Product Service Architecture
This page describes the responsibilities, languages, build options, startup methods, and customization entry points for applications under project/app/. This is where Seeed has made the largest additions to the original Rockchip SDK, and where product customization most often takes place.
Service Overview​
sensor ──► rockit ──►│ recamera_ipc (rkipc, C) │──► Internal RTSP 127.0.0.1:5554
▲ │ Main application for video, audio, recording, and AI inference │ │
rkaiq(ISP) │ protobuf ┌─────────┐
rockiva(NPU) │ Unix socket │ go2rtc │──► WebRTC :8555
librknnrt(NPU) ▼ └─────────┘ RTSP :554 (optional)
│ recamera_notify (Python) │──► MQTT / HTTP / UART / WebSocket
│ recamera_web │ │ recamera_services │ │ recamera_onvif (C) │
│ React frontend + backend │ │ Rust: gmgr/skt2ws/ │ │ ONVIF device discovery and control │
│ nginx static assets │ │ tmir/rcisd │ └──────────────────────┘
│ overlay system services │ │ recamera_utils │
│ ttyd/sshd/syslog/ │ │ Factory and test tools │
│ watchdog/board-id │ └─────────────────────┘
Application Index and Build Options​
ApplicationLanguageBoard Build OptionDescription
recamera_ipcC (CMake + protobuf)RK_APP_TYPE=RKIPC_RV1126B_RECAMERA2Core product-level IPC application
recamera_webReact/Node + C/C++RK_APP_RECAMERA_WEB=yWeb configuration interface (frontend + backend)
recamera_servicesRustRK_APP_RECAMERA_SERVICES=ySystem services including gmgr, skt2ws, tmir, and rcisd
recamera_notifyPythonRK_APP_RECAMERA_NOTIFY=yAI inference notifications (MQTT/HTTP/UART/WebSocket)
recamera_onvifCRK_APP_RECAMERA_ONVIF=yONVIF protocol implementation
recamera_utilsShell / Python / CNo explicit build optionFactory testing, serial number tools, and stress tests
rkaiC++ (CMake)Controlled by RK_APP_TYPERKAI wrappers (LLM/VLM) and examples
rkllm-inferenceC++RK_APP_RKLLM_INFERENCE=yRKNN + RKLLM multimodal inference demo
rkipcCRockchip reference implementationUpstream baseline for recamera_ipc
wifi_appC + third-party sourceRK_ENABLE_WIFI=ywpa_supplicant / hostapd / bluez / GATT
cvrC—In-vehicle recording
aov_sampleC—Always-on, low-power vision (AOV) example
ao_record_demoCRK_APP_TYPE includes RK_AO_RECORD_DEMOAudio recording demo
uvc_app_tinyC—UVC camera mode
ipcwebFrontend and backend—Original Rockchip web reference implementation
testdemoC/C++—low_delay_net_display、yoloworld_demo
fastboot_clientCRK_ENABLE_FASTBOOTFastboot client
nginx_mk——nginx packaging
component/Mixed—Common components:ao_record_service、fastboot_server、lvgl、rkadk、rkfsmk
RK_APP_TYPE=RKIPC_RV1126B_RECAMERA2 is a composite identifier. Some applications (such as ao_record_demo) use $(filter RK_XXX, $(RK_APP_TYPE)) to determine whether to build.
