_APP_OPTS) $(RK_APP_LDFLAGS) $(RK_APP_CFLAGS) \
-Wl,-Bstatic -pthread -lrockit -lrtsp \
-lrockchip_mpp -lrksysutils -lrga -Wl,-Bdynamic \
-Wl,--gc-sections -Wl,--as-needed \
-lrkaiq -lstdc++ -lm
Key points:
  • The include root is $(RK_APP_MEDIA_INCLUDE_PATH). rkaiq headers are spread across multiple subdirectories, so each one needs an -I option.
  • -Wl,-rpath-link,... resolves indirect dependencies at link time; without it, the linker may report warning: libxxx.so not found.
  • -Wl,-Bstatic ... -Wl,-Bdynamic statically links rockit/rtsp/mpp/rga while keeping rkaiq dynamic. This follows Rockchip reference-app conventions and reduces runtime dependencies under /oem/usr/lib.
  • -Wl,--gc-sections -Wl,--as-needed reduce binary size.
Start the Application at Boot​
The reCamera Pro application startup entry point is /oem/usr/bin/RkLunch.sh (the stop script is RkLunch-stop.sh). __PACKAGE_OEM() in build.sh generates an init script under /etc/init.d/ with this content:
#!/bin/sh
[ -f /etc/profile.d/RkEnv.sh ] && source /etc/profile.d/RkEnv.sh
case $1 in
start) sh /oem/usr/bin/RkLunch.sh ;;
stop) sh /oem/usr/bin/RkLunch-stop.sh ;;
*) exit 1 ;;
esac
Recommended approach: append your application startup command to RkLunch.sh. The source file is project/app/recamera_ipc/src/rv1126b_ipc/RkLunch.sh. This lets your application share the PATH and LD_LIBRARY_PATH set by RkEnv.sh (including /oem/usr/lib) and use the common stop flow.
If you need a separate init script, follow the overlay pattern (start-stop-daemon -S -b -m -p <pidfile> -x <executable> -- <arguments>) and name the file S<priority><name> under <PKG_BIN>/root/etc/init.d/. Existing priorities are S00board-id, S10log, S15watchdog, S20hwclock, S40gmgr, S40skt2ws, S40tmir, S49rcisd, S50sshd, S50ttyd, S50go2rtc, S70vsftpd, S99factorykey, S99inotify_passwd, and S99led.
Use CMake Instead of a Makefile​
recamera_ipc and recamera_web_backend use CMake. Keep a thin outer Makefile so the app framework's wildcard finds the application, then invoke CMake inside it:
endif
PKG_BIN ?= out
all:
rm -rf build && mkdir -p build
cd build && cmake .. \
-DCMAKE_TOOLCHAIN_FILE=../cmake/toolchain.cmake \
-DCMAKE_INSTALL_PREFIX=$(CURDIR)/$(PKG_BIN)
make -C build -j$(RK_APP_JOBS) install
distclean:
rm -rf build $(PKG_BIN)
clean: distclean
See Choose a Development Path for the toolchain-file approach.
Rust / Go / Node.js / Python Applications​
The project/app/ directory includes examples written in languages other than C; use their build approach as a reference:
ApplicationLanguageBuild approach
recamera_services/gmgrRustCargo.toml + Cross.toml; use cross for Docker-based cross-compilation. setup-libgpiod.sh prepares dependencies
recamera_web/recamera_web_reactNode.js / Reactpackage.json + nginx.conf; outputs static assets
recamera_web/recamera_web_backendC/C++CMake + thirdparty
recamera_notify/notify-serverPythonRun the installation script and install requirements.txt; no compilation
go2rtc-related appsGoPrebuilt binaries are placed in the overlay under oem/usr/bin/go2rtc (go2rtc-arm and go2rtc-arm64)
Go applications are supplied as prebuilt binaries in the overlay (overlay-buildroot-go2rtc-arm64/oem/usr/bin/go2rtc). This means the current build flow copies prebuilt Go binaries into the overlay instead of compiling them inside the SDK.
Checklist​
  • The application is under project/app/ and has a Makefile.
  • The Makefile includes ../Makefile.param near the beginning.
  • It provides all, clean, and distclean targets (the top-level clean calls distclean in each subdirectory and fails if the target is missing).
  • Outputs are copied to $(PKG_BIN), followed by a call to MAROC_COPY_PKG_TO_APP_OUTPUT.
  • Add the RK_APP_<NAME>=y switch to the board configuration.
  • After the build, verify that your files appear under output/out/app_out/.
