Download and Extract the Source Package
Download the archive here: recamera-pro-sdk-v1.0.10.tar.gz. This is the full BSP source package described in this guide.
Package Information
| Item | Value |
| File name | recamera-pro-sdk-v1.0.10.tar.gz |
| Archive size | About 3.7 GB (3,928,456,385 bytes) |
| Extracted size | About 12 GB |
| Top-level directory | recamera-pro-sdk-v1.0.10/ |
| SHA-256 | 0c171f7a65ed87a7112f07eb0408b91b934f456af32d91608f961a4a21bced8a |
The SHA-256 value was calculated from the actual distribution archive when this Wiki was written. Repacked archives or bundles created with
./build.sh savemay have a different checksum; in that case, use the checksum from the release record.
Host Requirements
| Item | Requirement |
| Operating system | 64-bit Ubuntu, 20.04 or later recommended |
| CPU architecture | x86_64 or aarch64 |
| Disk space | At least 20 GB free on the SDK partition; 100 GB or more is recommended if you keep multiple build outputs |
| Memory | 16 GB or more recommended; parallel media and kernel builds can use substantial memory |
| Network | Required on the first setup_build_env.sh run to download tools and dependencies |
Measured reference: on a host with a 937 GB SDK partition (242 GB used), extracting the 3.7 GB archive to 12 GB took about 20 seconds with 24-core parallel pigz. The system's single-threaded gzip can take several times longer.
Verify the Archive
sha256sum recamera-pro-sdk-v1.0.10.tar.gz
Compare the output with the checksum above. If it does not match, the download may be truncated or repackaged. Do not continue.
Extract the Archive
Parallel extraction with pigz is recommended:
sudo apt install -y pigz
tar -I "pigz -d -p 16" -xf recamera-pro-sdk-v1.0.10.tar.gz
Or use the standard command:
tar -xzf recamera-pro-sdk-v1.0.10.tar.gz
After extraction, confirm that the main entry points exist. These are symbolic links into project/:
cd recamera-pro-sdk-v1.0.10
ls -l build.sh rkflash.sh readme_cn.txt setup_build_env.sh
Expected output includes:
build.sh -> project/build.sh
rkflash.sh -> project/rkflash.sh
readme_cn.txt -> project/readme_cn.txt
Important Precautions
- Do not extract or copy this package on Windows. The SDK relies heavily on symbolic links (
build.sh,.BoardConfig.mk, and PDF shortcuts underdocs/) and executable permissions (build.sh,rkflash.sh, and binaries undertools/). Windows filesystems may lose these, causing build failures or missing commands. The bundledreadme_en.txtalso calls this out. - If you need to transfer the package between Windows and Linux, keep it as a tar archive and extract it on Linux, or use
git/repoto check it out. - Avoid spaces and non-ASCII characters in the installation path. Buildroot and some Makefiles do not handle spaces reliably.
- Do not build on a
noexec-mounted partition; binaries such astools/linux/Linux_Upgrade_Tool/upgrade_toolneed execute permission. - The extracted SDK does not contain
.repo/; this is a source snapshot. Ignore therepo syncinstructions inreadme_en.txtbecause they do not apply to this package.
Repair Lost Executable Permissions (Recovery)
If the package was transferred through an environment that did not preserve permissions, try:
chmod +x build.sh rkflash.sh setup_build_env.sh project/build.sh project/rkflash.sh
chmod +x tools/linux/Linux_Upgrade_Tool/upgrade_tool
find . -name "*.sh" -exec chmod +x {} \;
Once symbolic links are lost, chmod cannot restore them; re-extract the original tar archive.
First Step After Extraction
./setup_build_env.sh --check # Check only; report missing tools without changing anything
See Set Up the Build Environment for details.
Upgrade or Switch to a New SDK Version
- Each SDK release is a separate tar archive. Extract a new version into a different directory; do not mix versions.
- Board-configuration numbers in the
lunchmenu are generated by sorting filenames underproject/cfg/and can change between releases. Record the full configuration filename in documentation and scripts; do not rely on the menu number. - To migrate your application, copy the entire
project/app/<your-directory>/directory into the same location in the new SDK, then enable the correspondingRK_APP_xxx=yoption in the new board configuration.
