Device Access and Debugging
This page summarizes the debug channels actually included in the firmware. The information comes from the board overlay configuration under project/cfg/BoardConfig_Recamera2/overlay/. Channels can be added or removed with the RK_POST_OVERLAY option; see System Customization (DTS / Kernel / Buildroot / Overlay).
Channel Overview
| Channel | Port | Enabled by | Purpose |
| Serial console | ttyFIQ0, 1500000 8N1 | U-Boot CONFIG_BAUDRATE | Boot logs, U-Boot interaction, recovery |
| SSH | 22 | overlay-buildroot-sshd (S50sshd) | Primary development channel |
| Web terminal ttyd | 7681 | overlay-buildroot-ttyd (S50ttyd) | Open a shell in a browser |
| WebSocket logs | 8765 (loopback only) | overlay-buildroot-log (S10log) | View live logs in the Web UI |
| go2rtc API | 1984 (127.0.0.1 only) | overlay-buildroot-go2rtc (S50go2rtc) | Stream-management API |
| go2rtc WebRTC | 8555 | Same as above | Receive WebRTC streams |
| go2rtc RTSP | 554 (enabled as needed) | Same as above | External RTSP |
| Internal rkipc RTSP | 5554 (127.0.0.1) | recamera_ipc | Upstream source for go2rtc |
| vsftpd | 21 | overlay-buildroot-vsftpd (S70vsftpd) | File transfer |
Serial Console
U-Boot sets CONFIG_BAUDRATE=1500000 (sysdrv/source/uboot/u-boot/configs/rv1126b_recamera2_defconfig:162). The kernel command line uses console=ttyFIQ0 and earlycon=uart8250,mmio32,0x20810000.
# On the host (USB-to-serial adapter)
picocom -b 1500000 /dev/ttyUSB0
# Or
minicom -D /dev/ttyUSB0 -b 1500000
The baud rate is 1500000, not the common 115200. A mismatched baud rate produces garbled output.
The serial console is the only channel available when the system cannot boot. Use it to debug startup problems such as kernel panics, rootfs mount failures, and DDR initialization.
SSH
Key settings in overlay-buildroot-sshd/etc/ssh/sshd_config:
PermitRootLogin yes
PasswordAuthentication yes
AuthorizedKeysFile .ssh/authorized_keys
UsePAM yes
UseDNS no
Subsystem sftp /usr/libexec/sftp-server
By default, root password login is enabled, and public-key authentication is also supported. SFTP is available for file transfers.
ssh root@<device-IP>
scp my_app root@<device-IP>:/userdata/
sftp root@<device-IP>
Failed-Login Lockout (PAM)
overlay-buildroot-sshd/usr/libexec/ssh-login-lock.py uses PAM to protect against brute-force attempts:
- After 5 consecutive failures (
MAX_ATTEMPTS = 5), the account is locked for 300 seconds (LOCKOUT_SECONDS = 300). - Attempts are counted by client IP (
PAM_RHOST), using/proc/uptimeas the time base, so a reboot clears the counter. - State file:
/userdata/config/system/login_lock.json; the associated lock file islogin_lock.json.lock.
If locked out, wait 300 seconds, reboot, or log in over the serial console and remove /userdata/config/system/login_lock.json.
Web Terminal (ttyd)
overlay-buildroot-ttyd/oem/usr/etc/init.d/S50ttyd starts:
ttyd -p 7681 /oem/usr/bin/ssh-login-whitelist.sh
Open http://<device-IP>:7681 in a browser; it prompts for a username. The wrapper script ssh-login-whitelist.sh allows only users in its allowlist, then runs exec ssh <user>@localhost:
ALLOWED_USERS=("root" "admin")
In other words, ttyd is effectively an SSH client in the browser. Authentication still uses SSH (including the PAM lockout policy above); users outside the allowlist are rejected. To add a user, edit the ALLOWED_USERS array and rebuild the rootfs, or edit the script directly on the device (/oem may need to be remounted if it is read-only).
Logging System
The firmware has three logging layers. Understanding their roles can save debugging time.