recamera_ipc (Core Application)​
Structure​
project/app/recamera_ipc/
├── CMakeLists.txt / Makefile / cmake/ / format.sh
├── LICENSE
├── docs/ # Rockchip_Developer_Guide_Linux_RKIPC_{CN,EN}.md (V1.7.6) + resources
├── protobufs/ # Message definitions for communication with notify and web
├── model/rknn/ # yolox_s.rknn(+json)、nanodet-plus-m_416.rknn(+json)
├── lib/
├── system/
└── src/rv1126b_ipc/
├── main.c
├── CMakeLists.txt
├── RkLunch.sh # ★ System-wide application startup entry point
├── RkLunch-stop.sh
├── rkipc-3840x2160.ini # ★ Default configuration (resolution/bitrate/RTSP/ONVIF options)
└── video/
common Modules (Feature Map)​
project/app/recamera_ipc/common/ The code is organized by feature. Use this table to find the relevant directory:
ModuleResponsibility
audio/audio.c Capture and encoding;rkaudio_mp3.c MP3 prompt audio
isp/rkaiq wrapper
venc/Video encoding
rtsp/Internal RTSP service (127.0.0.1:5554)
rtmp/RTMP streaming
osd/Timestamp/text overlay
region_clip/、roi/Region cropping and ROI
rockiva/ROCKIVA algorithm integration
rc_infer/、rc_model/Custom inference framework and model management
rc_notify/Sends inference results to recamera_notify
event/Event system
storage/Recording storage and SD card management
network/Network configuration
socket_server/Socket service for the web backend and notify
system/、sysutil/System information and utility functions
param/INI parameter read/write
vendor_storage/Vendor storage area (serial number, MAC address, and more)
vigil/、vigil_device_support/vigil-related code (depends on protobuf and libblkid)
player/Player
lvgl/、ui/On-screen UI (LVGL)
uvc/UVC mode
ivm/Intelligent video monitoring
gstreamer/GStreamer-related code
Start and Stop​
On the device, generated init scripts call these commands:
# sh /oem/usr/bin/RkLunch.sh         # Start
# sh /oem/usr/bin/RkLunch-stop.sh # Stop
RkLunch.sh sources /etc/profile.d/RkEnv.sh, then starts rkipc and related processes. To start your own application at boot, modify this script first instead of adding another init script.
Configuration​
The runtime configuration on the device is /userdata/config/rkipc.ini (on a writable partition), initially populated from rkipc-3840x2160.ini. The go2rtc startup script reads its [video.0.rtsp]、[video.0.onvif]、[video.1.rtsp] sections to determine whether to expose port 554.
After changing the configuration, restart rkipc and restart go2rtc as well (its configuration is generated at startup at /tmp/go2rtc/go2rtc.yaml):
# sh /oem/usr/bin/RkLunch-stop.sh && sh /oem/usr/bin/RkLunch.sh
# /oem/usr/etc/init.d/S50go2rtc restart
recamera_services (Rust System Services)​
The following information is from recamera_services/README.md:
ComponentPurposeConfiguration
gmgrGPIO Manager; provides an HTTP/WebSocket API for GPIO control and monitoringgmgr/config.json
skt2wsSocket → WebSocket bridge that forwards Unix socket data (used by rkipc-record-events)skt2ws/config.json
tmirTTY Mirror; multiplexes a serial port to a socket/WebSocket (mirrors ttyS4)tmir/config.json
rcisdreCamera Intellisense daemon; queues events and transfers filesNo external configuration
Other directories include inotify_passwd/ (watches for password file changes), key_factory/ (factory button), led/ (LED control), and scripts/init.d/.
Build​
cd project/app/recamera_services
make # Default target: armv7-unknown-linux-gnueabihf
make SERVICE_TARGET=aarch64-unknown-linux-gnu # Use 64-bit for reCamera Pro
make gmgr # Build one component
make clean && make help
Rust and Docker are required (cross uses Docker for cross-compilation). gmgr/setup-libgpiod.sh prepares the libgpiod dependency.
The default target is 32-bit armv7. reCamera Pro uses aarch64, so pass SERVICE_TARGET=aarch64-unknown-linux-gnu explicitly; otherwise, the binaries will not run. The SDK sets the correct target when you use ./build.sh app, but it is easy to miss when invoking make manually.
