BSP Build Environment
One-Shot Installation Script
The SDK root contains setup_build_env.sh (the actual script is project/setup_build_env.sh, with a symbolic link at the root). It is idempotent: it does not reinstall or upgrade tools that are already installed at an acceptable version, so you can run it repeatedly.
cd recamera-pro-sdk-v1.0.10
./setup_build_env.sh # Install all missing tools
./setup_build_env.sh --check # Dry run: report missing tools without changing anything
./setup_build_env.sh --help # Show script help
On the first run, use --check to see what is missing before deciding whether to install packages or access the network.
Install Tools for Your Build Target
Tool requirements depend on what you plan to build. For a first full SDK build, using the script to install and check all dependencies is the easiest approach. If you are building only a C/C++ application, first check what its Makefile, linked libraries, and sysroot require, and install only those tools. Rust, Go, Node.js, and Docker are used by specific higher-level applications in the SDK; they are not universal prerequisites for building the kernel or every C program.
The script summarizes and checks the required tools. Its installation stages are:
| Stage | Contents | Used by |
| Step 1 | Hardware checks: 64-bit CPU and free space on the SDK partition (≥20 GB; ≥100 GB recommended) | All builds |
| Step 2 | Basic build packages via apt: repo git make gcc g++ cmake bison flex libssl-dev autoconf pkg-config python3 device-tree-compiler, etc. | U-Boot / kernel / Buildroot / common application dependencies |
| Step 3 | Rust (rustup / cargo), Docker (≥27.0.0, and add the user to the docker group), cross (Rust cross-compilation helper), nvm / Node.js (≥18) | recamera_services, recamera_web |
| Step 4 | CMake ≥3.21, libblkid-dev, libprotobuf-dev, protobuf-compiler | recamera_ipc, common/vigil |
| Step 5 | Go ≥1.24.0, UPX | recamera_go2rtc and related applications |
| Step 6 | Print a version summary for all tools | All builds |
Why does a “C SDK” check for Rust, Go, and Node.js? This is a complete product source package, not just C code.
recamera_servicesuses Rust, go2rtc-related programs use Go, the Web frontend uses Node.js tooling, and the notification service uses Python. These tools are needed only when building the corresponding components. If a full build fails because a tool is missing, first identify which application failed. See the reCamera Upper-Layer Service Architecture for the application list.
Users and Permissions
- Run the script as a regular user with sudo access, or as root.
- When invoked as
sudo ./setup_build_env.sh, user-level tools such as rustup, nvm, and Go configuration are installed for the real user identified by$SUDO_USER, not for root. This is intentional and avoids permission problems during later builds.
Required Steps After Installation
- If the script added the current user to the
dockergroup, log out and sign in again, or runnewgrp dockertemporarily, for the change to take effect. - Open a new terminal or run
source ~/.bashrcso the Go, cargo, and nvm PATH changes take effect. - Confirm that no required tool is marked
NOT INSTALLEDin the Step 6 version summary.
Verify the environment with:
Restricted Networks: Mirrors and Offline Packages
The script supports environment variables for overriding download sources:
| Environment variable | Overrides |
GO_MIRROR_BASE | Go download base URL |
DOCKER_REPO_BASE | Docker apt repository base URL |
CMAKE_BASE_URL | CMake download base URL |
RUSTUP_DIST_SERVER | rustup distribution server |
For example:
export GO_MIRROR_BASE=https://golang.google.cn/dl
export RUSTUP_DIST_SERVER=https://rsproxy.cn
If you place the offline archive go1.24.0.linux-*.tar.gz in the SDK root, the script will use it to install Go before attempting a network download.
Manual Installation (Without the Script)
If company policy does not allow running the installer, install at least:
sudo apt install -y build-essential git make cmake bison flex libssl-dev \
autoconf pkg-config python3 device-tree-compiler libblkid-dev \
libprotobuf-dev protobuf-compiler
Minimum version requirements:
- CMake ≥ 3.21 (
recamera_ipcrequires it in its CMakeLists) - Docker ≥ 27.0.0 (required by the Rust
crosscross-compiler) - Node.js ≥ 18 (frontend build)
- Go ≥ 1.24.0 (go2rtc)
You do not need to install the cross-toolchain manually. The SDK includes it under tools/linux/toolchain/:
aarch64-rockchip1240-linux-gnu(GCC 12.4.0, 64-bit; used by reCamera Pro)arm-rockchip1240-linux-gnueabihf(32-bit)
project/app/Makefile.param automatically adds tools/linux/toolchain/<RK_TOOLCHAIN_CROSS>/bin to PATH, so you do not need to modify the system PATH.
Check Whether the Build Environment Is Ready
The SDK provides this check command:
./build.sh check
It checks dependencies for the component SDKs. After running lunch, ./build.sh info also prints the current board configuration and all RK_* variables to help verify that the environment is loaded correctly.
Note:
./build.sh --helpis not the help command. An unrecognized argument causesbuild.shto show the board-selection menu. The usage information is in theusage()function inproject/build.sh; it is also summarized in the command table in First Full Build.
Common Installation Problems
| Symptom | Cause | Resolution |
docker: permission denied | The group change has not taken effect | Log out and back in, or run newgrp docker |
go: command not found after installation | PATH has not been refreshed | Open a new terminal or run source ~/.bashrc |
| rustup download times out | Restricted network | Set RUSTUP_DIST_SERVER and run the installer again |
| Disk-space check fails | Less than 20 GB free on the partition | Use another partition or free space and retry; build outputs can require tens of GB more |
cross build fails | Docker is not running | Run sudo systemctl start docker |