1. syslog-ng (overlay-buildroot-syslog-ng/etc/syslog-ng.conf, @version 3.38)
| Output | Path / destination | Format |
d_Recamera2 | /var/log/Recamera2.log | JSON: {"sTimestamp","sLevel","sData"} |
d_Recamera2_developer | /var/log/Recamera2_developer.log | Text: ISODATE HOST PROGRAM[PID]: [LEVEL] MESSAGE |
d_python_udp | UDP 127.0.0.1:5140 | Forwarded to the WebSocket log service |
Log files are owned by root:adm with permissions 0640. For debugging, start with Recamera2_developer.log (human-readable); use Recamera2.log (JSON) for programmatic parsing.
# tail -f /var/log/Recamera2_developer.log
# tail -n 200 /var/log/Recamera2.log
2. WebSocket Log Service (overlay-buildroot-log/oem/usr/bin/websocket_log.py)
S10log launches the service with python3:
- Listens on UDP
127.0.0.1:5140for messages forwarded by syslog-ng. - Provides a WebSocket service on port 8765, bound to
127.0.0.1(SERVER_IP = "127.0.0.1"). - Keeps the latest 2000 messages in memory (
MAX_LOG_SIZE = 2000).
Because it binds to loopback, forward the port over SSH to access it from the host:
ssh -L 8765:127.0.0.1:8765 root@<device-IP>
# Then connect a browser or script to ws://localhost:8765
The Web UI's live log panel uses this path.
3. Serial Console / dmesg
Kernel messages are sent to console=ttyFIQ0. On the device, use dmesg to inspect the kernel ring buffer.
Video Streams (go2rtc)
Default configuration in overlay-buildroot-go2rtc/oem/usr/etc/go2rtc/go2rtc.yaml:
streams:
main:
- rtsp://127.0.0.1:5554/live/0
sub:
- rtsp://127.0.0.1:5554/live/1
api:
listen: "127.0.0.1:1984"
webrtc:
listen: ":8555"
rtsp:
listen: "" # Not listening by default
The architecture is: recamera_ipc (rkipc) provides an internal RTSP source at 127.0.0.1:5554 → go2rtc pulls the stream and exposes it over protocols such as WebRTC/HLS. main is the main stream and sub is the substream.
The External RTSP Port Is Configured Dynamically
When S50go2rtc starts, it reads /userdata/config/rkipc.ini and decides whether to expose RTSP on :554, using this priority order:
- Check
enable=1under[video.0.rtsp]. - Otherwise, check
enable=1under[video.0.onvif]. - Otherwise, check
enable=1under[video.1.rtsp]. - If none are enabled, do not open the RTSP port; use the default configuration only.
When RTSP is enabled, it copies the default YAML to /tmp/go2rtc/go2rtc.yaml and adds rtsp: listen: ":554". If authtype=1, it also includes the username and password from the INI file. This avoids modifying the default configuration under the read-only /oem directory.
Useful debugging commands:
# cat /userdata/config/rkipc.ini | grep -A5 '\[video.0.rtsp\]'
# cat /tmp/go2rtc/go2rtc.yaml # Active configuration
# cat /var/run/go2rtc.pid
# /oem/usr/etc/init.d/S50go2rtc restart
After changing RTSP / ONVIF switches in rkipc.ini, restart go2rtc so it regenerates the configuration.
Stream URLs (when RTSP is enabled):
rtsp://<user>:<pass>@<device-IP>:554/...
http://<device-IP>:8555/ # WebRTC
The URL path depends on the go2rtc stream name (main / sub). Add a complete example after verifying it on a device.
FTP (vsftpd)
overlay-buildroot-vsftpd/etc/vsftpd.conf configures port 21, local_enable=YES, write_enable=YES, chroot_local_user=YES, and ssl_enable=NO. The user list is root and admin.
The configuration directory is hidden and access is denied:
hide_file={config,*/config,config_tar,*/config_tar}
deny_file={config,*/config,config_tar,*/config_tar}
As a result, /userdata/config is not visible over FTP. This is an intentional product design; configuration should be changed through the Web UI or API. Use SSH/SFTP instead of FTP when debugging.
