BSP Troubleshooting
The general rule is to identify the failing layer first. This SDK has five layers, each with different debugging methods:
1. Host environment     → setup_build_env.sh --check / ./build.sh check
2. Build → build.sh logs, make info, help <component>
3. Images and flashing → output/image/, upgrade_tool, serial console
4. System boot → serial console at 1500000, init scripts, /var/log
5. Application/runtime → /var/log/Recamera2_developer.log, processes, ports, configuration
1. General Diagnostic Tools​
CommandPurpose
./build.sh checkCheck host build dependencies
./build.sh infoPrint the current BoardConfig, all non-empty RK_* variables, make info from the three component SDKs, and power-domain checks
./build.sh help <component>Print the actual make command and arguments for a component so you can reproduce it manually
make -C project/app/<app> V=1Enable detailed output for an application build
make V=1 -C media/samplesEnable detailed output for media (a non-empty V disables CMD_DBG=@ quiet mode)
./build.sh DEBUG appRebuild with -O0 -g and skip stripping during packaging
./build.sh ASAN appRebuild with AddressSanitizer to investigate memory problems
/bin/sdkinfo on the deviceIdentify the build and BoardConfig running on the device
cat /etc/ota_version on the deviceCheck the firmware version
build.sh sets trap 'err_handler' ERR; on failure, it prints the failed function and line number. Search the log for err_handler or Error: to locate the problem quickly.
2. Host Environment and Build Issues​
SymptomCauseResolution
./build.sh --help opens the board-selection menulunch has not been run; the script checks for .BoardConfig.mk before parsing argumentsRun ./build.sh lunch first; then help / --help will work
Not found tool aarch64-rockchip1240-linux-gnu-gcc, please install first !!!Toolchain directory is missing or not executableConfirm tools/linux/toolchain/aarch64-rockchip1240-linux-gnu/bin/ exists; if needed, source tools/linux/toolchain/<tc>/env_install_toolchain.sh
*** error: Please Check Configure !!! / build app depend on media libs and header filesApp build started before media was builtRun ./build.sh media first and confirm output/out/media_out/{include,lib} exists
Build rootfs is not yet complete, packaging cannot proceed!rootfs tar archive was not generatedRun ./build.sh rootfs and check output/out/sysdrv_out/rootfs_glibc_rv1126b.tar
It is unclear which app failed to buildproject/app/Makefile builds apps serially with $(foreach) and exits on the first failureReproduce the build with make -C project/app/<app> V=1
Rust app (recamera_services) produces an armv7 binaryThe app Makefile defaults to armv7-unknown-linux-gnueabihfRun make SERVICE_TARGET=aarch64-unknown-linux-gnu
cross reports an error or hangsDocker is stopped, or the user is not in the docker groupRun sudo systemctl start docker; log out and back in
Node frontend build failsNode.js version is below 18Run nvm use 18 or use the version installed by setup_build_env.sh
CMake version is too oldrecamera_ipc requires CMake ≥3.21Use the CMake installed by setup_build_env.sh and check PATH order
protobuf-related build errorslibprotobuf-dev / protobuf-compiler is missingRun sudo apt install libprotobuf-dev protobuf-compiler
Unexpected errors after switching boardsOutputs from old and new configurations are mixedRun ./build.sh clean, then rebuild
Disk is fullBuildroot, kernel, and media outputs are largeKeep at least 20 GB free (100 GB recommended); use du -sh output sysdrv/source/buildroot to locate usage
Permission problems after one build as rootBuild outputs are owned by rootRun sudo chown -R $USER:$USER . and rebuild
Scripts behave incorrectly because symbolic links are missingFiles were transferred through WindowsRe-extract the original tar archive; see Download and Extract
3. Flashing Issues​
upgrade_tool ld does not list the deviceNot in Maskrom / Loader mode; udev rule missing; not run with sudoInstall 88-rockusb.rules, then run udevadm control --reload-rules && udevadm trigger; confirm lsusb shows a 2207: device; use sudo
Permission denied when running upgrade_toolExecute permission was lost during extractionRun chmod +x tools/linux/Linux_Upgrade_Tool/upgrade_tool
./rkflash.sh update does nothingThe branch is commented out in the scriptRun sudo upgrade_tool uf output/image/update.img
Unexpected partition behavior after ./rkflash.sh allall does not flash env.imgRun upgrade_tool di -p output/image/env.img manually (or use parameter.txt)
./build.sh sdcard_upgrade produces no outputThe Recamera2 board configuration does not define RK_SDCARD_UPGRADE_UBOOT_DEFCONFIG; check_config returns silentlyAdd the required variables to the board configuration; see System Customization (DTS / Kernel / Buildroot / Overlay)
Device is bricked after flashing was interruptedLoader was not written completelyForce Maskrom mode, run upgrade_tool ul download.bin, then flash again
Writing 'xxx' failedImage size does not match the partition sizeCheck that boot.img is under 11 M and rootfs.img is under 3 G
4. Boot Issues​
The serial console is the only reliable channel: 1500000 8N1, console=ttyFIQ0.
