OTA and Firmware Releases
Where to Find the Version
| Location | Value | Description |
Board configuration RK_OTA_VERSION | V1.0.10 | Written to /etc/ota_version in the rootfs during packaging |
| Archive name | recamera-pro-sdk-v1.0.10 | Distribution package name |
Device /etc/ota_version | Same as above | Version reported at runtime |
Device /bin/sdkinfo | Build Time / SDK Version / BoardConfig | Generated by build.sh during packaging |
project/cfg/BoardConfig_Recamera2/RECAMERA2-IPC-RELEASE-NOTES.md | Change log | Currently contains only v0.0.1 - init; keep it up to date |
Check the version on the device:
# cat /etc/ota_version
# /bin/sdkinfo
/bin/sdkinfo output looks like this:
#!/bin/sh
echo Build Time: 2026-08-28-09:28:00
echo SDK Version: NONE
echo SDK BoardConfig: BoardConfig-EMMC-RK801-RV1126B_V1-IPC_64BIT.mk
The current source snapshot does not include
.repo/, so SDK Version insdkinfomay showNONE. See Source Review and Known Issues for the source-based explanation. Verify the device version using both/etc/ota_versionand the build record.
For each release, update both RK_OTA_VERSION in the board configuration and RECAMERA2-IPC-RELEASE-NOTES.md.
OTA Mechanism
Related Configuration
export RK_ENABLE_RECOVERY=y
export RK_MISC=recovery-misc.img
export RK_OTA_RESOURCE="boot.img rootfs.img"
export RK_ENABLE_OTA=y # Comment: Used for set/get factory reset flag
OTA therefore updates only the boot and rootfs partitions. It does not update U-Boot, idblock, env, or userdata. This is intentional: bootloader and partition-table updates carry more risk, and user data must be preserved.
Create an OTA Package
./build.sh all # First create boot.img and rootfs.img under output/image/
./build.sh ota
ls -lh output/image/update_ota.tar
Package Contents and Update Script
build_ota() generates RK_OTA_update.sh and packs it with the images into update_ota.tar using tar -cvhf (note that -h follows symbolic links). The eMMC branch of the script is:
#!/bin/sh
set -e
COMMON_DIR=`dirname $(realpath $0)`
TOP_DIR=$(realpath $COMMON_DIR/../..)
cd $TOP_DIR
echo "Start to write partitions"
for image in $(ls /dev/block/by-name)
do
if [ -f $COMMON_DIR/${image}.img ]; then
echo "Writing $image..."
dd if=$COMMON_DIR/${image}.img of=/dev/block/by-name/$image || exit 1
fi
done
echo "Erase misc partition"
dd if=/dev/zero of=/dev/block/by-name/misc bs=32 count=1 seek=512 || exit 2
Key points:
- The script iterates over every partition under
/dev/block/by-name/and writes a partition if the archive contains an image with the same name. Add an image toRK_OTA_RESOURCEto include it in the OTA package; the script itself does not need to change. - It clears the flag in the misc partition at the end (offset 512 blocks of 32 bytes), so the next boot does not enter recovery again.
- With
RK_ENABLE_RECOVERY=y, the script is packaged using-C $OTA_SCRIPT_PATH RK_OTA_update.sh. - NAND media use a different branch with
flash_eraseall+nandwrite -p. This board uses eMMC, so that branch does not apply.
OTA Flow (Conceptual)
Application downloads update_ota.tar → extracts it to a directory
Write the recovery flag to the misc partition (RK_ENABLE_OTA provides set/get factory-reset flag interfaces)
Reboot → U-Boot reads misc → enters recovery
Recovery runs RK_OTA_update.sh → writes boot/rootfs with dd → clears the misc flag
Reboot into the new system → verify with cat /etc/ota_version
Build the recovery image separately with ./build.sh recovery (RK_KERNEL_RECOVERY_DEFCONFIG=rv1126b_ipc_defconfig plus the rv1126b-recovery.config fragment); the ramdisk content is under output/out/ramdisk/.
The upper-layer application code that triggers recovery and OTA is in
recamera_ipc/recamera_services(the Web UI's “Firmware Update” and “Factory Reset” actions). This page covers only SDK-side packaging. The specific API calls still need to be verified on a device.
Factory Reset
The comment for RK_ENABLE_OTA=y says that it provides set/get factory reset flag functions. In practice, a factory reset writes a flag to misc and clears or recreates userdata. User data resides under /userdata, including /userdata/config/rkipc.ini, /userdata/config/system/login_lock.json, and eth0_dns_mode; a factory reset resets these settings.
Full Firmware Image
./build.sh updateimg # Package all partition images as output/image/update.img
./build.sh unpackimg # Extract update.img
Use update.img with:
sudo tools/linux/Linux_Upgrade_Tool/upgrade_tool uf output/image/update.img
./rkflash.sh updatedoes not work because that branch is commented out in the script. Useupgrade_tool ufdirectly.
Factory Image
./build.sh factory
ls output/image/factory/
This internally invokes tools/linux/SocToolKit/bin/linux/programmer_image_tool -i output/image/update.img -o output/image/factory/ -t emmc. The image type is determined by RK_BOOT_MEDIUM. NAND media use -b <blockKB> -p <pageKB> [-s <oobB>]; override the defaults (0x20000 / 2048 / 128) with RK_NAND_BLOCK_SIZE, RK_NAND_PAGE_SIZE, and RK_NAND_OOB_SIZE.
