Troubleshoot by Symptom
This page groups common reCamera Pro issues by what you see, so you can jump straight to the fix. If none of these match, collect logs and share them with support.
| Symptom | Section |
| WebUI repeatedly shows Wi-Fi errors / cannot preview | 1. Wi-Fi errors and no preview |
| Uploading an FP16 model freezes the WebUI | 2. FP16 model upload freezes the WebUI |
Windows cannot reach 192.168.42.1 over USB | 3. Windows USB connection fails |
| Internet access lost after plugging in USB | 4. Host computer loses Internet over USB |
| Device needs a full reset | 5. Factory reset |
Symptom: the WebUI repeatedly prompts Wi-Fi connection errors and cannot show the live preview.
Solution:
- Check whether the device is powered properly — unstable power is the most common cause.
- If powering over the Type-C interface, make sure the adapter supports the PD protocol.
- For reliable operation, use the factory-supplied DC power cable (12 V, 3 A).
- After fixing power, verify the Wi-Fi connection in Device Info → Network Settings and confirm the green LED is solid before re-opening the preview.
Symptom: on firmware V1.1.1 and earlier, uploading an FP16 precision model causes the main system process to freeze and the WebUI becomes unresponsive.
This issue applies to FP16 (16-bit floating point) model quantization. Some older documentation used the abbreviation "FB16" — both refer to the same quantization format.
Solution — use whichever method is available:
Option A: Factory reset
Press and hold the button on the side of the device for 15 seconds to restore factory settings. The device will reboot with a clean configuration and the offending model removed. See Firmware update and recovery for the full reset flow.
Option B: Edit the configuration file over SSH
- Connect to the device via USB and log in over SSH.
- Open
/userdata/config/rkipc.inifor editing. - In the
[rc_model.0]section, change themodelfield toyolox_s.rknn. - Save and restart the device.
Symptom: after connecting the Type-C cable, http://192.168.42.1 does not load in the browser on Windows.
Solution: the Windows virtual network adapter usually did not obtain an IP address automatically.
- Open Control Panel → Network and Internet → Network and Sharing Center → Change adapter settings.
- Find the adapter named something like
Remote NDIS based Internet Sharing Deviceor related to reCamera (unplug/replug to see which adapter disappears and reappears — that is the reCamera Pro interface). - Right-click → Properties.
- Double-click Internet Protocol Version 4 (TCP/IPv4).
- Select Obtain an IP address automatically and Obtain DNS server address automatically.
- Click OK and try
http://192.168.42.1again.
Symptom: after connecting the reCamera to the computer via USB, the host computer cannot reach the Internet.
This happens because the USB network adapter takes priority in the OS routing table. See the network connection troubleshooting diagram for the fix.
5. Factory reset
If none of the above apply and the device is still misbehaving, restore factory settings:
- Hardware: press and hold the side button for ~15 seconds until a prompt sound is heard. Wait for the green LED to stay on continuously.
- WebUI: Device Info → System Settings → Factory Reset.
See Firmware update and recovery for what is preserved and what is wiped.
Other issues
- RTSP, recording, or storage problems → Event recording configuration and Find recordings and storage.
- Model conversion or inference problems → AI Inference configuration; for custom models see Choose a model deployment path.
- API call failures → API troubleshooting (B4 / T3 placeholder).