Serial-console symptomDiagnosisResolution
No output at allLoader / DDR did not start, or the serial connection / baud rate is wrongConfirm 1500000 baud; reflash idblock.img + download.bin; measure the serial TX signal
U-Boot appears, then stopsKernel image or DTB problemReflash boot.img; check RK_KERNEL_DTS
Kernel panic - not syncing: VFS: Unable to mount root fsrootfs does not match boot, or PARTUUID changedUse boot and rootfs from the same build; after partition changes, reflash env
Repeated resets with watchdog messages on serialA blocked process prevented watchdog refresh (-T 30)Stop S15watchdog and investigate; check for a stuck process
System boots but has no networkudhcpc script or DNS-priority issueSee the network troubleshooting section in Device Access and Debugging
Time is wrong by a whole number of hoursS20hwclock uses --hctosys --utc, although the comment says the RTC stores local timeConfirm whether the RTC stores UTC or local time, then adjust the script if needed
Cannot enter Linux but U-Boot worksrootfs is corruptedFlash only rootfs with sudo ./rkflash.sh rootfs
Check the boot sequence with:
# ls /etc/init.d/ /oem/usr/etc/init.d/          # Available startup scripts
# dmesg | head -50 # Early kernel logs
# cat /var/log/Recamera2_developer.log | head # Application logs
# ps w # Processes that actually started
5. Runtime and Application Issues​
Shared Library Not Found​
# ldd /userdata/my_app
  • Missing librockit.so, librknnrt.so, etc. → LD_LIBRARY_PATH does not include /oem/usr/lib. Login shells set it through /etc/profile.d/RkEnv.sh; for non-login contexts (init scripts, cron), source the file or export the variable explicitly.
  • Missing third-party library → the library is not in the rootfs. Enable its Buildroot package; see System Customization (DTS / Kernel / Buildroot / Overlay).
  • At link time, you may also need -Wl,-rpath,/oem/usr/lib; see Choose a Development Path.
Architecture / ABI Mismatch​
# file /userdata/my_app        # Must be ARM aarch64
Exec format error means the binary was built for x86-64. GLIBC_2.xx not found means the host toolchain is newer than the target device's runtime.
Video Issues​
Sample cannot open VI / device node is busyrkipc already owns the deviceRun sh /oem/usr/bin/RkLunch-stop.sh, then retry; restore the service when finished
Image is all black or greenSensor not detected or IQ file missingRun `dmesg
Wrong colors or heavy noiseIQ file does not match the sensorCompare RK_CAMERA_SENSOR_IQFILES with the installed sensor
Cannot receive the RTSP streamgo2rtc has not enabled external port 554Check [video.0.rtsp] enable in /userdata/config/rkipc.ini, then restart S50go2rtc
Web UI shows video but an external player does notgo2rtc API is bound to 127.0.0.1Use WebRTC on :8555 or forward port 1984 over SSH
/dev/videoN number changedDifferent firmware versions enumerate devices differentlyCheck on the device with v4l2-ctl --list-devices; do not hard-code the number
See docs/zh/media/Rockchip_Trouble_Shooting_Linux_VENC_CN.pdf for Rockchip's video troubleshooting guide.