Output Layout​
out/
├── etc/init.d/{S40gmgr,S40skt2ws,S40tmir,S49rcisd}
└── usr/
├── bin/{gmgr,skt2ws,tmir,rcisd}
└── share/{gmgr_config.json,skt2ws_config.json,tmir_config.json}
gmgr API​
Listens on HTTP port 8080 and also provides the Unix socket /dev/shm/gmgr.sock:
GET    /api/v1/gpios                     # Lists all pins and their full descriptions
GET /api/v1/gpios/events # WebSocket stream of events from all pins
GET /api/v1/gpio/{pin_id} # Full description of one pin
GET /api/v1/gpio/{pin_id}/info # Configuration information
GET/POST /api/v1/gpio/{pin_id}/settings # state / edge / debounce_ms
GET/POST /api/v1/gpio/{pin_id}/value # Reads or writes the pin level
GET /api/v1/gpio/{pin_id}/event # Most recent event
GET /api/v1/gpio/{pin_id}/events?limit=5
Local development enables the mock-gpio feature by default. For a hardware build, add --features hardware-gpio:
cargo build --release --features hardware-gpio
cargo test
recamera_notify (Python Notification Service)​
This service receives protobuf inference data from rkipc and forwards AI camera results through multiple channels.
CapabilityDescription
Socket serverReceives inference data from rkipc
Parsingprotobuf (protobufs/inference_pb2.py)
FormattingTemplate-based output
Notification channelsMQTT、HTTP、UART、WebSocket
ReliabilityAutomatically reconnects after an MQTT disconnection
ConfigurationJSON (notify_config_default.json)
StatusMQTT/HTTP/UART runtime status is written to a temporary JSON file
Modules: core/ (config_manager, inference_parser, template_formatter, socket_server, notifier_manager), notifiers/ (base_notifier, mqtt_notifier, http_notifier, uart_notifier, websocket_server, notifier_factory), and tests/ (including run_all_tests.py).
Build and Deploy​
export RK_APP_RECAMERA_NOTIFY=y
make -C project/app/recamera_notify
Installed paths on the device:
ItemPath
Python package/usr/lib/python3.11/site-packages/recamera_notify/
Startup script/usr/bin/notify_server.sh
System service/etc/init.d/S49notify
# /etc/init.d/S49notify start
# /etc/init.d/S49notify stop
# ps aux | grep notify_server
The target device uses Python 3.11. Check syntax and dependency compatibility if you develop on the host with another version.
recamera_onvif (C)​
Implements standard ONVIF device discovery and control. The directory contains src/ (dom.c, authenticate.c, cJSON.c, and other SOAP/XML handling code), socket_client/, and script/. It also includes RECV.log, SENT.log, and TEST.log for packet-capture debugging.
Enabled by RK_APP_RECAMERA_ONVIF=y When ONVIF is enabled, go2rtc also enables external RTSP (see Device Access and Debugging for the precedence rules).
recamera_web (Frontend and Backend)​
project/app/recamera_web/
├── recamera_web_react/ # React frontend
│ ├── package.json / src / public / backend / nginx.conf / requirements.txt
└── recamera_web_backend/ # C/C++ backend (CMake + thirdparty + ipcweb-env-rv1126b)
Frontend features (from its README):
  • Internationalization (English and Chinese), light/dark themes, and responsive layout
  • Device information: model, serial number, CPU/memory/storage monitoring, save configuration, reboot, and factory reset
  • Live view: stream preview, play/pause, snapshots, recording, and resolution/frame rate/bitrate/codec controls
  • Recording settings: continuous, scheduled, motion-triggered, or AI-event-triggered recording; storage path, segments, loop overwrite, and file browsing, playback, download, and deletion
  • AI inference: object detection (YOLO series), image segmentation, keypoint detection (pose/face/hand), and image classification (ResNet, EfficientNet). Each task can configure its model, confidence threshold, batch size, inference device (GPU/CPU/NPU), and visualization.
  • Terminal: manage the device through a command-line interface (integrated with ttyd)
The frontend requires Node.js 18 or later. The build output is deployed according to nginx.conf (nginx is provided by nginx_mk). Video preview uses go2rtc WebRTC on port :8555.
recamera_utils (Factory and Test Utilities)​
DirectoryItem
hw_test/bt_adv.sh (Bluetooth advertising test), imu_test.py (IMU test; corresponds to kernel option CONFIG_INV_ICM42670_I2C=y)
emc_test/AP6256_MFG.bin, the wl utility, and BT RF Test Commands for Linux-v09.pdf — Wi-Fi/Bluetooth RF certification tests
rf_range_test/bt_client.py、bt_server.py、wifi_ap.py、wifi_sta.py —— RF range tests
stress_test/cpu_stress.py、npu_stress.py、emmc_sd_stress.py、emc_test.py
sn_tool/SN_TOOL — writes the serial number (used with upgrade_tool sn)
Use these tools as the basis for factory work instructions. Each directory contains a README.md.