Environment Variables and Directory Conventions
overlay-buildroot-rkenv/etc/profile.d/RkEnv.sh sets these variables for login shells:
export OEM_HOME=/oem
export PATH=$PATH:/oem:/oem/bin:/oem/usr/bin:/oem/sbin:/oem/usr/sbin
export LD_LIBRARY_PATH=/oem/usr/lib:/oem/lib:$LD_LIBRARY_PATH
export HOME=/userdata
This means:
/oemcontains Seeed / Rockchip applications and libraries (includinggo2rtc, thettydwrapper,websocket_log.py, andlibrknnrt.so)./userdatais writable and stores configuration (/userdata/config/) and user data. It is also the defaultHOME.- Your cross-compiled program can load libraries under
/oem/usr/libthroughLD_LIBRARY_PATH. If it runs from an init script, make sure the environment is set there as well.
Other Built-In Services
| Script | Purpose |
overlay-buildroot-board-id/etc/init.d/S00board-id | Runs early during boot and reads the ADC (/sys/bus/iio/devices/iio:device0) to identify the baseboard and expansion-board model; writes the result to /run/board_id.env. It averages three samples with a tolerance of 440. Voltage levels are 0.0/0.3/0.6/0.9/1.2/1.5/1.8 V and map to V0.9–V1.5 and TYPE0–TYPE6. |
overlay-buildroot-hwclock/etc/init.d/S20hwclock | Runs hwclock --hctosys --utc at boot to sync from the RTC and writes the time back at shutdown. |
overlay-buildroot-watchdog/etc/init.d/S15watchdog | Starts the hardware watchdog with watchdog -T 30 -t 15 /dev/watchdog (30 s timeout, 15 s keepalive interval); writes V to /dev/watchdog on stop to disable it. |
overlay-buildroot-udhcpc/usr/share/udhcpc/default.script | Customized DHCP script that writes /tmp/resolv.conf.<iface> per interface and merges them into /etc/resolv.conf with eth0 taking priority; supports a manual-DNS mode marker at /userdata/config/system/eth0_dns_mode. |
overlay-buildroot-banner | reCamera ASCII logo in /etc/motd; /etc/profile.d/banner.sh prints it only in interactive non-SSH sessions. |
The comment in
S20hwclocksays the RTC stores local time, but the command uses--utc; these indicate different time conventions. If a clock offset matches the timezone offset, investigate this first. Verify on a device.
Watchdog note: -T 30 means any blocking operation that prevents the watchdog process from refreshing it for more than 30 seconds can cause a hard reset. If you need a long breakpoint while debugging, stop S15watchdog first.
Push Files to the Device Without Reflashing
This is one of the most common operations in day-to-day development. Three options:
# 1. scp (simplest)
scp output/out/app_out/bin/hello_world root@<device-IP>:/userdata/
# 2. Batch transfer with sftp
sftp root@<device-IP> <<< $'put output/out/app_out/bin/hello_world /userdata/'
# 3. adb (only if adbd is enabled in the firmware) — verify on a device
adb push output/out/app_out/bin/hello_world /userdata/
Copy files to /userdata rather than /oem: /oem usually comes from a read-only image, while /userdata is writable.
# ssh root@<device-IP>
# chmod +x /userdata/hello_world && /userdata/hello_world
If the program cannot find a shared library, first check that LD_LIBRARY_PATH includes /oem/usr/lib, or run ldd /userdata/hello_world to identify the missing library. See Choose a Development Path.
Diagnose Network Configuration
# ip addr # Check whether eth0 / wlan0 received an address
# cat /etc/resolv.conf # Generated by udhcpc; eth0 takes priority when merging
# cat /tmp/resolv.conf.eth0 # Per-interface file
# cat /userdata/config/system/eth0_dns_mode # Check for manual DNS mode
# netstat -tlnp # Check whether ports such as 22/7681/21/8555 are listening
Wi-Fi is enabled by RK_ENABLE_WIFI=y + RK_ENABLE_WIFI_CHIP=AP6XXX; the application is under project/app/wifi_app.
Five-Minute Checklist for a New Board
- Connect the serial console at 1500000 and confirm that boot logs and the reCamera banner appear.
- Run
ip addrto get the IP address, then confirm thatssh root@<IP>works. - Check
cat /proc/versionfor kernel 6.1.157 anduname -mforaarch64. - Run
ls /oem/usr/lib | headand confirm that application libraries such aslibrknnrt.soare present. - Run
netstat -tlnpand confirm that go2rtc (8555), ttyd (7681), and sshd (22) are listening. - Run
tail -f /var/log/Recamera2_developer.logto inspect application logs. - Check
cat /run/board_id.envto confirm that the baseboard and expansion-board IDs were detected correctly.