NPU / AI Issues​
rknn_init failsModel was not converted for rv1126b, or Toolkit and Runtime versions do not matchConvert again with target_platform='rv1126b'; check the board's librknnrt.so version (internal baseline 2.3.2)
Inference output is completely wrongPreprocessing mismatch (mean/std, RGB/BGR, NCHW/NHWC, resize policy)Check the export script parameters instead of guessing
Results are inaccurateINT8 calibration set is not representativeFirst establish an FP16 baseline, then quantize again with a better calibration set
OOM / process killedLLM / VLM uses too much memoryCheck memory_usage with rkllm_benchmark_demo; try a smaller quantization
Inference is slowOnly one NPU core is in useSet rknn_set_core_mask(ctx, RKNN_NPU_CORE_0_1)
Performance degrades after a long runThermal throttlingCheck thermal status; see docs/zh/bsp/Rockchip_Developer_Guide_Thermal_CN.pdf
VLM output is garbled or unexpectedVision special tokens do not matchPass img_start / img_end / img_content at runtime
Audio Issues​
See the issue table in Audio Development. The most common problem is opening hw:0,0 directly instead of using dsnoop, resulting in Device or resource busy.
Services and Ports​
# netstat -tlnp        # 22 / 7681 / 21 / 8555 / 1984 / 8765 / 554 / 5554
# ps w | grep -E 'rkipc|gmgr|skt2ws|tmir|rcisd|go2rtc|ttyd|notify'
# /etc/init.d/S49notify start|stop
# /oem/usr/etc/init.d/S50go2rtc restart
If SSH rejects a correct password, PAM lockout may have been triggered (5 failures / 300 seconds). The state file is /userdata/config/system/login_lock.json; rebooting clears it.
If the ttyd page says the user is not allowed, the allowlist in ssh-login-whitelist.sh contains only root and admin.
If FTP does not show the config directory, hide_file / deny_file in vsftpd.conf intentionally hide it. Use SFTP instead.
Logs​
# tail -f /var/log/Recamera2_developer.log    # Human-readable
# tail -n 100 /var/log/Recamera2.log # JSON for programmatic parsing
# dmesg # Kernel logs
WebSocket live logs on port 8765 bind to 127.0.0.1. From the host, use ssh -L 8765:127.0.0.1:8765 root@<IP>.
Memory and Performance​
The kernel has debug nodes enabled; inspect them with:
# cat /proc/rk_cma/*        2>/dev/null      # CONFIG_RK_CMA_PROCFS
# cat /proc/rk_dmabuf/* 2>/dev/null # CONFIG_RK_DMABUF_PROCFS
# cat /proc/rk_memblock/* 2>/dev/null # CONFIG_RK_MEMBLOCK_PROCFS
# cat /proc/rk_rga/* 2>/dev/null # CONFIG_ROCKCHIP_RGA_PROC_FS
# ls /sys/kernel/debug/ # CONFIG_DEBUG_FS
Exact node names depend on the device and still need hardware verification. Note that RK_BOOTARGS_CMA_SIZE="8M" sets a small CMA region; check it first if large contiguous allocations fail.
Coredumps are enabled with CONFIG_ELF_CORE=y. __BUILD_ENABLE_COREDUMP_SCRIPT() in build.sh can generate an enablement script. Use it together with IMAGE/.../DEBUG_FILES/kernel/vmlinux.tar.bz2 and a cross-gdb to analyze a dump.
6. Information to Include in a Bug Report​
For an internal report or a Rockchip issue (see docs/en/Rockchip_User_Guide_Bug_System_EN.pdf), collect this information in one pass:
# On the host
./build.sh info > info.txt 2>&1
cat IMAGE/*/build_info.txt
# On the device
/bin/sdkinfo
uname -a && cat /proc/cmdline
dmesg > dmesg.txt
cat /var/log/Recamera2_developer.log > app.log
cat /run/board_id.env
netstat -tlnp
ps w
Also include the complete serial boot log (1500000 baud), reproduction steps, and the path to the IMAGE/..._RELEASE_TEST/ archive.
Static source findings, their evidence, impact, and verification status are collected in Source Review and Known Issues to keep maintenance audits separate from operational procedures. If you encounter a related behavior, verify it against the current SDK files and version first.