Other Applications​
ApplicationDescription
rkaiRKAI wrapper library (rkai_LLM, rkai_VLM), examples (rkai_samples_llm.cpp, rkai_samples_vlm.cpp, rkai_samples_vlm_vision.cpp), and documentation doc/Rockchip_Developer_Guide_Linux_RKAI_{CN,EN}.md; common/include/ contains rknn_api.h, rknn_custom_op.h, cJSON.h, cnpy.h, and easy_timer.h
rkllm-inferenceSee AI and NPU Development
wifi_appBuilds wpa_supplicant (2.6, or 2.10 for WPA3), hostapd, libnl 3.9.0, openssl 3.2.1, bluez 5.77, rtk_hciattach, and GATT server/client tools; configuration is in /userdata/rk96x/conf. RK_ENABLE_WIFI_CHIP selects the RK960 or RK962 prefix
aov_sampleAOV low-power examples:sample_aov_aiisp_iva_venc.c、sample_aoa_capture.c、sample_aov_audio.c、resume_suspend_test.sh
testdemo/yoloworld_demoEnd-to-end YOLO-World demo
component/ao_record_service (audio recording service), fastboot_server (fast boot), lvgl (GUI), rkadk (application development kit), rkfsmk (filesystem)
Startup Order Overview​
Scripts in /etc/init.d/ and /oem/usr/etc/init.d/ run in numerical order on the device:
OrderScriptSource
S00board-idoverlay
S10log(WebSocket logging)overlay
S15watchdogoverlay
S20hwclockoverlay
S20/S21linkmount / appinitbuild.sh generated automatically (mounts partitions / calls RkLunch.sh)
S40gmgr、skt2ws、tmirrecamera_services
S49rcisdrecamera_services
S49notifyrecamera_notify
S50sshd、ttyd、go2rtcoverlay
S70vsftpdoverlay
S99factorykey、inotify_passwd、ledrecamera_services
When adding a service, choose an unused sequence number and account for dependencies. For example, start network-dependent services after S40 and services that need /userdata after S20linkmount.
Source Repositories​
This is a source snapshot without .git metadata. The README files identify these applications as corresponding to Seeed internal GitLab repositories:
ApplicationRepository
recamera_onvifhttps://iteam-gitlab.seeed.cn/rockchip/linux-ipc-app-recamera2-onvif.git
recamera_utilshttps://iteam-gitlab.seeed.cn/rockchip/linux-ipc-app-recamera2-utils.git
The naming pattern is rockchip/linux-ipc-app-recamera2-<module>. Other recamera_* applications likely follow the same convention (verify this in the internal GitLab before completing the table). Make upstream changes in the corresponding repository rather than in this SDK snapshot, or they may be lost during the next sync.
Change Impact Quick Reference​
If you want to change…Edit hereRebuild
Video resolution/stream/RTSP/ONVIF optionsrecamera_ipc/src/rv1126b_ipc/rkipc-3840x2160.ini or on the device /userdata/config/rkipc.iniapp + firmware(or edit the device INI directly)
Web UI pagesrecamera_web/recamera_web_react/src/app + firmware
Web backend APIsrecamera_web/recamera_web_backend/src/Same as above
GPIO definitions/APIrecamera_services/gmgr/config.json and src/Same as above
Inference notification format/channelsrecamera_notify/notify-server/、notify_config_default.jsonSame as above
AI modelsrecamera_ipc/model/rknn/ and the corresponding .json filesapp + firmware
Startup applicationsrecamera_ipc/src/rv1126b_ipc/RkLunch.shapp + firmware
Log format/outputoverlay-buildroot-syslog-ng/etc/syslog-ng.confrootfs + firmware
Serial/SSH/ttyd policyoverlay-buildroot-sshd、overlay-buildroot-ttydrootfs + firmware
Audio channel mappingoverlay-buildroot-asound/etc/asound.confrootfs + firmware