Release Archives: save / allsave
./build.sh save # Create an archive
./build.sh save xml # Generate only the repo manifest XML, then exit
./build.sh allsave # all + save; default when ./build.sh is run without arguments
build_save() constructs the archive path and converts it to uppercase:
IMAGE/<application-scenario>_<boot-medium>_<power-scheme>_<hardware-version>_<YYYYMMDD.HHMM>_RELEASE_TEST/
For this board configuration, the path looks like:
IMAGE/IPC_64BIT_EMMC_RK801_RV1126B_V1_20260828.0928_RELEASE_TEST/
├── IMAGES/ # All contents of output/image/
├── PATCHES/ # Patches and repo information (__GET_REPO_INFO)
├── DEBUG_FILES/
│ ├── kernel/vmlinux.tar.bz2 # Unstripped kernel for crash analysis
│ ├── media_out.tar.bz2 # Complete media outputs
│ ├── app_out.tar # Complete application outputs
│ └── uboot/uboot.debug.tar.bz2
└── build_info.txt # BUILD-ID: <hostname>:<user> + build_info output
build_save()uppercases the archive path, so the directory is namedIMAGE/, as shown in the SDK quick-start guide.The suffix is always
_RELEASE_TEST, even for an actual production release. To distinguish production and test builds, rename the archive or record the status inbuild_info.txt.
DEBUG_FILES are essential for investigating field issues. Keep the archive for every external release, especially vmlinux, which is required to decode kernel panic call stacks.
Record Build Information and Configuration
./build.sh info prints:
- The real path of the current
BOARD_CONFIG - All non-empty
RK_*environment variables, sorted make infooutput from the sysdrv, media, and app component SDKs- Power-domain check results (
build_check_power_domain)
Attach this output to the release record to avoid later guesswork about how the firmware was built.
./build.sh info > release_info_$(date +%Y%m%d).txt 2>&1
build_info() also tries to link or copy project/cfg/BoardConfig_Recamera2/RK-RELEASE-NOTES-Recamera2.txt to the SDK root if that file exists. The current file is named RECAMERA2-IPC-RELEASE-NOTES.md, which does not match the RK-RELEASE-NOTES-<board-name>.txt pattern the script searches for, so it will not be promoted automatically. The root-level RECAMERA2-IPC-RELEASE-NOTES.md is a symbolic link to it.
Release Checklist
Before the Build
- Sync
git/ internal repositories to the target tag and confirm the working tree is clean. - Update
RK_OTA_VERSIONin the board configuration. - Update
RECAMERA2-IPC-RELEASE-NOTES.mdwith this release's changes (it currently contains onlyv0.0.1 - init; keep it maintained). - Run
./build.sh lunchand selectBoardConfig_Recamera2/BoardConfig-EMMC-RK801-RV1126B_V1-IPC_64BIT.mk. - Run
./setup_build_env.sh --check; confirm that no tools are missing.
Build
- Run
./build.sh cleanwhen switching versions or board configurations. - Run
./build.sh allsaveand keep the build log. - Verify that
boot.imgis smaller than 11 M androotfs.imgis smaller than 3 G underoutput/image/. - Confirm that
IMAGE/.../build_info.txtwas generated.
Verify
- Flash a clean board with
sudo ./rkflash.sh alland confirm that it boots to the banner. - Confirm the BoardConfig name in
/bin/sdkinfoand verify thatcat /etc/ota_versionmatches the new version. - Video: confirm that the Web UI displays video and go2rtc WebRTC on
:8555can receive a stream. - AI inference: confirm that the NPU model loads and
recamera_notifyreceives and forwards events. - Audio: verify that
ai_debugcan record four channels and the speaker outputs audio. - OTA: upgrade from the previous release using
update_ota.tarand confirm that/userdataconfiguration is preserved. - Factory reset: confirm that the device returns to its default configuration.
- Stability: run relevant stress tests under
media/samples/example/test/andrecamera_utils/stress_test/. - Watchdog: confirm that a long-running test does not trigger a reset (
S15watchdog, 30-second timeout).
Archive
- Upload the entire
IMAGE/directory, includingDEBUG_FILES/, to the internal artifact repository. - Record
update.img,update_ota.tar, the version, and SHA-256 together. - Attach the output of
./build.sh infoto the release record.
Command Quick Reference
| Command | Output |
./build.sh firmware | Partition images under output/image/ |
./build.sh updateimg | output/image/update.img |
./build.sh ota | output/image/update_ota.tar |
./build.sh factory | output/image/factory/ |
./build.sh recovery | output/image/recovery.img |
./build.sh save | IMAGE/<...>_RELEASE_TEST/ |
./build.sh info | Print current configuration; does not write a file |
./build.sh unpackimg | Extract update.img |
Related Documents
docs/en/Rockchip_User_Guide_SDK_Application_And_Synchronization_EN.pdf: SDK application and synchronization (request SDK updates from Rockchip)docs/en/Rockchip_User_Guide_Bug_System_EN.pdf: file issues with Rockchipdocs/zh/ipc/Rockchip_RV1126B_Linux_IPC_SDK_Release_V1.0.0_20250620_CN.pdf: upstream SDK release notesproject/cfg/BoardConfig_IPC/RK-RELEASE-NOTES-IPC.txt: release-note format for the Rockchip IPC reference board; use it as a template for maintainingRECAMERA2-IPC-RELEASE-NOTES.md
